Help! Bilstein 5100 leveling kit questions.
Discussion in 'Suspension' started by Darthinvader48, Mar 25, 2019.
  1. Mar 25, 2019 at 6:05 AM
    Darthinvader48
    Darthinvader48 [OP] New Member
    2019 Black tundra SR5 TSS 4x4
    Hello I’m New to this forum and I had a quick question. I’ve been searching all over and I can’t find any answers to my question about the Bilstein 5100s front and rear.
    I want to replace the stock shocks with both front and rear 5100s in order to level the truck with improved handling vs just getting the rough country spacer blocks.
    1) would you recommend these shocks over a rough country leveling kit (3in front 1in rear)
    2) If I went with the set of four 5100s what else do I need to buy to ensure I don’t mess anything up? I don’t off-road much this is just for the highway and occasionally the beach no serious off reading. I will eventually put 33s or 35s on it.
    3) Would you recxoment any other type of kits In the same price range?
    4) do I need a differential drop kit?
  2. Mar 25, 2019 at 6:35 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    1) yes, the 5100's are much better than any spacer lift.
    2) the highest the 5100's will lift is 2.24" in the front. for the rear, the 5100's will accommodate a lift, but they do not provide the lift. you will need to get either an add a leaf, a block, or a shackle to lift the rear. (shackles seem to be the preferred method for the rear). depending on your wheel offset, 33's will easily clear with minimal trimming and 35's will require more trimming.
    3) for the price, nothing beats the 5100's. there really isnt any other lift option in that price range. however, the next best lift would be the bilstein 6112's. they include a shock and coil and go for about $800 for the fronts: they can provide 0.75", 1.3", 1.9", and 2.5" of lift. however, once you get around 2.5-3.0" of lift, you may have to start thinking about an aftermarket UCA to achieve a proper alignment.
    BTW, I have the 5100's on the middle setting (1.57") with 33's:
    DMB4x4, bretn77, thornjude89 and 5 others like this.
  3. Mar 25, 2019 at 6:39 AM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    Using @Coachbuilder1 recommendation will give you 3” or so.
    5100’s on top setting with his shims
    And his shackles in the rear
    You don’t have to do 5100’s in the rear unless you just want to replace the OEM’s.
  4. Mar 25, 2019 at 6:39 AM
    Darthinvader48
    thanks! @Netmonkey I’m trying to achieve the same look your truck has I didn’t want to touch the rear end if I didn’t have to I just wanted it perfectly leveled.
    Do I need to buy a differential drop kit?
    And all you did there was add the 5100s no additional parts?
  5. Mar 25, 2019 at 6:41 AM
    Welcome from NY.
    Just 5100's and set the fronts on the middle setting.
  6. Mar 25, 2019 at 6:42 AM
    Darthinvader48
  7. Mar 25, 2019 at 6:42 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Check out my build thread below vvv
  8. Mar 25, 2019 at 6:47 AM
    Netmonkey
    Georgetown, TX
    yeah, I only purchased the 5100's for the front. I left the rear stock. if I were going to lift any higher in the front, I would lift the rear 1". as it sits now, there is a tiny bit of rake. although, it looks perfectly level. I don't have 4 wheel drive, but I think the CV's would be ok with 1.5" of lift (someone can chime in on that). but a front diff drop wouldn't hurt. I think those are $30?
    for me, the 5100's, the installation, and the alignment was about $450.
  9. Mar 25, 2019 at 6:47 AM
    :thumbsup:
  10. Mar 25, 2019 at 6:50 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    5100’s in the front using the middle setting and a Coachbuilder shim each side, no rear mod is about the same level profile as a Pro (which is 2” higher in the front).
    David from CB will recommend bumpstop extensions if you use his shims.
    5100’s are a bit stiff though and you’ll definitely feel it at top setting.
    You might want rake if you tow or haul.
  11. Mar 25, 2019 at 7:29 AM
    Darthinvader48
    @JoshuaA i don’t tow or haul and don’t plan to. But I am very ignorant when it comes to suspension I’ve rebuilt and engine but I’ve never touched anything suspension related lol. So I have no idea what those shims are you mentions or what they assist with do they provide additional lift?
