Hertz Cento vs Morel Tempo
Discussion in 'Audio & Video' started by FirstTruck, May 25, 2021.
  1. May 25, 2021 at 6:10 PM
    FirstTruck
    FirstTruck [OP] New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    Im in the process of selecting my new speakers. I will go with components in the front and coax in the back with two subs behind the seat, D 4.800 and RF T750X1bd to run them. Keeping HU for now.
    Option 1: Hertz Cento Pro CPK 690.
    Option 2: Morel Tempo Ultra 692 MK II.
    The rears will be coax of the same line.
    Any input on either set will be appreciated.
  2. May 26, 2021 at 3:27 AM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    I have sound experience with Hertz k170’s in all four doors and love them. For the money they are Very good sounding across their spectrum.
    From what I hear and know, I would lean towards the Hertz direction myself.
    good luck with your choice, I’m sure it IS going to be way better then our JBL sound from the Toyota folks.
    FYI, you may need a RF Mastero dsr1 module to retain head unit and dash display functions….
  3. May 26, 2021 at 8:08 AM
    FirstTruck
    Stock, for now
    Thanks for your input. I will be going with the D 4.800 so no need for DSR, is this correct?
  4. May 26, 2021 at 8:22 AM
    RdKing
    Rich
    Eastern Seaboard
    Im not exactly sure as I have a JBL Premium head unit, so for my signal correction and wheel functions I had to go with the Mastero DSR1.
  5. May 26, 2021 at 9:02 AM
    FirstTruck
    Stock, for now
    Guess you are correct. Anyways a DSR-1 is needed. The D4.800 is an amp with a DSP built in. Maybe an LC 4.800 with the DSR1 might be a better fit.
  6. May 26, 2021 at 9:07 AM
    RdKing
    Rich
    Eastern Seaboard
    Your not considering a 5 Channel Amp FirstTruck?
    My JBL A5055 and the RF Mastero fit under my r/f seat in the original location as the factory.
  7. May 26, 2021 at 9:40 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Hell yes>>>>>>>>>>>>:thumbsup:
    5 channel for the win..
    Even when I had the huge JBL MS-8, before buying an aftermarket HU..:eek2:
    7B9FAC95-91A2-41AD-A680-FDADB81A1AFC_zps_badcd71b34e987f2cff775922d2290a231c3cb31.jpg
    Rica25 and RdKing[QUOTED] like this.
  8. May 26, 2021 at 11:20 AM
    FirstTruck
    Stock, for now
    I started with a 5 channel; alpine, kenwood, RF..., but nothing was checking all the boxes.
    I will have (2) 10” P3 with 300 each plus (4) door speakers of 100 rms min on each door.
    I could not find a 5 channel with 100 / 125 x 4 + 1 x 600 rms. There are some out there but either the price or the size wasnt there.
    Let me know if there is one that will fit under the seat and have enough power for the speakers.
  9. May 26, 2021 at 11:41 AM
    RdKing
    Rich
    Eastern Seaboard
    Have you looked around Taylor's Audio t/a tech12volts for a package, or started collecting components yet?
    I can tell you that if your budget is within the package prices, that their recipe is proven and is a nice match that will make you smile.
  10. May 26, 2021 at 3:19 PM
    FirstTruck
    Stock, for now
    To tell you the truth I have heard mixed reviews from him. I will send him an email and let you know. Also dont think he sells Audio Control, Hertz or Morel
  11. May 26, 2021 at 5:43 PM
    RdKing
    Rich
    Eastern Seaboard
    I learned of Hertz from James
    Did some research and put them in.
    I’ve said it before, I hear sounds thru their range that I have not distinguished in any car audio I’ve done or heard and I’m no expert or fanatic.
    I like tunes and I like some things loud and I haven’t been disappointed.
    I do know that if anyone in this forum is close enough to my shop wants to take a @tech12volts test drive in my truck is always welcome. But I warn you, your gonna buy something you’ll appreciate.
    But as my Italian uncle used to say
    “What do I know”
    LOL
    Kung likes this.
  12. May 27, 2021 at 11:31 AM
    FirstTruck
    Stock, for now
    Would you mind specifying yr install? Roughly what amp(s), speakers and subs
  13. May 27, 2021 at 11:56 AM
    RdKing
    Rich
    Eastern Seaboard
    Custom Sub Enclosure for CrewMax Dual Sub's
    JBL Audio Club 5505 5 Channel Amp
    Hertz K170 6.5 Components Front
    Hertz K170 6.5 Components Rear
    JL Audio 10W0v3 10 inch Subwoofers
    Speaker Mounting Brackets for Doors with Harnesses
    Rockford Fosgate Maestro DSR-1
    Rockford Fosgate DSR-1 Harness For JBL
    JBL Factory System HeadUnit
  14. May 27, 2021 at 5:24 PM
    FirstTruck
    Stock, for now
    Hey not bad!!! Are u happy with the Hertz? Or wish u would have gone up the line?
