Help I fear for the worst
Discussion in '2nd Gen Tundras (2007-2013)' started by sgibson513, Sep 16, 2022.
  1. Sep 16, 2022 at 3:38 PM
    sgibson513
    sgibson513 [OP] New Member
    2007 Tundra SR5
    Cold air intake, bed cover, wheel spacers, fever flares
    I have a 2007 Tundra with the 5.7.
    I've had a steady misfire on cylinder 8.
    Here is what I've done:
    Replaced plugs,
    Swapped coils,
    Swapped fuel injectors,
    Replaced pcm,
    Cold compression test was just under 90 for cylinder 8
    I've pulled the valve cover and can see no broken springs or anything out of the ordinary.
    Oil is clean and coolant is clean.
    Wiring to coil and injector looks good as well.
  2. Sep 16, 2022 at 3:41 PM
    Retired...finally
    Did you save or take pictures of the old plugs?
  3. Sep 16, 2022 at 3:46 PM
    sgibson513
    2007 Tundra SR5
    They were all dirty, cylinder 8 had a good bit of oil on it so I did the valve cover gasket as well.
    Here is the only picture I have and can't tell you which cylinder it was
  4. Sep 16, 2022 at 4:23 PM
    FrenchToasty
    FrenchToasty The Desert rat, 6 lug enthusiast
    Mo
    The SoAz….. big surprise
    Bone stock
    Reset the computer? (Pull a battery cable for 20mins)
    alb1k likes this.
  5. Sep 16, 2022 at 4:28 PM
    FrenchToasty
    Mo
    Bone stock
    Also clean your throttle body, I can see it’s dirty from here, and your MAF, with proper cleaners
  6. Sep 16, 2022 at 4:29 PM
    blenton
    blenton New Member
    What is compression in the adjacent cylinder? Head gaskets often leak between two cylinders since that is where the gasket is often smallest and where heat builds up. Hopefully that’s not it, but low compression on two adjacent cylinders can be a clue.
  7. Sep 16, 2022 at 4:40 PM
    sgibson513
    2007 Tundra SR5
    Other cylinders were over 120 each cold
    Computer was reset yesterday when I did the pcm.
    Also I'll give the throttle body some brake clean treatment but would that really ONLY cause a cylinder 8 misfire? If it were random I'd understand.
    I've also checked for vaccine l vacuum leaks and found nothing
  8. Sep 16, 2022 at 4:42 PM
    blenton
    blenton New Member
    90 does sound a little low. 120-150 is usually pretty healthy. Does squiring a little oil in cylinder 8 immediately bump up the compression?
  9. Sep 16, 2022 at 4:45 PM
    sgibson513
    2007 Tundra SR5
    I've got an endoscope on order, I'll try the oil trick in the cylinder tomorrow to see if it is any better.
    Here were some shots from today and I see nothing jumping out at me
  10. Sep 16, 2022 at 4:50 PM
    blenton
    blenton New Member
    I was going to suggest an borescope to take a peek in that cylinder but it looks like you’ve got that covered. Definitely take a look in a few other cylinders to compare.
    Sometimes a leaking fuel injector will wash a cylinder and cause premature wear on the rings or cylinder bore, dropping compression without completing killing the cylinder. Eventually it will over time, but it can show up as lower than normal compression. What does your oil look/smell like, especially at oil change time? A washed cylinder can dilute the oil.
  11. Sep 16, 2022 at 4:53 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Miles on engine?
  12. Sep 16, 2022 at 4:54 PM
    sgibson513
    2007 Tundra SR5
    160,000.
    Did oil last week and it looks and smells like oil right now
  13. Sep 16, 2022 at 6:10 PM
    Retired...finally
    I don't think your missfire is caused by the lower compression rather the other way around.
  14. Sep 16, 2022 at 6:24 PM
    MadMaxCanon
    Were the gaps and electrodes ok on the old plugs? When we look at the cylinder walls in 8 do you see any hot spots? Do you burn oil regularly?
  15. Sep 16, 2022 at 6:30 PM
    sgibson513
    2007 Tundra SR5
    Cylinder 8 looked like the others but with a bit of oil on the ceramic.
    Noticed no oil loss/burning
  16. Sep 16, 2022 at 6:45 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    You said you did the valve cover gaskets, did you do the tube seals as well? Could just be that seal leaking oil and fouling the plug on cylinder 8. And did you look super closely at the valve springs? Could possibly have one look intact but be cracked.
    ColoradoTJ likes this.
  17. Sep 16, 2022 at 7:43 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
  18. Sep 17, 2022 at 5:29 AM
    sgibson513
    2007 Tundra SR5
    I did do the tube seals and yes it is a p0308
    I couldn't find and evidence of a head gasket leak
  19. Sep 17, 2022 at 5:40 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    If I remember correctly it’s either 10% or 20% difference between cylinders. Since you have 120+ on all your other cylinders then the problem is head gasket or mechanical issue on 8. Not really much you can do about except a tear down.
  20. Sep 17, 2022 at 5:43 AM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    Look the cam lobes over on # 8 and make sure it's not short stroking or as stated earlier a spring issue.
  21. Sep 17, 2022 at 5:53 AM
    pursuit2550
    You could also do a leak down test. If it fails a leak down test then start with the head, head gasket and valves.
  22. Sep 17, 2022 at 7:47 AM
    Notarobot
    Notarobot Jagged lines!
    2013 CM
    I agree with this. You can't see the spring in the first picture, but the lobe wear looks inconsistent. In the second picture the spring next to the green dot looks smashed/ out of seat on top.
  23. Sep 17, 2022 at 8:36 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    It does look funky. I see this on die knockout springs all the time. Usually when those first break it will be the first 1/2 to full coil breaking off of one end. The flush-ground end of the spring is supported a good ways around the diameter against whatever it's pushing on, but the free coils beyond it are moving as a spring moves, so that turns into a high stress area of the spring.
  24. Sep 17, 2022 at 10:29 AM
    sgibson513
    2007 Tundra SR5
    Two different angles for that back spring
  25. Sep 17, 2022 at 8:54 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Did the rocker arm contact the retainer? Is that the bright spot?
  26. Sep 18, 2022 at 4:51 PM
    sgibson513
    2007 Tundra SR5
    Some photos from the inside
  27. Sep 18, 2022 at 4:59 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    How does this compare to other cylinders?
  28. Sep 18, 2022 at 5:00 PM
    sgibson513
    2007 Tundra SR5
    This is about the average, cylinder 1 is dirtier. 4 is cleaner.
    Edit:
    I have run Lucas fuel injector cleaner in every tank and I have sea foamed the truck in the past.
    I bought the truck with 145k and am around 160 or so now.
    I feel like the 15k I've owned it this truck has seen more maintenance than the first 140k
  29. Sep 18, 2022 at 5:05 PM
    Notarobot
    2013 CM
    Do a leak down test.
  30. Sep 18, 2022 at 5:14 PM
    blenton
    blenton New Member
    Can you look at the cylinder bore, especially the downhill side of the cylinder (where fuel or coolant would collect if left to sit for a while)? Also, what were the results of the compression test after a squirt of oil in the cylinder?
