Help Please TRD Skid Plate Bolts
Discussion in '3rd Gen Tundras (2022+)' started by Buellride, Mar 18, 2022.
  1. Mar 18, 2022 at 4:40 PM
    Buellride
    Buellride [OP] New Member
    Olympia
    THE BOULDER
    BD Lights, Banks PM, Fuel Vector 18" on 295/70R18 Cooper AT3 XLTs, Black-Out badges, TRD front grill
    My TRD skid plate arrived from Ebay today and of course it didn't come with bolts. I know you reuse the 2 front and middle bolts that come on "piece of paper" Toyota calls the skid panel on non-TRD trucks but what size are the bolts for the remaining 2 rear bolts?
    The Toyota parts number is "out of stock" everywhere.....so I was hoping to get something that is an aftermarket match
  2. Mar 18, 2022 at 4:47 PM
    Osiris
    Osiris New Member
    20 Plat
    They call it ballistic nylon, not paper. It doesn't permanently dent like the TRD aluminum plates that take one hit before being useless. If you want more durability, get a steel plate.
    Use McMasterCarr or local HD/Lowes for bolts.
  3. Mar 18, 2022 at 4:53 PM
    Buellride
    Olympia
    THE BOULDER
    Yeah I kidding with the "paper" comment....I am not going to be taking the truck hard core rock crawling so the aluminum TRD plate is fine. Are the bolts the same all the way around? So I can get like thread/thickness bolts at HD?
  4. Mar 18, 2022 at 6:31 PM
    AustinTexas
    AustinTexas New Member
    Anyone know if the skid plate helps protects the catalytic converter from easy access for thieves?
  5. Mar 18, 2022 at 7:18 PM
    EvilSteve
    EvilSteve New Member
    2022 Lunar Rock Tundra Limited
    Here’s the part I ordered for the bolts.
  6. Mar 18, 2022 at 7:35 PM
    Buellride
    Olympia
    THE BOULDER
    Yup and nobody seems to be able to order them currently
  7. Mar 18, 2022 at 7:47 PM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Where are you located? I ordered too much and have like 6 extra bolts lol
  8. Mar 18, 2022 at 7:56 PM
    Buellride
    Olympia
    THE BOULDER
    Washington state.
  9. Mar 18, 2022 at 9:14 PM
    EvilSteve
    I’m in Utah, went to the parts department at Karl Malone Toyota, they ordered them, they came in like a week later. ¯\_(ツ)_/¯
    NewImprovedRon likes this.
  10. Mar 18, 2022 at 9:28 PM
    Osiris
    Osiris New Member
    20 Plat
    No. There's a dealer on the forums selling a steel plate that does though. Might ask CBI or C4Fabs if they're going to offer one.
    You can get an M8 1.25pitch bolt & washer from anywhere and it will fit. Just make sure it's stainless steel to prevent rust. Also use anti-sieze.
    Guide: http://toyotaparts.sparkstoyota.com/install/PTR60-34220inst.pdf
    1lowlife likes this.
  11. Mar 18, 2022 at 9:47 PM
    Buellride
    Olympia
    THE BOULDER
    This is SUPER helpful!! Thank you VERY VERY MUCH!!!
  12. Mar 18, 2022 at 9:49 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    May not be helpful, but enjoyed seeing the dog in the passenger's seat..:D
    Helluvalot easier than installing my TRD Pro skidplate on my 2014..:eek2:
    https://youtu.be/BME8iJZQ1uo
    Osiris likes this.
  13. Mar 18, 2022 at 9:58 PM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Nope…need extra stuff for that
    https://valhallasshields.com/shop/ols/products
    (This vendor is a regular on the board)
    Taco Tunes…website and YouTube video
    CBI off-road
    Couple other around…
    ChucklesToy likes this.
  14. Mar 19, 2022 at 2:23 PM
    Buellride
    Olympia
    THE BOULDER
    Thanks to everyone that offered suggestions and advice! Skid Plate installed!
    ChucklesToy and EvilSteve like this.
  15. Mar 19, 2022 at 2:28 PM
    Jlin
    Jlin New Member
    Joe
    22 Platinum CMLB
    I have the Taco Tunes cat plate and the TRD Skid plate. This is what it will look like if you get a cat plate.20220311_063110.jpg
  16. Mar 19, 2022 at 2:30 PM
    Buellride
    Olympia
    THE BOULDER
    Nice!
    Jlin[QUOTED] likes this.
  17. Mar 19, 2022 at 2:40 PM
    ThePolak
    ThePolak 2022 Platinum hunt/tow/haul/family ride on order!
    The Land of the Cobra Chicken
    Nice setup! Is there any way to access the oil filter or drain plug with the skid plate on?
  18. Mar 19, 2022 at 2:44 PM
    Jlin
    Jlin New Member
    Joe
    22 Platinum CMLB
    Unfortunately there's no way to access the filter or drain plug. I will have to remove the skid plate every oil change. I was thinking about making a cut out for the filter and drain plug but I haven't had the time to put the truck on a lift and figure it out.
    ThePolak[QUOTED] likes this.
  19. Mar 19, 2022 at 2:46 PM
    ThePolak
    Thanks for letting me know. Looks like a great skid. I was the drain plug access might be solved with a Fumoto valve and hose that you tuck away if you can get to the level for the valve, but if you have to remove it to get access to the filter, might as well just leave the drain plug as is.
  20. Mar 19, 2022 at 2:51 PM
    Jlin
    Jlin New Member
    Joe
    22 Platinum CMLB
    No problem and thanks.
    I read about the Fumoto valve but I don't feel comfortable having a valve as a drain plug that's why I thought about the cut out for the filter and plug. Hopefully I get some time to figure it out soon.
  21. Mar 19, 2022 at 3:06 PM
    ThePolak
    Does the drain nut face down or to the back/front/side? If it faces down, as simple hole the size of a socket should suffice. Probably a hole saw with some cutting oil should do the trick nicely with a few strokes of a file.
    For the filter, you could just cut the hole to an appropriate size using a jig saw and then make a cover using some aluminum flat stock and some rivet nuts with stainless hardware. I'm thinking with a rectangular/square hole, 4 rivet nuts on each corner and a piece of flat aluminum screwed into the nuts with an overlap of ¼ all around should work nicely. Overlapping should help with any impacts in that location.
    Another thought with this setup is that instead of the 4 bolts in rivet nuts, is that you only place 3 bolts: 2 rivet nuts with the appropriate stainless hardware and one through-bolted bolt. This through-bolt would act as a pivot point, so that when you unscrew the other two bolts, you can just swivel this out of the way, instead of taking it off completely. Less things to lose lol.
    You could also do it flush to maintain the look but using the piece you cut out for the oil filter. Cut out a small rectangular piece of aluminum flat and solid rivet in the back of the plate so that it encroaches the oil filter opening by ¼ to 3/8' or whatever amount of material you need to place some rivet nuts. Again, 4 rivet nuts, one in each corner, and secure using pan head stainless bolts. Now the piece you cut out can rest flush with the rest of the skid for a more cleaner appearance.
  22. Mar 19, 2022 at 3:10 PM
    Jlin
    Jlin New Member
    Joe
    22 Platinum CMLB
    Thanks for the input. That sounds like a good idea. I'll try that whenever I get the time to put my truck on a lift at work.
  23. Mar 19, 2022 at 3:11 PM
    ThePolak
    Just edited it with another way you could do the bolt set up:
    "Another thought with this setup is that instead of the 4 bolts in rivet nuts, is that you only place 3 bolts: 2 rivet nuts with the appropriate stainless hardware and one through-bolted bolt. This through-bolt would act as a pivot point, so that when you unscrew the other two bolts, you can just swivel this out of the way, instead of taking it off completely. Less things to lose lol."
  24. Mar 19, 2022 at 3:16 PM
    Jlin
    Jlin New Member
    Joe
    22 Platinum CMLB
    That should work better and easier. Thanks.
  25. Mar 20, 2022 at 4:54 AM
    extremes074
    extremes074 New Member
    David
    West Coast, Florida
    22 1794 TRD Off-Road
    Sure you even need the bolts? I ordered the TRD running boards and the hardware and when I went under the truck to install noticed the hardware was already present and just needed to be unscrewed.
  26. Mar 20, 2022 at 8:02 AM
    paradizecityz
    Richmond, TX
    This one is a little different, with the current skid plate, you can re-use the bolts but that's only 4, you still need an additional 2
  27. Mar 20, 2022 at 8:17 AM
    Buellride
    Olympia
    THE BOULDER
    I noticed the same thing when I installed my running boards...I was thinking that I could use 1 bolt from each side for installing the skid plate. Honestly I decided to just purchase M8 1.25 x 30mm stainless bolts from Lowe's instead. I may reconsider in the future to use the side "extra" bolts but for now Lowe's bolts were on the 2 middle bolt holes of the plate. OEM bolts on the outside locations.
  28. Mar 20, 2022 at 9:40 AM
    ThePolak
    If this is in regard to my earlier posts, the bolts I was referring to creating a cover on the existing skid plate so that you could access the oil filter easily. I think for attaching it to the vehicle you could just use the existing bolts from the ballistic nylon “shield”.
  29. Mar 20, 2022 at 8:25 PM
    SDT
    SDT New Member
    B
    2022 Limited Tundra Mesquite
    TRD running boards/skid plate
    I also have extra skid plate bolts for whoever needs them. I'll send them free in the US. Just PM. (You'll need 2 beyond what's already installed on your truck.)
    As for the running boards, yes the bolts are already installed and came with your Truck,.
  30. Jun 23, 2022 at 8:51 PM
    paradizecityz
    Richmond, TX
    Where you located?
