Help, I stripped my Bumper bolts and flange nuts
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ketchumj, Apr 25, 2020.
  1. Apr 25, 2020 at 4:32 PM
    Ketchumj
    Ketchumj [OP] New Member
    South Texas
    2020 Tundra SR5 4x4 Double Cab
    2020 Tundra 4x4 SR5 Magnetic Grey – TSS Off Road Toytec Complete performance 3” Lift kit with Aluma Series 2.5 Coilovers, SDP Upper Control Arms, Black Rhino 18” Gauntlet Wheels - +12 Offset, Nitto Terra Grapplers – 295/70R18, Victory 4x4 strike Front Bumper, Fab Fours Premium Rear Bumper, Smittybilt X20 12k Winch
    Greetings,
    I have stripped two bolts and two nuts trying to put on my Victory 4x4 Strike bumper. Unfortunately, my tap set is for SAE, so I wasn't able to fix. I am wondering what I should do to get this thing working. I am not sure if the Bullet coating was too thick and didnt let all the bolts line up properly, but I am at my wit's end.
  2. Apr 25, 2020 at 5:00 PM
    Ketchumj
    South Texas
    Right now, I think I might just get an air chisel and remove the welds from the back side of the mounting plate and replace with some stainless bolts. I hate the idea of taking the bumper off and scraping off the coating at the mounting plate, but I think that might be in order. Funday Sunday!!!!
  3. Apr 26, 2020 at 3:37 PM
    devdomski
    devdomski New Member
    Devin
    South Jersey
    2018 SR5 CM 4x4
    Is it just the vertical nuts and bolts or the bottom where the nuts are in the frame? If its the vertical ones you can just use new nuts and bolts. If its the ones on the bottom you need to try to fix the threads or its going to be a bitch because you can really get in there to put a nut and washer on the inside of the frame.
  4. Apr 26, 2020 at 4:11 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Stainless bolts are weak,
    I’d use Grade 8 ones if you can find them, especially for bumpers
    Good luck Sir
    you might be able to order @Roman for new Toyota OEM ones on Monday...?
    Start a nut bolt collection too
    Sounds crazy but you not left out in the cold
    Mater, CH1NO, EDDO and 3 others like this.
  5. Apr 26, 2020 at 4:38 PM
    Ketchumj
    South Texas
    Got it fixed!
    Part1: Found a tap and die set that had m10x1.25 and rethreaded all the bolts. Couldn't use the wrench, had to use vice grips.
    Part2: I cut off all the bullet lining that would touch the frame. Some was 1/4"! Picture attached.
    Part3: reattach everything. The wife asked me why I didnt test fit it without the winch the first time. I drank another beer.
    Crisis Averted!
  6. Apr 26, 2020 at 4:42 PM
    Ketchumj
    South Texas
    Went to lowes bought a bunch of grade 8 bolts. Couldn't sleep this morning and studied metallurgy.
    reneaux likes this.
  7. Apr 27, 2020 at 6:47 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    You scuffed, primed and spray painted that bare metal right?
  8. Apr 28, 2020 at 4:36 AM
    Ketchumj
    South Texas
    Affirmative
    Luckydog likes this.
  9. Apr 28, 2020 at 5:04 AM
    Crunch527
    Iowa
    Good deal!
  10. Jun 2, 2020 at 5:29 PM
    Yoder18
    Yoder18 Veteran underwater basket weaver
    Mitch
    Front range Colorado
    18 tundra trd off-road
    •Toytec Radflo 3” with 1.5 shackles •+25mm icon rebound wheels matte black. •Prox15 tonneau/Softtopper •315/70r17 ridge grapplers •Wheelers front bumper stops •Spray in bed liner •Vleds floorwell leds front and back and interior led kit •Boss front bumper spacer •First choice fabrication welded sliders •8” ss dirty deeds exhaust •Tech12volts remote start with carlink •Vleds front turn signals leds •AFE pro dry s air filter •Baja xl sport amber fogs •Victory 4x4 strike bumper w hoop •Ajt designs chrome delete for vent rings and cup holder/gear shifter (black) •Wet okole seat covers •Husky floor liners •RCI skid plate and transmission skid •Jomax SpEed sensor guards •Rear diff breather location mod
    Did you have any issues putting in your parking sensors?? Mine won’t fit. The stick bumper hole is roughly 1 15/16” x 1 13/16” and the strike bumper is just a round hole at 1 13/16”. Tried sanding the sensor down on one side but i still couldn’t get it to fit.
  11. Jun 2, 2020 at 6:02 PM
    Ketchumj
    South Texas
    My SR5 did not have parking sensors.
  12. Jun 2, 2020 at 6:10 PM
    Yoder18
    Mitch
    Gotcha thanks for the reply man I appreciate it
  13. Jan 27, 2021 at 12:57 PM
    StaphAttack
    StaphAttack New Member
    What size bolts did you end up going with?
  14. Jan 27, 2021 at 2:09 PM
    thetastelingers
    thetastelingers Master Baiter
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    He re-tapped the holes and used a die to fix the threads on the OEM bolts.
    Ketchumj[OP] likes this.
  15. Jan 27, 2021 at 2:32 PM
    StaphAttack
    Thanks... also found out that 3/8" Grade 8 bolts will replace stock M10 studs
    thetastelingers likes this.
  16. Oct 2, 2022 at 4:56 PM
    Cthulhu
    Hey all, sorry to revive an old thread; I’m trying to keep threads down to minimize search results, and hopefully my mistake will help someone in the future.
    Trying to install a spacer to move the bumper forward to allow for better clearance for my 35’s, and I reckon I over-torqued the nuts, and the studs are stripped to where the nuts won’t fully tighten, but will “tighten enough”, if you catch my meaning. Similar to the pics above, only the stripping goes further down the stud length. For the meantime, I doubled up in front of the factory nuts with grade 8 nylon nuts, but again, they will only snug. I know I won’t be confident in using my winch for now.
    I don’t think I’ll be able to rethread them. I like the idea of replacing with grade 8 bolts, but would like to explore a factory replacement option first. See pic below, that’s the replacement part. I can’t really see well enough to determine how the stud plate is mounted to the frame rail. Can someone please tell me (if easier for you to see or you recall when replacing your front bumper) is the stud plate mounted to the frame rail with other factory nuts/bolts, or, is it welded? Thanks in advance for any potential help!!
  17. Oct 2, 2022 at 5:16 PM
    It is welded. It looks like those studs may be pressed in.
    Cthulhu[QUOTED] likes this.
  18. Oct 2, 2022 at 5:20 PM
    Cthulhu
    Thanks George! Looks like grade 8 bolts it is. I think for the studs there are spot welds, which I’ll probably air-chisel out, or maybe cut the stud back and drill through it and feed the grade 8 bolts through, so I don’t undermine the structural integrity of the stud plate itself.
  19. Oct 2, 2022 at 5:23 PM
    No problem. If they press out and come out somewhat easily, let me know what you replace them with. I am using the CB shims with my aftermarket bumper and it makes the studs fairly short. What part of SC? I'm originally from Myrtle Beach.
  20. Oct 2, 2022 at 5:27 PM
    Cthulhu
    About 30 minutes outside of Charleston. Mentioned in the posts above are the grade 8 bolts I’ll probably use. I intend to get bolts a little longer than the factory studs, to give the nuts a little more “meat” to grab onto. I’ll definitely post up the results.
  21. Oct 2, 2022 at 5:35 PM
    Sounds good. It will give me another project to do lol. Might be a little more challenging than the head unit that I just put in lol. I was just looking online....the studs in the Tacoma are tack welded. I'll look at mine in the morning to see if they are or not. If not they should come out somewhat easily.....hopefully.
  22. Oct 9, 2022 at 11:54 AM
    Cthulhu
    Well I finally had the opportunity to pull the front end apart and see what’s what. They were stripped pretty good, but figured I’d roll the dice with rethreading original M10x1.25, vs. cutting down to M8x1.25 or using new bolts. Even using new bolts, looks pretty difficult as there’s not much clearance to feed a new bolt. Glad I tried rethreading first because it worked, even with my cheapo Pittsburgh tap and die set. Broke the die, took it to HF and got a free replacement. First two pics are stripped condition, second two rethreaded with factory nuts put back on for fit test, final two pics with bumper installed back on. Also pic of front end off. This time when I tightened, since I can’t fit a torque wrench up there, I just got them snug tight, using a new 14mm offset box wrench also from HF which was a HUGE time saver. Took a long time, about 7 hours, but well worth it.
    Tundra234 likes this.
