Help! Broken leaf spring!
Discussion in '2.5 Gen Tundras (2014-2021)' started by maziv52, Jun 22, 2022.
  1. Jun 22, 2022 at 12:49 PM
    maziv52
    maziv52 [OP] New Member
    So I had a weird clunky sound while going over bumps at slower speeds coming from the rear. Took it to Toyota and found out I have a broken rear passenger side leaf spring. The bottom plate of spring totally sheared in half. Toyota says they have to replace the whole thing! Meanwhile, I have a ‘17 trd pro crew. Only 40k miles!!! Tech said he hasn’t seen this before. They want almost 2k to replace. Can this be welded? Take to a different shop? And no, I do not tow or have heavy payloads. Thanks in advance for any suggestions.
  2. Jun 22, 2022 at 12:54 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    No warranty?
  3. Jun 22, 2022 at 1:00 PM
    maziv52
    I do not have any extended warranty. I feel like calling Toyota though and inquiring seeing as the tech said he had never seen that.
  4. Jun 22, 2022 at 1:01 PM
    maziv52
    Not like they’d care or do anything. Just want to bitch at somebody.
  5. Jun 22, 2022 at 1:03 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Welded? No. Either buy a used set (eBay/junkyard) or buy brand new aftermarket. Either way it'll be less than $2k.
    BlueCrushSC16 and snivilous like this.
  6. Jun 22, 2022 at 1:03 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I highly doubt it can be welded. The spring flexes, welds are tight and solid.
    its sucks that it broke, but on the bright side you can now buy a much nicer aftermarket spring and it will probably ride even better
    AZBoatHauler likes this.
  7. Jun 22, 2022 at 1:09 PM
    saybng
    Gary
    Ventura CA
    Sux..I would not weld that! Get a new set.
  8. Jun 22, 2022 at 1:12 PM
    maziv52
    Ok. Welding is out. Guess I was reaching a bit there. So if I get aftermarket leaf spring I assume I have to do both sides. Any recommendations? I have the stock pro suspension.
  9. Jun 22, 2022 at 2:13 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    It'll all just depend on what you're doing. But if you don't know yet, then just buy a set of used leaf springs off of CL, FBMP, or even our marketplace to replace it momentarily.
    Leo's first likes this.
  10. Jun 22, 2022 at 2:15 PM
    MARanger
    MARanger Lost in the woods
    Andy
    Home of Friendly's Ice Cream
    2017 Super White SR5 DC 4X4
    See if you have a custom spring shop around you. I have a shop near me in MA that will break a spring pack and replace the broken spring then put the pack back together. I had a broken leaf and it cost me about 200 for them to replace.
    Joe333x, bulldog93 and maziv52[OP] like this.
  11. Jun 22, 2022 at 2:20 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Dude for $1200 you can get a custom set of Alcan leaf springs that would be MILES ahead of factory. Changing out leaf springs isn't a hard job either. You could get it done at a lot of places if you aren't able to do it yourself
  12. Jun 22, 2022 at 2:22 PM
    As mentioned, I would check locally for a used set or have that leaf replaced for now. There are alot of options for leaf springs. It all depends on how you use the truck. I put a set of Alcans in mine...right around $1K shipped. The OEM springs are too soft for these trucks. Mine were shot at less than 14K miles on my 2020.
    texasrho83 and M3Tundra-JK like this.
  13. Jun 22, 2022 at 2:23 PM
    M3Tundra-JK
    Scott
    2005 GX470
    My experience is that Toyota's in general have too soft leaf springs. Even my Tacoma T/X Baja leafs were shot in short order.
    nobodyintexas likes this.
  14. Jun 22, 2022 at 2:32 PM
    Yeah it's crazy how soft they are for such a capable truck. I put Alcans in mine.
  15. Jun 22, 2022 at 2:43 PM
    maziv52
    Thanks for the suggestions all. Helps me a lot. Honestly, i didn’t need a pro at all. Only reason I bought it was I got a smokin deal from a local seller pre Covid times. It was my personal truck but I have since turned it into my work truck. Used mostly for estimating. I will definitely look into all mentioned options. May just get the alcans if they are superior to oem. The times I’ve pulled a trailer she sagged like a motha.
    M3Tundra-JK likes this.
  16. Jun 22, 2022 at 3:20 PM
    maziv52
    I can’t find any local takeoffs. Are icon springs any good? At this point I’ll probably go with whoever can get them to me the quickest.
  17. Jun 22, 2022 at 3:28 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Call Lew at Alcan 970-241-2655. Only takes 4-5 days to build and have them ready to ship but that's if there's no wait time.
  18. Jun 22, 2022 at 4:30 PM
    M3Tundra-JK
    Scott
    2005 GX470
    Icon is really good, but for me, I'd never purchase used suspension components. Deaver and Alcan would be the best tbh. Deaver has a lot of different types of leafs to choose from, Alcan will be all tailored with the options you input on the form.
    Occidentalis likes this.
  19. Jun 23, 2022 at 9:06 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Check the marketplace, there are some stock 2.5 gen leafs posted for sale today. Could be a great and less expensive fix for you to get your truck back on the road.
  20. Jun 23, 2022 at 9:08 AM
    He has some springs.....
    https://www.tundras.com/threads/lightly-used-2020-tundra-parts.108979/#post-2811028
  21. Jun 23, 2022 at 9:23 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Most OEM leaf springs flatten within a couple of years. I wouldn’t buy used take offs unless they were brand new take offs.
  22. Jun 23, 2022 at 9:24 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Hell even the new packs are trash lol
    joonbug[QUOTED] likes this.
  23. Jun 23, 2022 at 9:26 AM
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    @maziv52 where are you located? I have some some leafsprings in my garage that I would love to get rid of.
  24. Jun 23, 2022 at 10:15 AM
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    Currency converter= Earned to wasted dollars
    Hey… Bad for business here..:rofl:LOL
    Hey OP… If your in the PA area and your hardup for leafs springs I’d be glad to help you out for whatever you can pay…
    2020 4x4 Tundra
    Tundra234 likes this.
  25. Jun 23, 2022 at 2:54 PM
    maziv52
    Update:
    Took the truck to a spring shop. They found that the driver side leaf spring was broke as well. BOTH bottom leafs broke in the exact same spot. Pretty wild. Gotta be defective metal or something. Can’t convince me otherwise. If I towed or had high payload maybe but I definitely do not. Pretty pissed I paid Toyota a $150 diagnostic fee and the dude didn’t even see the driver side leaf spring. Subpar performance to say the least. Anyway, spring shop repaired both for $350. Not too shabby. Thanks to everyone offering their used leaf springs but after this debacle I will be moving on from OEM.I contacted Lew and will likely be buying the Alcan leafs. 7-8 week build time currently. Thanks for everyone’s input, advice, and offerings. Still love Toyota even though leafs and dealerships suck.
    doggunner and saybng like this.
  26. Aug 24, 2023 at 6:47 PM
    Eric104
    Eric104 New Member
    Eric
    2018 Crewmax
    My passenger side lead spring is broke on my 18. Thought it was the loose center cap on the rim but just saw the 2nd lead from the bottom hanging off to the side. From reading this thread guess I’ll go with Alcons. I don’t tow or do anything crazy with my truck. Has just over 60k. Crazy.
  27. Aug 25, 2023 at 7:27 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Alcans are the way to go. They tailored my leaf packs for what I do and I also opted for the Timbren springs.
