Homelink compatibility bridge (SOLD)
Discussion in 'Marketplace - Other' started by shifty`, Jul 27, 2022.
Thread Status:
Not open for further replies.
  1. Jul 27, 2022 at 7:52 AM
    shifty` [OP] Just like witches at black masses
    Retail is $50 on these. It's FREE, just cover the ride.
    Basically, this lets you use older Homelink door openers with the newer Chamberlain/Liftmaster garage door openers using Security+ 2.0 encrypted remotes.
    Who needs it? I did. I replaced our 20yo garage door opener and it was incompatible with our 2012 Highlander's Homelink. This kit fixed the problem, bridged the communication gap.
    Setup requires following instructions to the letter, it's not a "no-brainer" to program. Once setup, it worked flawlessly for 2yrs. Only requires an electrical outlet 5ft-15ft from the opener to work.
    Our new 2020 Highlander has Homelink v5, so I pulled the kit. Kit should work with all Chamberlain, Liftmaster, potentially Merlin and Grifco openers, if you have the same issue I did.
    Here's a link to explain what it does and maybe check compatibility: https://www.chamberlain.com/homelink-compatibility-bridge/p/HOMELINK+RPTRMC
    Comes with everything you see pictured: Receiver/broadcast unit, programming remote, instructions.
  2. Aug 17, 2022 at 8:06 AM
    Bump for freeness
Thread Status:
