HELP!!! TRUCK Won't start!!!
Discussion in '1st Gen Tundras (2000-2006)' started by lyteflyer, Feb 15, 2022.
  1. Feb 15, 2022 at 12:03 PM
    lyteflyer
    lyteflyer [OP] New Member
    larry
    2000 tundra 4.7l v8
    none
    My 2000 Tundra usually runs like a top with no issues. Two days ago, as I was pulling out of a parking lot, a guy cut me off requiring me to hit the brakes HARD. My engine died and would not restart. Had it loaded on a truck and brought home. After they unloaded the truck, I hit the starter and it started right up. Drove around the block with no problems, but coming to a stop in the driveway I braked hard and IT DIED AGAIN! Now it won't start! ANY ideas what is wrong? Yes the STARTER works, But the ENGINE won't start.
  2. Feb 15, 2022 at 12:22 PM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Sounds like you might have a wire loose. Slam on brakes and it loses connection.
    Just an uneducated guess.
    KK6PD, N84434, 5N0W808 and 2 others like this.
  3. Feb 15, 2022 at 1:44 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    You could start with checking battery cables?
    By don't start, do you mean it just clicks when turning the key? Or Is it cranking but not turning over?
    Aerindel likes this.
  4. Feb 15, 2022 at 2:46 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    check for loose battery connections, check for loose ground wire. Likely one of those based on what you describe.
  5. Feb 15, 2022 at 3:27 PM
    Sounds like an obvious case of loose/shorted cable to me, the inertia of braking is highlighting it.
  6. Feb 15, 2022 at 3:42 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    This ^^ right here.
  7. Feb 15, 2022 at 3:49 PM
    Aerindel
    Aerindel New Member
    Montana
    Need to know what you mean by won't start.
    Won't turn over? Won't run?
    Like others have said, if it won't turn over, probably loose battery terminals/wires.
    If it turns over but won't start, could be a variety of things...loose ECU wires of some kind, bad fuel pump, have to start testing things.
    joseph_womack likes this.
  8. Feb 15, 2022 at 4:07 PM
    So if you get into an accident, the truck will kill the ignition to prevent a runaway engine scenario (foot pinned on the gas pedal, fuel leak etc.) Maybe the system is interpreting the hard stop as an accident like situation. Not sure if the deceleration sensors are responsible for this? My truck engine died when I backed into a retaining wall at high speed sliding on the ice. I had to turn the truck all the way off and then turn it back on to get it to start. My thoughts.
  9. Feb 15, 2022 at 5:29 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Holy crap. Today I learned. Had NO IDEA that trucks (and cars too I would assume) had that feature. Anyone know how far back this feature goes? I've hit some crap pretty hard in my 1997 T100 and don't ever recall the engine immediately dying. But I absolutely love the premise of the feature.
    As they say on that thing called the internet: thanks for sharing.
    joseph_womack and bmf4069 like this.
  10. Feb 15, 2022 at 5:47 PM
    Aerindel
    Aerindel New Member
    Montana
    I've never heard of it before. I'd really like to see a link or something to it before I take it as gospel on OUR trucks.
  11. Feb 15, 2022 at 5:54 PM
    So it’s a fuel shutoff, not an ignition kill, info from several different Toyota owners manuals (Tundra, Camry, etc.)
    'Fuel pump shut off system
    To minimize the risk of fuel leakage when the engine stalls or
    when an airbag inflates upon collision, the fuel pump shut off
    system stops supply of fuel to the engine.
    Follow the procedure below to restart the engine after the system is
    activated.
    Turn the engine switch to the “ACC” or “LOCK” position.
    Restart the engine.'
    KK6PD, joseph_womack and w666 like this.
  12. Feb 15, 2022 at 5:57 PM
    the “incident” I described occurred in my 2000 Tundra. Same model as yours, except mine is the limited TRD OR trim. So it applies to “our trucks”.
  13. Feb 15, 2022 at 7:30 PM
    Pretty sure the deceleration sensor is under the center console area (between the seatbelt bolts-ish) on our trucks IIRC. A lot of guys with VSC enabled trucks seem to post around looking for this bastard, someone was just looking recently?
  14. Feb 15, 2022 at 7:31 PM
    Aerindel
    Aerindel New Member
    Montana
    I know about airbag deployment killing it, thats pretty standard, I've just never heard of anything else shutting off the engine. I wonder if what really happened is it just stalled the engine when you backed into the wall.
