Help me out 2005 tundra fog light not working
Discussion in '1st Gen Tundras (2000-2006)' started by Jokeywest1128, Aug 2, 2020.
Please help me 2005 fog light not working
Poll closed Aug 3, 2020.
  1. 2005 tundra fog light not working
    4 vote(s)
    57.1%
  2. Help 05 tundra fog light not working
    3 vote(s)
    42.9%
  1. Aug 2, 2020 at 5:02 PM
    Jokeywest1128
    Jokeywest1128 [OP] New Member
    2005 tundra 4 door
    Led headlights. Lasfit switchback fog lights
    Hello I'm new my names Chris. So I have a ? I bought some jdmastar T2 led bulbs for my head lights and lasfit switchback white and yellow fog light bulbs switchback. Each light has resistors built in them. But when I installed my headlights the fog lights wouldn't work only the headlights would work. And the fog light switch would turn on the high and low beams. Also when I installed the factory headlights back on the led fog lights and fog switch will work. But then I put back on the led headlights and the fogs stop working and the fog switch then operates the hi and low beams. Heard this is common for 2005-2006 tundra truck year do you have any ideas how I can fix that?
  2. Aug 2, 2020 at 5:27 PM
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    What's with the survey? Needs an "all of the above" option...:rofl:
    bmf4069 and Black Wolf like this.
  3. Aug 2, 2020 at 5:29 PM
    Jokeywest1128
    2005 tundra 4 door
    What do you mean survey ?
  4. Aug 2, 2020 at 5:30 PM
    Did you disconnect the battery first? Just curious....
  5. Aug 2, 2020 at 5:31 PM
    Dog
    Dog sit!
    Top of your original post when you started this thread - you created it as a Survey (poll) for members to vote on...
    Black Wolf likes this.
  6. Aug 2, 2020 at 5:33 PM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    It was a tough decision but I went with ‘fog light’. :thumbsup:
    bmf4069, revtune and shifty` like this.
  7. Aug 2, 2020 at 5:34 PM
    Jokeywest1128
    2005 tundra 4 door
    Lol sorry guys first time here said I had to fill that out wouldn't let me post my stuff if I didn't do that poll thing. And no I didn't disconnect the battery first. What would disconnecting the battery first do ?
  8. Aug 2, 2020 at 5:40 PM
    Classic response....I rest my case. 99.99999% of electrical issues reported here on this forum is because the battery wasn't disconnected first. Electrical wiring 101. Just sayin and welcome from Colorado.
    Disconnecting the battery "de-energizes" the electrical system in your Tunny. Just because the ignition is off and no key doesn't mean it's ok to work on anything electrical. The most common excuse to not disconnect the battery by far is......... "I'll have to reprogram my radio presets"........
    bmf4069 likes this.
  9. Aug 2, 2020 at 5:50 PM
    Jokeywest1128
    2005 tundra 4 door
    Thank you got it doing it now guys. Thanx
  10. Aug 2, 2020 at 5:57 PM
    Lots of info out there on LED headlights causing fogs to stop working due to non-factory load.
    Basic backwards troubleshooting: Get the cheapest halogens you can find at the store and pop them in. If it fixes the issue, you know it's the bulbs.
    Jokeywest1128[OP] and BestGen like this.
  11. Aug 2, 2020 at 6:01 PM
    Glad you got it working:thumbsup:
  12. Aug 2, 2020 at 6:18 PM
    Jokeywest1128
    2005 tundra 4 door
    Ok disconnected the battery and still didnt work
  13. Aug 2, 2020 at 6:20 PM
    Jokeywest1128
    2005 tundra 4 door
    To shifty well all bulbs work. Its just i think I might need a bigger resistor. When I out the factory lights back on the LASFIT Switchback fog lights work. But when I put the JDMASTAR led headlights on the fog lights wouldn't work and also the fog light switch now operates the high and low beams
  14. Aug 2, 2020 at 6:20 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    You need in line load resistors on your headlights.
    When in the truck, and click the high beams on. Does the blue high beam light on dash come on? If not, then you need resistors.
    2005 trucks still use the H4 bulb?
  15. Aug 2, 2020 at 6:24 PM
    What he said ^^
  16. Aug 2, 2020 at 6:33 PM
    Jokeywest1128
    2005 tundra 4 door
    They still are H4 bulbs. And each light has its own resistor. But maybe need a bigger one. When I put the high beams on the blue light indicator is not on the dash board
    Tundra2 likes this.
  17. Aug 2, 2020 at 6:51 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @Jokeywest1128
    I tried plug, and play in line resistors from super bright leds.com.
    Install day came around, and everything was going peachy until I tried to plug in the actual light plug to the resistor. The female plug on the resistors were junk. I cut those off, and soldered on ceramic females. Been running those for years now.
    Something like this should do your fancy.
    https://www.amazon.com/dp/B07QTXQ931/ref=cm_sw_r_cp_apa_i_a02jFbT8XBVDQ
    Decent reviews on the product also. I mounted the actual resistor box to the wall of the engine bay some where around the lights. I used jb weld steelstik because I didn't want to drill holes if I could help it. If I need to pop them off I can do that easily with a flat blade screwdriver, and a hammer..
    From your avatar it looks like you have a double cab? If so, I don't know anything about the day running lights in the inside corner of your headlights.
    Jokeywest1128[OP] likes this.
  18. Aug 2, 2020 at 7:12 PM
    Jokeywest1128
    2005 tundra 4 door
    This is what I bought guys. And like I said each light has its own resistor
  19. Aug 2, 2020 at 7:19 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'm not familiar with either of those. Not saying its a bad thing. I just haven't looked for headlight/foglights in a few years.
    My fogs do not have resistors in line. Work just fine. Give me a minute, and I'll go out and take a reading from my resistors so you know how much resistance you need.
    Are you familiar with multi-meters?
  20. Aug 2, 2020 at 7:21 PM
    Looks like Amazon purchase. I'd be sending it back. @Professional Hand Model swears by the Katanas on Amazon. I don't think he needed anything special to make it work, but I may be wrong.
    Unfortunate thing about amazon is like 60% of sellers are unregulated or poorly regulated shops in Asia, so you never truly know what you're getting. Sometimes you'll hit on one that's putting out quality product but in my experience, it's a 1-in-4 crapshoot.
    I don't even want to get started on my experience buying a grease gun back in 2018. Like, seriously, in the US we'd been making quality grease guns that never failed, still working after decades. You won't find a hand-pump physically made and assembled in the USA on there for under $100, and everything else lasts for under 100hrs.
    Such is the world we've allowed ourselves to be bullied into though...
  21. Aug 2, 2020 at 7:25 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    bmf4069 likes this.
  22. Aug 2, 2020 at 7:45 PM
    Jokeywest1128
    2005 tundra 4 door
  23. Aug 2, 2020 at 7:50 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I guarantee you that he changed his light exposure on his camera when he recorded the halogen bulbs.
    Halogens are dim, but not that dim.
    The resistors he showed in the video are the same exact ones, from the same exact vendor I have, and told you about earlier.
  24. Aug 2, 2020 at 9:13 PM
    Dog
    Dog sit!
    I suspect I am looking at a different set of headlights in that picture...:thumbsup:
  25. Aug 2, 2020 at 9:15 PM
    Jokeywest1128
    2005 tundra 4 door
    Thanx guys I'll keep you guys updated on what happens stiff comes in August 9th
    Tundra2 likes this.
  26. Aug 2, 2020 at 9:16 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  27. Aug 2, 2020 at 9:17 PM
    Jokeywest1128
    2005 tundra 4 door
    @Tundra2 did they correct the problem for you ?
    Tundra2 likes this.
  28. Aug 2, 2020 at 9:19 PM
    Jokeywest1128
    2005 tundra 4 door
    I bought these because I saw reviews on that one that ppl said he had the wrong one the one he had was for a motorcycle. So I bought these for H4 hope they work
    Tundra2 likes this.
  29. Aug 2, 2020 at 9:25 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yes. Sure did.
    Like I said in post #17 the female side of the resistors were poorly made. I cut those off, and soldered on ceramic connectors. Here are some pictures for you.
    Drivers side resistor box by the battery.
    The soldering job, and heat shrink.
    Ceramic plug.
    Passnegers side.
  30. Aug 2, 2020 at 9:26 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    You've mentioned a few times that your lights have built in resistors in them. The JDM Astar and Lasfit lights you showed pictures of do not have built in resistors. If you mean the rectangular boxes that are part of the wiring of those lights, those are LED drivers, not resistors. The load resistor kit you purchased above will fix your headlight problem but your LED fog lights may also need resistors added for them to work properly.
    Edited to mention that adding the second headlight resistor took care of my LED foglights not working.
