Hi lift jack
Discussion in 'Recovery & Gear' started by joonbug, Feb 19, 2017.
  1. Feb 19, 2017 at 2:32 PM
    joonbug
    joonbug [OP] °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Just wondering if anyone has a Hi Lift jack? How did you mount it? I'm guessing the stock jack doesn't work on our lifted trucks so I think I'm going to carry around my Hi Lift permanently to use as a jack. I want to mount to the side or front of my bed but I don't have a deck rail system.
  2. Feb 19, 2017 at 2:48 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    This is when i had my Patriot HL jack. I use the LoRac for the mounting. Took me about 30min to install
    TRDGen, equin, Mountun Goat and 8 others like this.
  3. Feb 19, 2017 at 2:49 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Here's a shot with the Jerrys mounted as well
    TRDGen, equin, Mountun Goat and 11 others like this.
  4. Feb 19, 2017 at 2:54 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  5. Feb 19, 2017 at 3:03 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Tommy, exactly what I'm looking for. The jack is so heavy, does it just screw through the bedliner and into the bed? I have a retractable cover canister right there, so I may have mount under it. And where did you get the jerry cans and mounts too? I need that exact set up too.
    ColoradoTJ and Hattori like this.
  6. Feb 19, 2017 at 3:14 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Cool! Yea man, you have to drill through the bed and secure with longer bolts. But it holds very nicely. You're gonna have a challenge on your hands trying to mount it like that underneath the canister though. You can do the side of the bed, just have to remove the liner on what side you want to mount on and drill the spots out you want to mount the secure system to then reinstall the liners.
    The Jerry can holders are from Smittybilt. I drilled down through the bed and just secured em down with nuts, bolts, and washers. I need to add some insulation to the insides to keep the cans quiet while they're empty. I love that setup because I have a extra 10gal of gas on reserves when needed.
  7. Feb 19, 2017 at 3:20 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    I'm going to have to go look at the bed and see where I can mount on the side. And what do you mean by "remove the liner"? I have a spray on bedliner.
    Hattori likes this.
  8. Feb 19, 2017 at 3:22 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    On the liner; if you decide you wan to side mount it above the wheel well on either side, you need to remove the fender liner to gain access to the upper portion of the inner bed.
    ColoradoTJ and joonbug[OP] like this.
  9. Feb 19, 2017 at 3:24 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Oh gotcha. Thought you were talking about the bedliner. Thanks Tommy, this looks perfect
    Hattori[QUOTED] likes this.
  10. Feb 19, 2017 at 3:31 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
  11. Feb 19, 2017 at 3:56 PM
    Here is another way to mount things like this if your going to use sheet metal.
    https://www.fastenal.com/products/f...roducts"|~ ~|categoryl3:"602457 Rivet Nuts"|~
    Rivit Nuts are a little spendy, but boy are they nice. I use them for removable panels, hanging electrical...etc. works well when getting behind panels is difficult.
    For the HI-lift, I like using the bed rail system, even if you have to mount it down a bit, using some uni-strut like what csuviper used for his DIY bed rails.
    CM-LENNY and Hattori like this.
  12. Feb 19, 2017 at 4:03 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    I don't think I can mount a bed rail due to my cover. Unless I find one of those drop down kits. I wouldn't mind having some more tie down points too. How does that rivet nut work Chris?
  13. Feb 19, 2017 at 6:53 PM
    Drill hole, insert rivit nut, use crushing tool, and your done. Very easy to do.
    joonbug[QUOTED][OP] likes this.
  14. Feb 19, 2017 at 6:59 PM
    I like how you mounted the Jack and Cans, very clean and leaves the bed open for use. Well done.
  15. Feb 19, 2017 at 7:15 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    I like it... maybe I won't have to remove the liner.
  16. Feb 19, 2017 at 8:09 PM
    I use these in conjunction with mounting systems or like plate steel for strength.
  17. Feb 19, 2017 at 11:40 PM
    caboose
    caboose -1
    somewhere in the USA
    tundra dc trd
    ride rites w/ air compressor, trd pro grille, decked bed storage, nfab rkr rails w/steps, remote start.
    040Tundra and ColoradoTJ like this.
  18. Feb 19, 2017 at 11:41 PM
    caboose
    caboose -1
    tundra dc trd
    Its for the Tacoma But The rail system is the same size.
    Sleeper16plat and ColoradoTJ like this.
  19. Feb 20, 2017 at 1:49 AM
    caboose
    caboose -1
    tundra dc trd
    Didn't see this. You could probably fab up something very similar just make sure you make it hang low enough that it doesn't get in the way of the cover might want to check out Tacoma world mod pages.
    https://www.tacomaworld.com/threads/cheap-free-mods.4838/page-4#post-46131
    He says in the thread it got in the way of his cover but the tundra doesn't have bed issues like the Tacoma. I've never had a cover over my bed how far down does it sit?