  15. Feb 15, 2022 at 7:33 PM
    It wouldn’t restart without turning it all the way off and then back on. The fuel cutoff is an inertia switch. May be located here, if you believe everything you read on the Internet.
  16. Feb 15, 2022 at 10:35 PM
    Aerindel
    Aerindel New Member
    Montana
    Cool. Good to know.
  17. Feb 16, 2022 at 3:59 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Ford, back in the Crown Vic days, used a lil black box with a white button on it in the trunk. If you bumped the car hard enough it would trip and interrupt the fuel pump circuit. You had to pop the trunk and push the white button to reset it.
    Road criminals learned to back into the police cruisers to trip the fuel pump interrupter and speed off into the sunset.
  18. Feb 16, 2022 at 4:04 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yup. My taurii do the same thing. If you bonk the passenger rear too hard it'll trip it.
    joseph_womack and Sirfive like this.
  19. Feb 16, 2022 at 5:08 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    For whatever reason, I had downloaded all 1st Gen OM's sometime in the past. According to each of those OM"s, they started in 2003 and forward, listing it as an item, FWIW.
    from my 2004 OM....
  20. Feb 16, 2022 at 6:06 AM
    My 2000 definitely has it. It’s been field tested.
  21. Feb 16, 2022 at 6:26 AM
    des2mtn
    des2mtn On the scenery looking at the road
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    This is interesting. I had a scenario where the truck shut off on me, but started right back up just fine. It happened when I was doing an uphill obstacle at a steep angle, spinning the tires and on the throttle a bit. Computer could have interpreted it as a throttle pinned situation. I could not find anything wrong with the truck that would of caused it and I figured it might be something to do with a safety system. Haven't been able to replicate it since. Truck had plenty of fuel when it happened.
  22. Feb 16, 2022 at 6:28 AM
    Don’t think having the throttle pinned will do it. It’s an inertia switch. Triggers with an abrupt and sudden stop, like collisions. Shouldn't activate with the brakes or inclines or any of that unless the switch is faulty or worn out.
    joseph_womack and des2mtn like this.
  23. Feb 16, 2022 at 10:35 AM
    joseph_womack
    Joe
    Louisiana
  24. Feb 16, 2022 at 11:26 AM
    Aerindel
    Aerindel New Member
    Montana
    Literally just woke up from having nightmares all night about this switch. After my coffee, I'm going on a search and destroy mission.
  25. Feb 16, 2022 at 11:34 AM
    If you’re lucky you’ll never need to mess with it. Mine did it’s job, and sent me on my way after. Haven’t needed to see it or mess with it at all
  26. Feb 16, 2022 at 6:32 PM
    Aerindel
    Aerindel New Member
    Montana
    I'm not usually lucky.......
    shifty` likes this.
  27. Feb 19, 2022 at 2:11 PM
    lyteflyer
    larry
    2000 tundra 4.7l v8
    none
    Truck is fixed. But I would like to say that if I had been given accurate data It would not have taken me a week to run it down. THE FUEL PUMP CIRCUIT is NOT energized when the ignition is turned on. It is energized when the STARTER is engaged. If the engine starts it continues to pump. If NOT the power to the pump is SHUT OFF.
    My problem turned out to be the connector INSIDE the tank had come loose, and was making intermittent contact. Upon hard braking the fuel sloshed up and disconnected the connector. To make matters worse, when I pulled the pump out and bench tested the unit it ran fine because the connector was not fully unplugged.
    So I put it back together and spent three days trying to figure out why the pump circuit was dead.
    Only by accident ( I left a circuit tester attached to the pump wire and engaged the starter) did I learn how it works.
    So if you have a 2000 tundra DON'T listen for the pump when the key is on and the engine is not running.
  28. Feb 20, 2022 at 6:17 AM
    glad you got it sorted. Where did you get inaccurate data? Yours sounds like it was a unique problem, not a common part failure. Loose wire in an inaccessible and non-visible spot is a tough find.
  29. Feb 20, 2022 at 9:17 AM
    lyteflyer
    larry
    2000 tundra 4.7l v8
    none
    The inaccurate date i got was I was told that the fuel pump circuit energized when you turn on the key. Since MINE doesn't energize until you engage the starter it sent me looking for why the circuit was dead. I thought my ECM was bad.
  30. Feb 20, 2022 at 2:15 PM
    Aerindel
    Aerindel New Member
    Montana
    Yah, I could have told you that. Its the reason our trucks take a second longer to start than some some others. Thats a frustrating failure to be sure, loose but not totally broken connectors are a nightmare.