  15. May 27, 2021 at 9:07 PM
    RdKing
    Rich
    Eastern Seaboard
    I wouldn’t change a thing
  16. May 29, 2021 at 3:42 PM
    Freeezen
    Freeezen New Member
    https://www.sonicelectronix.com/item-158921-NVX-VAD11005.html
    I used this amp, which actually meets your requirements at 2 ohms. I run my front and rear components at 4ohms and my two subs at 2 ohms. Everything else I got through James at Tech12volts. It plays LOUD and I have the gains set fairly low.
    Kenwood DDX 9707S
    (2 pair) Hertz CK 165
    (2) JL Audio 10W03
    9AEADCEE-F82C-4109-AF7C-8388DE9C3702.jpg 24F8E6EA-BEA2-45F5-97AA-12DC4ABAA9F5.jpg 39525128-DB25-4C6B-915B-083A25EFE149.jpg
  17. Jun 1, 2021 at 2:33 PM
    FirstTruck
    Stock, for now
    Thanks for your input. Something is not adding up. The specs on that amp are 80 x 4 @ 4 ohms. How are you running the Centos at 2 ohms?
  18. Jun 1, 2021 at 3:28 PM
    Freeezen
    Freeezen New Member
    Reread my post. The components are run at 4ohms and the (2) 4 ohm SVC subs are run in parallel at 2ohms on the the 5th channel.
  19. Jun 1, 2021 at 3:35 PM
    FirstTruck
    Stock, for now
    That amp has 80w per channel at 4 ohms. Im running 120w front and 95w rear. I need just a little bit more.
    what idatalink Maestro harnesses did you buy?
  20. Jun 1, 2021 at 3:49 PM
    RdKing
    Rich
    Eastern Seaboard
    You don’t have to run it on the redline FirstTruck
    You can bounce off of it occasionally, but it’s not necessary
    There are two of us that aren’t max’d but have nice tunes.
  21. Jun 1, 2021 at 6:36 PM
    FirstTruck
    Stock, for now
    Correct. Im trying to get as closer as possible. Thats why I will run 2 amps.
  22. Jun 1, 2021 at 8:08 PM
    Elduder
    Elduder New Member
    Have heard both, have bought Morels multiple times over, if that says anything.
    I know sound is a subjective thing, the Centos are great for efficiency and loudness but the Morels are just lovely.
    One thing to consider, I own the Tempo 692 Ultras right now, they’re in our 4R because they won’t fit in the Tundra. The magnet is simply too large and deep.
    I now have the Virtus 602s, even better than the Tempo Ultras. A bit more cash but they fit and are worth every penny.
  23. Jun 1, 2021 at 10:38 PM
    Freeezen
    Freeezen New Member
    That NVX amp is rated at 125x4 at 2ohms and 600 x1 at 2ohms. I just run my components at 4ohms for the 80 watts.
    I used the Maestro RR, rTO2, sTO2 and UTO2. I couldn't tell where you are from, but if you are near Orange County, California you are welcome to take a listen.
  24. Jun 2, 2021 at 4:32 AM
    FirstTruck
    Stock, for now
    I live in SoFla. East Coast. Thanks for the offer. Very kind of yours.
  25. Jun 2, 2021 at 6:09 AM
    FirstTruck
    Stock, for now
    Thanks for the input. Virtus is the way to go if you are going Morel. A little pricey for me right now.
    Almost all 6x9 in this price range are between 3 1/4” and 3 1/2”. Taller or stacked adapters and spacer plus trimming of the door panel will make it. I need to triple check this before pulling the trigger but thats my plan. I would go the extra mile to have 6x9s.
    Elduder[QUOTED] likes this.
  26. Jul 6, 2021 at 2:28 AM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    FYI these fit tight…after trimming the inside of the door panel. Magnet is against the window guide. I think the Cento are only an 1/8 inch deeper?
  27. Jul 6, 2021 at 5:45 AM
    FirstTruck
    Stock, for now
    Thank you. I gave up on the 6x9’s. I was looking for min 100W. I went with Hertz Mille MPK 165P.3 with 115W. Hope they're good. I will start a thread soon on my install. I guess I went down the rabbit deep hole.
    MTRock[QUOTED] likes this.
