Help regarding offset
Discussion in 'Wheels & Tires' started by EagleClaw972, Jan 27, 2022.
  1. Jan 27, 2022 at 4:43 PM
    EagleClaw972
    EagleClaw972 [OP] New Member
    2008 Tundra Crewmax
    Straight Pipe, A/T on stock 20s, towing mirrors, kickers pro comp subs and amp
    Does anyone know the offset on these wheels?
  2. Jan 27, 2022 at 4:46 PM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    These are the TSS rims. I believe they are +50 offset. Not much different than factory which are +60
    EagleClaw972[OP] likes this.
  3. Jan 27, 2022 at 4:50 PM
    BlueTSS
    BlueTSS New Member
    TX
    2014 Blue Tundra TSS
    Exterior - ReadyLift 4” SST Lift - BFG KO2 285/65/R20 - GST black wheels (2021 TSS) - MGP red caliper covers - TRD exhaust with black tips - TRD rear sway bar - Toyota blackout emblem overlays - Toyota bed rail system - Toyota bed light kit - AlphaRex headlights - AlphaRex style taillights - OEM LED fogs - OEM honeycomb grill - VLEDS Interior - Katzkin black leather seats - TRD black shift knob - Toyota all weather floor liners - SET wireless charger - Taco Tunes starter system - JL Audio 10TW3 - 3M 35% front tint - VLEDS
    Actually those are Texas Edition wheels, similar to TSS. 20x9, +50mm.
  4. Jan 27, 2022 at 5:15 PM
    EagleClaw972
    2008 Tundra Crewmax
    Thanks y’all. One more Lol Are these 60+ offset? If so Ill go get the Texas Edition. Can’t stand how far in these sit.
  5. Jan 27, 2022 at 5:15 PM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Yup. +60. But the Texas edition will not sit out much further. Less than half an inch.
  6. Jan 27, 2022 at 5:16 PM
    BlueTSS
    BlueTSS New Member
    TX
    Also I believe those are 20x8, an inch less wide. So the Texas edition would be roughly 22mm farther out than these. (0.5 inches out because of the width of the wheel + 10mm out because of the offset).
  7. Jan 27, 2022 at 5:20 PM
    EagleClaw972
    2008 Tundra Crewmax
    Awesome. I can gain an 1” from the wheel width and I guess +10 from the offset. So it shouldddd sit out a bit more.
  8. Jan 27, 2022 at 6:17 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Just an FYI before you spend the money on those wheels. You won’t get more poke from a wider wheel. You only gain poke from a wider tire and the offset. If you put a 295 wide tire on a 9” wheel or an 8” wheel with the same offset, they’ll both poke out exactly the same.
  9. Mar 2, 2022 at 9:25 PM
    EagleClaw972
    2008 Tundra Crewmax
    So I can keep my 20” stock wheels and put a wider tire and that’ll give me some poke?
    joonbug[QUOTED] likes this.
  10. Mar 2, 2022 at 9:30 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Not quite, the offset is based on the center of the wheel - the mounting surface centered is 0mm. A wider wheel at 0mm pokes more than a narrower wheel at 0mm.
  11. Mar 2, 2022 at 9:50 PM
    alb1k
    Left Coast
    It's good
    I should add, 0 offset on different widths is obvious. But just -15mm offset on 7.5 vs. 8.5 is only .2 inches further out. The wider the wheel the less the same positive or negative offset is an impact. The wheel width takes over for the most part.
    7.5 to 8.5 width increases poke by .5 inches in comparison at 0mm
  12. Mar 2, 2022 at 10:16 PM
    alb1k
    Left Coast
    It's good
  13. Mar 3, 2022 at 8:38 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Haha. Wrong. Yes, the wheel pokes out more, but if your tire is wider than the wheel, the tire determines the poke and not the wheel. If you have a 12.5” wide tire on a 0 offset, the poke will be the same whether you have a 10” wide wheel or a 9” wide wheel. It’s counter intuitive but that’s how it works. Read this thread. https://www.tundras.com/posts/189124
    It will help you understand. There’s a slight difference because of the curvature of the tire on different width wheels but that’s negligible.
  14. Mar 3, 2022 at 8:48 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Yes, but very little. Whatever increase in tire width will equate to half of that increase in poke. Usually takes a good inch or more in poke to notice a good difference. Usually adding 2” or more of tire width will exceed the max tire width for the wheel.
  15. Mar 3, 2022 at 8:50 AM
    alb1k
    Left Coast
    It's good
    Sorry, I was only talking about the wheel.
  16. Mar 3, 2022 at 8:59 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Yes, so it does affect poke visually, but only if your set up looks like this. :D
    alb1k[QUOTED] likes this.
  17. Mar 8, 2022 at 7:40 PM
    EagleClaw972
    2008 Tundra Crewmax
    Thanks for all the info ... I guess Ill keep the wheels I have and change the A/Ts for a wider Highway tire. Now the question is what size tire Hate how rough it rides
