Help with backlight for a switch
Discussion in '3rd Gen Tundras (2022+)' started by Woocawachie, Sep 27, 2023.
  1. Sep 27, 2023 at 2:47 PM
    Woocawachie
    Woocawachie [OP] New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    (SOLVED)!
    anyone can recommend where to tap into to get my aftermarket switch backlight to come on and off along with the other switches. Currently using eBay aftermarket for fog lights and the backlight of the LED switch always stays on, no matter what. The market switch is circle in red
  2. Sep 27, 2023 at 2:58 PM
    AZBoatHauler
    So.Arizona
    If the light is on all the time it’s wired incorrectly.
    You can test the 4 wires going to one of the switches on the row above - the one that has 0v until the headlights turn on is the wire you want to tap for illumination on the new switch.
    Hella Krusty and Woocawachie[OP] like this.
  3. Sep 27, 2023 at 3:00 PM
    AZBoatHauler
    So.Arizona
    WTF is that?
    1lowlife and Hella Krusty like this.
  4. Sep 27, 2023 at 3:05 PM
    Dtrancrx
    Dtrancrx New Member
    Auto start and stop disablling device
  5. Sep 27, 2023 at 3:06 PM
    Dtrancrx
    Dtrancrx New Member
    Test one of the tan brownish wire
  6. Sep 27, 2023 at 3:42 PM
    chance12
    chance12 New Member
    GA
    23 Tundra CM Limited
    It has been several months since I've wired mine up. But if I remember correctly, I think that is the same one I tapped into. And my backlight works as it should
  7. Sep 27, 2023 at 3:46 PM
    Woocawachie
    Dickens
    Philadelphia
    Thank you for instructions. Didn’t think of that
  8. Sep 27, 2023 at 3:47 PM
    Woocawachie
    Dickens
    Philadelphia
    Will try it tomorrow and see how it works. Thanks
    chance12[QUOTED] likes this.
  9. Sep 27, 2023 at 4:11 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    The tan wire is backlight but won't dim with the other switches
  10. Sep 27, 2023 at 6:36 PM
    Woocawachie
    Dickens
    Philadelphia
    What do you mean? If I tap one of the tan wires to the spare wire hanging off my aftermarket switch it won’t work? It will still stay on?
  11. Sep 27, 2023 at 7:03 PM
    eddiefromcali
    Eddie
    100% Stock
    It'll work...its going to illuminate but won't dim
  12. Sep 27, 2023 at 7:12 PM
    Woocawachie
    Dickens
    Philadelphia
    It’s already illuminated, all the time. That’s the problem. I’m trying to get it to dim. Or completely disable the backlight somehow
  13. Sep 27, 2023 at 8:11 PM
    eddiefromcali
    Eddie
    100% Stock
    If its always lit, then it's not wired correctly
    Hella Krusty likes this.
  14. Sep 27, 2023 at 9:04 PM
    chance12
    chance12 New Member
    GA
    @eddiefromcali is correct. it should cut on and off with the rest of your dash lights, but it will not be able to dim
  15. Sep 27, 2023 at 10:15 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    These are your illumination leads to your dash switches.
    I have no idea if your aftermarket switch will dim or be on and off with the dash lights.
    upload_2023-9-28_0-13-9.pngupload_2023-9-28_0-13-48.pngupload_2023-9-28_0-14-25.pngupload_2023-9-28_0-14-56.png
    Woocawachie[OP] likes this.
  16. Sep 28, 2023 at 3:37 AM
    Woocawachie
    Dickens
    Philadelphia
    In that case I’ll try the lazy man way and see if I can take the switch button itself apart and kill the LED
  17. Sep 28, 2023 at 3:37 AM
    Woocawachie
    Dickens
    Philadelphia
    Helpful. Thank you
    1lowlife[QUOTED] likes this.
  18. Sep 28, 2023 at 4:31 AM
    Hunter1699
    Hunter1699 New Member
    Here is what I did the other day for Cali Switch and Lasfit Ditch Lights if it helps:
    So referencing the Ditch Lights wiring questions that I had (above)I finally figured it out this morning:
    I have Lasfit ditch lights and their harness-color schemes on other lights are different color code but should be able to adapt from the below
    Cali Switch wires/Lasfit Harness wires
    Red / Yellow
    White / Black
    Black / Black
    Green / Red (fused)
    Yellow / Tan wire from unused harness
    The Cali Raised switch diagram on their site is incorrect as someone earlier had reported.
    Works great and hope it helps someone else.
  19. Sep 28, 2023 at 5:48 AM
    Woocawachie
    Dickens
    Philadelphia
    My switch is a little different. It just has 4 wires that go directly to a relay switch. Then the switch has 2 pairs of wires going to the fog lights. And one wire to the battery. You had a switch and harness to try to match the correct wires.
    eddiefromcali likes this.
  20. Sep 28, 2023 at 6:26 AM
    eddiefromcali
    Eddie
    100% Stock
    One of those Reds is likely the backlight. Blue js usually your remote turn on.
  21. Sep 28, 2023 at 7:03 AM
    Woocawachie
    Dickens
    Philadelphia
    You sir are a scholar and a genius. I tried depinning the first red wire… and wallaaaahh… no backlight LED and FOGs still work… thank you!! :cheers:
  22. Sep 28, 2023 at 9:06 AM
    eddiefromcali
    Eddie
    100% Stock
    You can now take that red wire and tap into a tan wire from a neighboring switch.
  23. Sep 28, 2023 at 9:24 AM
    Woocawachie
    Dickens
    Philadelphia
    That’s what I though.awesome! Thank you.
  24. Sep 28, 2023 at 8:20 PM
    Dtrancrx
    Dtrancrx New Member
    By any chance do any of u know if there's a fuse on the passage side either in the engine bay or under the glove box that can be used for back lighting?
  25. Sep 29, 2023 at 6:34 AM
    Woocawachie
    Dickens
    Philadelphia
    A fuse for what backlighting exactly? Backlight for all the switches ?
  26. Sep 29, 2023 at 8:08 AM
    Dtrancrx
    Dtrancrx New Member
    No..I ment a location where I can tap a back light wire into..instead of running a wire all the way to the switch panel
  27. Sep 29, 2023 at 8:40 AM
    Woocawachie
    Dickens
    Philadelphia
    Oh. That I’m not 100% sure about
