High RPM on startup
Discussion in '3rd Gen Tundras (2022+)' started by arkhomer, Aug 13, 2023.
  1. Aug 13, 2023 at 10:33 AM
    arkhomer
    arkhomer [OP] New Member
    Tyler
    2024 Limited
    I'm pretty sure I saw a post, but the search feature is difficult... what's up with the high RPM on start up? Gets up to around 1500-1800 for 15-20 seconds then levels back out to around 1000.
    Truck has 300 miles.
  2. Aug 13, 2023 at 10:41 AM
    EmergencyMaximum
    EmergencyMaximum New Member
    Maybe AC is on when you start up? Unless its electric ac, in that case nevermind.
  3. Aug 13, 2023 at 10:44 AM
    That's usually normal for most vehicles to get fluids flowing.
    chaztizer and Durtywrench like this.
  4. Aug 13, 2023 at 10:45 AM
    EmergencyMaximum
    My truck does the same, but she's olde girlie. My newer venza drops rpm much sooner, but she's also a v4, small engine probably doesn't need to idle as long in hi rpm
  5. Aug 13, 2023 at 10:50 AM
    arkhomer
    Tyler
    2024 Limited
    Thanks for the replies, just sounds like it's about to take off
  6. Aug 13, 2023 at 11:15 AM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Once the electric fan clutch lets go it quotes down tremendously
  7. Aug 13, 2023 at 11:18 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    In the past, Toyota used that method to get the cats up to operating temperature quicker for emissions reasons.
    Polo08816, pwpblue and NutsVolts like this.
  8. Aug 13, 2023 at 11:52 AM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Normal, has to get the cats heated up asap!
    SC4333 likes this.
  9. Aug 13, 2023 at 12:32 PM
    iforceAZ
    iforceAZ New Member
    Pretty normal for just about every car to rev higher to get up to operating temperature quicker
  10. Aug 13, 2023 at 12:36 PM
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    Yep. High idle and dumping fuel to warm up the catalytic converters as quickly as possible to meet EPA emission testing requirements. You'll notice this happens on nearly all new vehicles when cold starting.
  11. Aug 13, 2023 at 12:43 PM
    CMikeB
    CMikeB New Member
    Your Owner's Manual will tell ya' all about it.
  12. Aug 13, 2023 at 12:53 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I haven't noticed this so much with our late model GM fleet pickups and passenger cars though. Maybe they have a different methodology?
  13. Aug 13, 2023 at 1:44 PM
    arkhomer
    Tyler
    2024 Limited
    That sounds like work..
    EmergencyMaximum likes this.
  14. Aug 14, 2023 at 2:13 AM
    CMikeB
    CMikeB New Member
    My bad, sorry.
