Help with rear rotor removal
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tndra789, Mar 6, 2021.
  1. Mar 6, 2021 at 7:39 AM
    Tndra789
    Tndra789 [OP] New Member
    14 Crew
    Undercover flex Spyder headlights Trd exhaust 24 in KMC Slides Nittos on factory wheels
    I’m stuck
    Can’t get the rear rotor off. I put bolts in to back it off and it’s 90% off. Rookie I will admit, is the emergency brake holding it on from the rear? The top off the rotor will not come all the way off. I can’t see much behind it
    Any help would be great
  2. Mar 6, 2021 at 7:42 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    usually....hit it with a BFH (Big Fucking Hammer)
    I haven't pulled the rear's off, but if they have the drums for the park brake they can be a bit of a pain.
  3. Mar 6, 2021 at 7:49 AM
    Tndra789
    14 Crew
    So got it off, think I might have messed up the parking brake, 2 random springs were in bottom of rotor when I pulled it off. Any idea where they might go. Sh!t this should have been an hour job
  4. Mar 6, 2021 at 7:50 AM
    Tndra789
    14 Crew
    Here is a pic
  5. Mar 6, 2021 at 7:58 AM
    Tndra789
    14 Crew
    Think I got it!
  6. Mar 6, 2021 at 8:10 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    OP, did you find out were those two springs came from.
  7. Mar 6, 2021 at 8:14 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I think those may be from the drum parking brakes. Usually you'll want to use a flathead into that big hole on top of the rotor to adjust the parking brake. Make sure you put it back correctly so you can access the parking brake adjustment in the future.
    Ely010606 likes this.
  8. Mar 6, 2021 at 8:34 AM
    Tndra789
    14 Crew
    Yes
    Two nail looking things hold the spring using pressure from the back side, just pop in and turn to hold spring
    All good on quick test drive!
    Tundra family, Henry1jg and Ely010606 like this.
  9. Mar 7, 2021 at 1:18 PM
    hainesfive
    hainesfive New Member
    MD
    2020 Black TRD Sport Crewmax
    TRD Dual Exhaust Weathertech rear floor liner Black out badging Linex sprayed bed TRD PRO Wheels VLED Interior and exterior Drivers side grab handle Front drivers and passenger window tint Focal speaker upgrade with amp and 10" sub Retrax pro bed cover Falken tires
    Rear emergency brake adjusts like drums do, it's on the rear of all toyota trucks. back off internal wheel and drum slides right off. BFH will cost you $$$$$
  10. Jun 21, 2023 at 5:45 PM
    trevortundra
    trevortundra New Member
    2019 tundra
    Hi, I have the same issue . My Rotor is 90% off but feels like something is stopping it from popping off? I had made the mistake and my parking break was also on. I have released it but still the rotor is being difficult! I am worried about damaging it and I also have found two nail like things and can see loose springs inside the rotor. Should I continue to man handle it off? and wondered how to avoid the same mistake on the other brake?
  11. Jun 21, 2023 at 6:06 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    Shifless Joe and Henry1jg like this.
  12. Jun 21, 2023 at 6:17 PM
    trevortundra
    2019 tundra
    Thanks! I will try that tomorrow. The rubber plug on the , so many videos have talked about preserving it but thats the first time I have seen why it's there! Hopefully a Philips screwdriver will solve the issue!appreciate quick your reply!
  13. Jun 22, 2023 at 9:29 AM
    Shifless Joe
    Shifless Joe New Member
    Mesa AZ
    2016 TRD Off-Road
    A phillips wont but a flat tip will. Like DZ said, gotta rotate the parking brake adjuster, then the hub will slide right off.
  14. Jun 23, 2023 at 3:46 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    So usually a ridge forms on the inside drum part of the rotors that prevents the rotor from being fully removed. As posted above, remove the rubber plug and back off the emergency brake shoe adjuster. Then do the re- adjustment after assembly..
    DZ_ likes this.
  15. Nov 5, 2024 at 3:38 PM
    Telamont
    Telamont New Member
    2015 toyota tundra sr5
    Can anyone help me? I'm having same issue but I can't find the parking brake adjuster .
    Should I be easily finding this with a flathead?
    I wish I could see what I'm looking for to help me understand what to do. I know to pull the plug and align it apparently at the bottom and insert flathead.
    Any insight is appreciated.
    Thanks.
  16. Nov 5, 2024 at 4:24 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Never had this issue when I replaced my rear rotors. Was your parking brake engaged?
  17. Nov 6, 2024 at 10:08 AM
    Toyotaloop
    Toyotaloop New Member
    Pittsburgh
    2021 SR5 Crewmax MGM
    Very little so far
    Telamont, watch some YT videos to see where the star wheel is located on the Tundra parking brakes and which way to rotate for loosen/tighten. The star wheel adjuster is at the bottom and offset from center. IIRC the hole in the rotor will be offset towards front of vehicle: 7 o'clock for driver side, 5 o'clock for passenger side. But a video will confirm.
    When you remove your rotor, take photos of the parking brake components so that you can refer for spring placement and such.
    Before you install the rotor, take note of which way the star wheel is adjusted when turned upwards or downwards on both sides. This will aid greatly to adjust them properly when you have the rotor back on.
    Too many pple complain about weak parking brakes but only adjust the cable under the cab to take up slack. A properly adjusted parking brake is done within the actual brakes, not tightening cables. And will provide you a ton of confidence on a hill or boat ramp.
    sonofdad likes this.
  18. Nov 8, 2024 at 8:39 AM
    sapper8
    sapper8 New Member
    West Michigan
    I just replaced my rear rotors and pads this week. I was lucky and they both popped off. But I was happy to see that there was a space where the backing plate has space that allows the rotor to be hit in the direction away from the truck.
  19. Nov 8, 2024 at 9:06 AM
    Tundra family
    Tundra family New Member
    Force of habit has me setting a parking brake, even when Im about to do brakes (I'm an idiot)
    I yanked those retainers right off the pins. :rofl:
