Hewitt Bypass Kit Failure?
Discussion in '2nd Gen Tundras (2007-2013)' started by kanger328, Sep 23, 2022.
  1. Sep 23, 2022 at 12:17 AM
    kanger328
    kanger328 [OP] New Member
    Anchorage, Alaska
    2012 DC 4x4
    Has anyone had their Hewitt SAIP bypass kit fail? I had the SAIP failure, so I got the bypass kit back in 2020. Worked great...until yesterday. Got a check engine light, code read P2444. Today, truck went into limp mode and now has 3 codes (P2442, P2444, P2442P).
  2. Sep 23, 2022 at 12:35 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Was looking into Hewitt ... thought if you installed before a pump failed, it was a non issue moving forward ?!
    I would call them, number on website.
    Subbed for info, good luck OP !
  3. Aug 5, 2023 at 2:45 PM
    2160Tundra
    2160Tundra New Member
    Any luck with resolving this issue? I installed the Hewitt bypass kit in 2021 and just started receiving a P2442 code recently in my son's 2008 Tundra with the 4.7l. Interestingly enough, this issue occurred after getting a flat and installing the spare without a tpms. Replaced the tire and had no issues for three weeks and then the code comes back.
  4. Aug 5, 2023 at 8:50 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Call Hewitt's #. Chances are you'll speak with the owner. Super nice and will answer any & all questions.
  5. Aug 20, 2023 at 5:55 PM
    1blessedyota
    1blessedyota New Member
    Athens-Bellevue
    I'm in the same boat haven't been a year and just got the 2443-2447 I did the full bypass 2 kit. A little frustrating considering before hand I had spent the money on the dap to delete it and it didn't work. But unlike Dap Hewitt has been great at customer service. So I problay give them a call.
    Tundrastruck91 likes this.
  6. Aug 21, 2023 at 5:46 PM
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    I installed my Hewitt kit in 2019 as prevention. All was great until last month, started the car and got a P2440. The bad part was that I was 750 miles away from home. When I got home, I went ahead and put the blocking plates in. In retrospect I should’ve installed them in 2019 (as recommended by Hewitt), but I didn’t because others on the forums said it was unnecessary when being used as prevention.
  7. Aug 21, 2023 at 6:14 PM
    1blessedyota
    Athens-Bellevue
    Give them a call. We started to go the dealer route and fix it with new parts but even then that's a gamble. I'm $1700 in this between the 2 companies but the Service side of Hewitt is by far one of the best.
    So I'm sure it's gonna get ironed out. I would start by checking and rechecking your connectors. Dads truck wouldn't go 30miles before the cel came back on and I went back and double squeezed the connectors and it's not come back over the last 30 miles so we will see. He drives a lot so we will see real soon. Love this truck but it's costing more than my diesel with a lot of dumb stuff toyota just dropped the ball on.
  8. Aug 21, 2023 at 6:18 PM
    Tundrastruck91
    How many miles you got on the 17 ? .. Did putting on the blocking plates, clear codes and take out of limp mode?
    Larry Chen did the relocation mod for the pumps, which makes the replacement easy if/when they fail. With prices of delete kits and not actually even working, will probably just have pumps replaced by dealer if they fail.
    Anyone know if the continued these pumps on the 2022+ models ?
  9. Aug 21, 2023 at 6:22 PM
    1blessedyota
    Athens-Bellevue
    Well it's not just the pumps what about the actual actuators underneath the intake when they get stuck open or closed? That's another pain in the butt I just wasn't ready to deal with.
  10. Aug 21, 2023 at 6:43 PM
    Rph74
    Rph74 New Member
    Springfield,MO
    Mine is actually an 07 with the 5.7…it has 195,000 miles on it. Yes, I was able to clear the codes, put in the blocking plates and all is good now.
    I had to pull over 15-20 times on that 750 mile trip to clear codes each time….when my check engine light came on, it went into limp mode. Clearing it allowed me to run like normal for at most 150 miles, and on the low end 2-3 miles each time. It was actually the most harrowing road trip I’ve ever made. I was praying to God that I wouldn’t go into limp mode in Houston or Dallas, and thankfully that didn’t happen.
    1blessedyota likes this.
  11. Aug 22, 2023 at 5:38 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    You have to install the block off plates or it wont work in the long run.
    Rph74 likes this.
  12. Jan 1, 2025 at 7:56 PM
    TundrAZ86
    TundrAZ86 New Member
    2010 Tundra 4.6 SR5 4x4
    Any updates to these kits working/not working? I ordered mine yesterday, threw a 0412 code, I cleared it, then a P2441 Code, valve is stuck closed. I got the bypass and a pressure sensor replacement for Bank 1. Am planning to install the block off plates, rolling the dice since I live in a state w/ emissions testing so we'll see how it goes.