  12. Mar 25, 2019 at 7:35 AM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    cb shim is placed on top of the coil over. it is .25" thick and increases height about .5". Tundras have a driver side lean because of the gas tank, you, and the battery on the same side. I took measurements on my truck, and it was .5" lower on the driver side. which is why I did 1 cb shim on the driver side and none on the passenger side.
    https://shop-coachbuilder.myshopify.com/collections/frontpage/products/coachbuilder-strut-
    coilover-shim-provides-50-of-lift
    JoshuaA likes this.
  13. Mar 25, 2019 at 7:38 AM
    Darthinvader48
    @Faht Nocker do I need two or is this just for the driver side issue? And thanks everyone for answering these simple questions I should already know the answer to
  14. Mar 25, 2019 at 7:39 AM
    Faht Nocker
    Woody
    Milky Way
    it really comes down to what you are trying to do as far as offset, tire size, and many other variables. The best thing to do is to contact @Coachbuilder1 or Darren @BOSS4x4s and tell them your goals.
    JoshuaA likes this.
  15. Mar 25, 2019 at 8:47 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Instead of top setting, middle setting will offer better preload ride. Middle is 1.57” + .5” shim = ~2” for leveling height. There’s a possibility of driver’s side lean as noted above. Measure what you are now from the ground to top of wheel well all 4. Some people add an extra shim to the driver’s side, some don’t.
    Faht Nocker likes this.
  16. Mar 25, 2019 at 10:35 AM
    r1-superstar
    DB
    UTAH
    I went through all this in my build thread. Hopefully your questions will be answered. :thumbsup:
  17. Mar 25, 2019 at 6:58 PM
    Darthinvader48
    @r1-superstar yes thankyou I only ordered two shims looks like I will have to order a third one I just checked my drivers side and is sits approximately .5 lower than the passenger
  18. Mar 25, 2019 at 7:05 PM
    Darthinvader48
    I’m still Tempted to only put one on the driver side instead of buying an additional is the lean more noticeable after the strut install?
  19. Mar 25, 2019 at 8:49 PM
    r1-superstar
    DB
    UTAH
    Did you go through Darren @BOSS4x4s ? He has the best pricing. As for the shims, yeah, half an inch is pretty noticeable.
  20. Mar 26, 2019 at 5:38 AM
    Darthinvader48
    I did not :( I just purchased them through boss 4X4 at $19 plus shipping
  21. Mar 26, 2019 at 5:44 AM
    Darthinvader48
    Through everyone's advice I ended up purchasing the following: 2 Bilstein 5100s, 3 coachbuilder shims (1 ps, 2 DS), and the differential drop kit. If I'm missing anything please let me know guys, I would like to do this all in one run to the shop.
  22. Mar 26, 2019 at 7:01 AM
    Netmonkey
    Georgetown, TX
    that would be everything for lifting. however, the shims are optional. I didn't need to use them to match the left to right height. what is your goal for the lift height? 1.5", 2.0", 2.25", 2.5" or?
    using shims can cause the same issues as using spacers. if you are not careful, you can bottom out the shock which will destroy it. if you use shims, do not jump your truck or slam it hard off-road. you may also want to consider bump stop spacers so that you do not bottom out the shock.
  23. Mar 26, 2019 at 8:10 AM
    Darthinvader48
    2.0 is my goal on the drivers side apparently 1.5 or near there is my goal on the passenger side I just want an almost level truck on both the driver and passenger side
  24. Mar 26, 2019 at 8:14 AM
    Netmonkey
    Georgetown, TX
    is your drivers side currently 0.5" lower than your passenger side? did you measure (fender to ground) on level ground?
  25. Mar 26, 2019 at 8:47 AM
    Darthinvader48
    I measured it in the garage
    Netmonkey likes this.
  26. Mar 26, 2019 at 8:49 AM
    r1-superstar
    DB
    UTAH
    Sounds like you have it all. Set your 5100s to the middle setting, install two shims on the driver's side and one on the passenger's side and call it good!. Post pics!
  27. Mar 26, 2019 at 12:01 PM
    Darthinvader48
  28. Apr 2, 2019 at 7:59 PM
    Darthinvader48
    Here’s the finished product
  29. Apr 2, 2019 at 8:01 PM
    Darthinvader48
    Middle setting with two shims on driver side one on passenger it has about a half inch to 3/4 in rake
    r1-superstar likes this.
  30. Apr 2, 2019 at 8:13 PM
    teedubbya
    Austin TX
    Looks good! Love the black
    Darthinvader48[OP] likes this.
