Hi , I have 2014 Tundra 1794 have 22” Trd rims , 285/45/22 tires like to go wider?
Discussion in 'Wheels & Tires' started by 1794 Tundra R, Mar 5, 2018.
  1. Mar 5, 2018 at 5:59 AM
    1794 Tundra R
    1794 Tundra R [OP] New Member
    Richard
    2014 Tundra1794
    Trd air intake , 22” Trd cast aluminum rims , aftermarket tail lights
    I have 2014 Tundra 1794 , installed 22” F-Sport wheels of LX 570 with 285/45/22 tires trying to go with wider tires keeping about same height , any suggestions?
  2. Mar 5, 2018 at 6:01 AM
    agentcox000
    agentcox000 "Skin that smoke wagon and see what happens"
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    Welcome! Sorry no info on your question as that is not a common size around here. I’ll sure someone will be along who is more knowledgeable
  3. Mar 5, 2018 at 6:03 AM
    Welcome from Texas
    Checkout customwheeloffsets.com maybe help out???
  4. Mar 5, 2018 at 6:17 AM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Welcome from AZ
  5. Mar 5, 2018 at 6:39 AM
    Filthy13
    Filthy13 New Member
    NorCal
    2017 White 1794 TRD OR
    A few goodies
    Welcome.
    :worthless:
    TheBeast likes this.
  6. Mar 5, 2018 at 7:12 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO
  7. Mar 5, 2018 at 7:21 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome Richard.
  8. Mar 5, 2018 at 12:40 PM
    TUNDRA375
    TUNDRA375 New Member
    GA
    2021 TRD PRO LUNAR ROCK
    :worthless:
    Kevin1741 likes this.
  9. Mar 5, 2018 at 1:08 PM
    Kevin1741
    Kevin1741 New Member
    Interested...can you show a pic of your truck with the 22’s. Ty!
  10. Mar 5, 2018 at 1:27 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Unless someone here has an answer based on experience with the same wheel/tire combinations, I would suggest:
    If you are going to keep the same wheels (/rims), then measure the distance between the existing tire and the UCA where it is closest to the tire.
    Also turn the wheels all the way to the left and measure the distance between the inside of the tire edge and frame on one side and the distance between the front face of the tire and the bumper, mud guard etc. - anywhere it seems to be close. Repeat with wheels all the way to the right, since it is not always the same for each side. You might want to repeat this with the wheels in flex (parked with one wheel on a curb and again in a hole). Then take the difference in width between the existing and proposed tire, divide it in two (since one half of the additional width will be to the inside and the other half to the outside) and see if it will fit in the dimensions/clearances you have with the existing tires.
