Help with wheel spacer fitment on a 2015 CM?!
Discussion in '2.5 Gen Tundras (2014-2021)' started by 15max, Jun 5, 2015.
  1. Jun 5, 2015 at 9:12 AM
    15max
    15max [OP] New Member
    Cole
    15 SR5 TSS 4x
    3/1 lift level, 35" Toyo Trail Grapplers
    Question,
    I am wanting to install wheel spacers so my 35s don't rub the sway bar when at full lock but don't want to push them out too far. What is the minimum thickness recommended so that the stock studs do not extend past the face of the bolt on spacer?
    And does anyone know if the 20" fuel wheels that come with the TSS off road package have voids between the lug holes on the mounting face so that if the studs stick out past the Bolt on spacers the face of the wheel will still be able to sit flush against the wheel spacer.
    :help:
  2. Jun 5, 2015 at 11:17 AM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    I'm running 1.25" spacers, they've worked well for me and didnt require grinding down the studs.
  3. Jun 5, 2015 at 11:34 AM
    15max
    Cole
    15 SR5 TSS 4x
    Awesome, whats the brand and site link to where your purchased?
    Did you mount them with stock wheels? What is your exact setup? I have a 3/1 lift level, tss 20s, 295/65/20 (35"). I trimmed the skid plate and removed the front lower fender liner. Just have the issue with getting into the sway bar at full lock.
  4. Jun 5, 2015 at 11:56 AM
    T-Rex266 SpaceX Director Staff Member
    1.25" is the norm.
    Many purchase from @ToyTec Lifts for quality.
  5. Jun 5, 2015 at 1:01 PM
    Relentless
    Eric
    I bought mine from the guys at Motorsport tech/BORA, heres their site. Give them a call, Lenny is a good dude. http://www.motorsport-tech.com/
    I have stock TRD wheels and 295/70/18's on my truck
    15max[QUOTED][OP] likes this.
  6. Jun 5, 2015 at 1:08 PM
    15max
    Cole
    15 SR5 TSS 4x
    Perfect! Exactly what I'm looking for. That you Relentless, much appreciated. :headbang:
  7. Jun 20, 2015 at 2:57 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I have 1.25". You might get away with 1" but def no smaller. 1.25" is recommended.
