HELP PLEASE! Tire size for 20x9 +12 offset
Discussion in 'Wheels & Tires' started by Coz2122, Nov 12, 2019.
  1. Nov 12, 2019 at 7:08 PM
    Coz2122
    Coz2122 [OP] New Member
    2019 SR5 Crew Max
    6112/5100 1.5” rear shackles
    I just bought a 2019 SR5 CM. I bought the boss 4x4 kit for it which includes 6112 in the front and 5100 with 1.5” shackles in the rear. I’m having a hell of a time figuring out what tires will fit without major fab work. I purchased the Vision Rockers 20x9 +12 offset. I’m losing hair over this and some insight would be great. I’d like to keep the cuts down to an absolute minimum. Do I do 275/65/20 285/65/20 or 295/60/20?! Thanks to all who respond
  2. Nov 12, 2019 at 7:10 PM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    275/65-20's would look good. That's a 34" tire and would most likely eliminate having to BMC to get a 35 on there.
    Coz2122[OP] likes this.
  3. Nov 12, 2019 at 7:15 PM
    Mike19
    Mike19 New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    +1
    I put them on my OEM 20” and it rubs on the front sway bar at full lock. having a +12 should be no problem.
  4. Nov 12, 2019 at 7:18 PM
    Coz2122
    2019 SR5 Crew Max
    That’s what I was thinking and they are significantly cheaper. I’m just worried that the tires will be too skinny for the wider stance.
  5. Nov 12, 2019 at 7:51 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I run 275/65/20 on mine.
    I had to remove the mud flaps and the aero dam off of the front.
    The tires look a tad short with 2” in the front and 1.5 in the rear. But, overall I’m happy with it.
    This one was before I added the shackles in the rear.
  6. Nov 12, 2019 at 7:57 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I run 275/70/18 with +18 and I don’t rub. At +6 I was rubbing big time. You will probably need to fab the front plastic a bit at +12 with 275/65/20 but I don’t think you’ll rub all that bad.
  7. Nov 12, 2019 at 8:00 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    These are getting mounted on Thursday. The all black is getting tired IMO so I like your color choice.
  8. Nov 12, 2019 at 8:05 PM
    Coz2122
    2019 SR5 Crew Max
    Scuba.. I’ll have a 3/1.5 when I ya all said and done. Do you have a front shot? I’m wondering if they will be too skinny?? Baker.. I picked the grey because it’s different. Everyone is running black outs now and I’ve seen the grey on the magnetic grey. I love the look just trying to figure out this tire situation before I lose my hair over it. Im digging those fuels for sure
  9. Nov 12, 2019 at 8:15 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    :popcorn:
    Pinay likes this.
  10. Nov 12, 2019 at 8:16 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    I’ll get you a picture come morning time.
    Coz2122[QUOTED][OP] likes this.
  11. Nov 12, 2019 at 8:17 PM
    saybng
    Gary
    Ventura CA
    IMHO I would go 295•60•20.. i currently have 275•65•20 on my Method NV and might go that route or 35's..
    Coz2122[OP] and Pinay like this.
  12. Nov 13, 2019 at 4:22 AM
    Coz2122
    2019 SR5 Crew Max
    Thanks scuba. What’s an aero dam?? And Say... I’d love to run them but i don’t want to do any BMC. I’d be afraid that i might with that size but I can’t find any pictures for visual reference. I’ve spoke with someone who said they bought 285/65/20 and have a +12 but he hasn’t installed yet and won’t until the end of the month. I was hoping he would be my guinea pig lol
  13. Nov 13, 2019 at 9:59 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    The aero damn is attached to the bottom of the front bumper.
    It is there to move air around the tires.
    I didn't have to do a BMC with the 275/65/20 but I can imagine it may be necessary once you go with a wider tire. You can fit a 315 wide tire with a +25mm offset on an 8.5 wide wheel. Sometimes it all comes down to offset.
    A shop may allow you to test fit the 285/65/20 before purchasing.
    I would actually prefer that size but I'm pretty far away from needing new tires. I will say that in my experience the 285/65/20 is about $100 more expensive compared to the 275/65/20.
    saybng likes this.
