Here's a fun one.....serpentine belts?
Discussion in 'General Tundra Discussion' started by 389 24/7, Jan 13, 2025.
  1. Jan 13, 2025 at 7:04 PM
    389 24/7 [OP] 125k on the gen3
    Oregona
    2022 TRD OR
    Nada
    Never mentioned in any manual...
    Kinda critical, right?
    So many opinions on the matter as far as timing & reasoning to change.....
    Who do you trust?
    Lol
    How far do you take a serpentine belt?
    Is one better than two?
    (My 2013 taco had one which I 1st changed at 160k miles of 400k, & my gen3 tundra has 2 belts of which I changed 1 at 80k miles...I really need to do the back one soon)
    I know, keep a spare on board at all times, but what is the real lifespan of this super critical rubber band???
  2. Jan 13, 2025 at 7:14 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    2021 DC SR5 4x4 (guess the color)
    Generally, 10yr/100k miles is typical maintenance schedule…. OR, anytime you replace an accessory drive component, you replace idlers and tensioners if they are nearing that age. This is assuming OEM-quality components. I wouldn’t expect economy aftermarket parts to last nearly that long.
    Again, this is general/typical maintenance timeframe you’ll find across brands. Some will say “if it ain’t broke, don’t fix it”. Unlike a timing belt, serpentine/accessory drive can be easily inspected for damage and won’t destroy your engine if it does break.
  3. Jan 13, 2025 at 7:29 PM
    Oregona
    2022 TRD OR
    Nada
    So that's every 2 yrs for me based on my yearly mileage
    Good to know
  4. Jan 13, 2025 at 7:31 PM
    Oregona
    2022 TRD OR
    Nada
    Does weather & extreme temps (cold or hot) change the timing to change out serpentine belts?
  5. Jan 13, 2025 at 7:42 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    Possibly, but would have to be pretty extreme. If the belt is expose to oils/fluids because of leaks, that could potentially shorten its service life. Modern belts are very resilient.
    you could inspect the belt for wear, cracks, glazing and damage. Idler bearings tend to chirp or make other bearing noises, belt squealing usually indicates a tensioner losing its tension.
    You’ll usually get some indication that something is going wrong with the accessory drive and the consequence of a failed serpentine belt is not catastrophic like a timing belt.
    Raven67 likes this.
  6. Jan 13, 2025 at 7:52 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    About 10 years ago, I did a timing belt on a 2000-ish Ford Ranger 4-cyl with over 15yrs/150k on the original timing belt. I looked pretty rough, but was still doing its job.
    Also, I don’t think Ford put a replacement interval on those. Absolutely do not recommend going that long.
  7. Jan 13, 2025 at 8:24 PM
    2mchfun
    I go with 3yrs or 50k on all my vehicles and keep the newest old one stowed away in the vehicle at all times. Never had a failure and probably never will:thumbsup:
    389 24/7[OP] and Tundra family like this.
  8. Jan 13, 2025 at 9:48 PM
    Tundra family
    Tundra family New Member
    I'm in AZ where my belt sees some pretty gnarly temps. It failed at around 190k miles. I'm that guy that pushes my luck, still on factory hoses after 215k.
    389 24/7[QUOTED][OP] likes this.
  9. Jan 15, 2025 at 3:12 PM
    smokint
    smokint New Member
    I changed mine at around 100K, along with the idler pulley and belt tensioner…all of it looked brand new
    389 24/7[OP] and AZBoatHauler like this.
  10. Jan 16, 2025 at 9:44 AM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    When I replaced our Sequoias belt, at ~80K, it still looked very good. I only replaced it as the tensioner went out around that time and I already bought the belt. I probably could have easily gotten 100K out of it.
    smokint likes this.
  11. Jan 16, 2025 at 9:59 AM
    2mchfun
    Keep in mind it really sucks to be miles from anywhere at 1 A.M. with a broken $40 belt and no spare folks.
    smokint, yakeng and AZBoatHauler like this.
  12. Jan 16, 2025 at 10:06 AM
    AZBoatHauler
    So.Arizona
    Sucks even more if the belt takes out your radiator. I’ve seen that on a neglected 3UR.
    smokint and 2mchfun[QUOTED] like this.