  20. Feb 20, 2017 at 3:44 AM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    This thought never even crossed my mind. Joon, if you could stop posting ways I should be practically spending my money (like this and the full sizes spare) that would be great. lol
  21. Feb 20, 2017 at 4:21 AM
    Mountun Goat, rons23, Law323 and 4 others like this.
  22. Feb 20, 2017 at 5:48 AM
    Sunkist
    Sunkist New Member
    Siler City, NC
    2014 Tundra Crewmax SR5
    ESP rear seat storage Rough Country Susp lift 20" Fuel wheels 35" Toyo open country MT Weathertech front/rear floor liners ICI Magnum steps with led's
    How are you going to lift the truck with a high lift jack though without any lift tabs on the truck ?
    joonbug[OP], 15whtrd and TNTundra08 like this.
  23. Feb 20, 2017 at 8:36 AM
    15whtrd
    15whtrd Mr. Blonde
    My thoughts exactly. Where are you guys jacking the truck up from? Unless you have sliders I don't see a good spot.
    joonbug[OP] likes this.
  24. Feb 20, 2017 at 8:44 AM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    I've got sliders. Yeah, I don't really think you can use a high lift on a Tundra without sliders.
    CJ21 and 15whtrd[QUOTED] like this.
  25. Feb 20, 2017 at 8:47 AM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    I go from the hitch receiver. If I need to access the front end I use the Hi-Lft bumper lift get the front up in the front, also if you're needing to get the wheel from being stuck in mud, sand etc, I use the lift mate. Just need some max trax now....:facepalm:
    equin, Law323 and joonbug[OP] like this.
  26. Feb 20, 2017 at 8:52 AM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    What's the bumper lift? And it's okay to lift from the hitch?? I need some max trax too but so much $$$$.
  27. Feb 20, 2017 at 8:54 AM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    The stock bottle jack still works if you have some blocks of wood. I'm also not a fan of using farm jacks since they usually jack the truck up from a point that requires significant suspension travel before a wheel comes off of the ground. Lifting a truck up from the axle is way safer and much easier than using any farm jack. I think that this would be a much more viable option off-road.
    rons23, Hammerhead and dcsleeper408 like this.
  28. Feb 20, 2017 at 8:59 AM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Yeah, I still carry my stock jack and blocks of wood but I'm not going to carry my full size floor jack around. I'd rather mount the hi jack somewhere.
    equin likes this.
  29. Feb 20, 2017 at 9:07 AM
    computeruser6
    Dirk
    Escondido
    I just don't like using farm jacks. I've used them off-road before and it's like a tool that can do many things but none of them very well.
    equin and ColoradoTJ like this.
  30. Feb 20, 2017 at 9:28 AM
    LibertySand
    LibertySand IH Support Rig
    Montclair, CA
    07 TRD DC 5.7 Tow 4X4
    Just some words, take it or leave it...
    Mounting:
    Hi-Lift jacks are heavy. They rattle like a sum'bitch and anything they are attached to tends to get destroyed. You pretty much have to isolate the jack so it has no chance in moving.
    I've used the "Hi Lift Jack Mount system" Fails after a year. like in post #2 More times than not, the mounts rip off what ever they are attached to. The Jack will find a way to vibrate itself and causes damage to the sheetmetal or screws/bolts used to affix it.
    Riv Nuts, I wouldn't do it. Like post #13. Those wont last at all! This goes back to the Jack Vibrating them loose and ripping them right out of the sheetmetal in the bed. Riv Nuts are great, just not this situation.
    You'll want to find something or make something that is more of a permanent solution. Most Hardcore wheelers physically bolt straight thru there Hi Lift to a welded or hard mount on a cage.
    Usage:
    Have you ever used a Hi Lift? Maybe on the drive way they seem safe and stable but when you really need them your rig is usually in a bad spot on the trail and the jack becomes a widow maker. Thats if you were able to even get a good grip location on the rig at all. They are nice to have when in dire need but usually opt out for a common bottle nose jack. Or like post #27
    Some off road clubs required a Hi Lift jack as part of their rules for having while on a run. Like a rear locker or spare tire. Since then, all they require is a "means to lift vehicle to change tire"
    On my 72 Scout II I carry both Hi Lift and a Harbor Cheap Jack. On my Tundra I am building a Bed Rack that will carry only a Harbor Cheap Jack, No Hi lift.
    Take it or leave it.... just thought I chime in.
    Tundra805, equin, rons23 and 3 others like this.
