Hood bulge light bar
Discussion in 'Lighting' started by greentrbo95gst, Jul 8, 2021.
  1. Jul 8, 2021 at 8:44 PM
    greentrbo95gst
    greentrbo95gst [OP] New Member
    Huntington Beach
    What are some options for the hood bulge light bar for 2020 Trd pro? TIA
  2. Jul 8, 2021 at 8:47 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Tundra234 likes this.
  3. Jul 8, 2021 at 8:50 PM
    greentrbo95gst
    Huntington Beach
  4. Jul 8, 2021 at 8:54 PM
    memario1214
    Colton
    Missoula, MT
    Ha yes that is just the mount. The light bar that mount is built for is a 40" Baja Designs S8. I could help you out on picking one up if you decide to go that route, but there are certainly other bars that probably have been install there. Pretty sure NSV was working on something once upon a time, but I don't know if they ever came out with it.
  5. Jul 8, 2021 at 10:13 PM
    13igtymer
    13igtymer New Member
    2016 toyota tundra crewmax limited
    I am also looking for a lightbar for the hood bulge. I was the nsv and the bd s8 but I can't justify spending almost $1k just for one lightbar. Another forum member bought a $100 lightbar from Amazon and was happy with the results.
  6. Jul 8, 2021 at 10:15 PM
    13igtymer
  7. Jul 8, 2021 at 10:32 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I love my NSV lightbar
  8. Jul 8, 2021 at 11:40 PM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Mine is a 2016, went with SDHQ mount and Baja Designs S8. Expensive yes but also extremely bright. Stock headlights, S8 and S8 backlight.
  9. Jul 9, 2021 at 12:05 AM
    AZ Red Nek
    Chuck
    When I was looking there were a few that didn't require cutting. The S8 isn't one of them. I didn't really want to cut but I wanted the most light output I could get. I did give her a bath and a wax after if that helps.
  10. Jul 9, 2021 at 7:58 AM
    greentrbo95gst
    Huntington Beach
    Isn't the $100 one from Amazon also a lot less effective?
  11. Jul 9, 2021 at 8:52 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Yes, you get what you pay for. My 4runner has more lights then any vehicle should ever have. Started with Amazon bars and pods and started getting Baja and rigid. Now the whole truck is Baja and rigid and the quality is obvious. My rigid side shooter pods are brighter then an Amazon 32" led bar.
  12. Jul 9, 2021 at 8:53 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I think almost all require cutting those bars behind the bulge, you might be able to find a skinny bar on Amazon that would fit in front of it.
  13. Jul 9, 2021 at 9:14 AM
    BlancaLaGordita
    BlancaLaGordita New Member
    Blanca
    2021 Tundra TRD Sport
  14. Jul 11, 2021 at 10:33 AM
    greentrbo95gst
    Huntington Beach
    Do it right the first time....DIRFT. I will stick with the S8. Thanks man.
  15. Aug 6, 2021 at 9:28 AM
    Could you post some closeup pictures of the fitment? Also, does the S8 have its own switch? I don't like the NSV because it only works off of the high beams. Thanks.
  16. Aug 6, 2021 at 2:18 PM
    AZ Red Nek
    Chuck
    Hope this helps. The S8 has two switches on the wiring harness. One for the backlight the other for the main light. I ended up getting a Switch Pros controller and switch. On the switch the DLR button is for the backlight and the lightbar switch is for the S8.20210806_140424.jpg 20210806_140419.jpg 20210806_140409.jpg 20210806_140357.jpg 20210313_134820.jpg
  17. Aug 6, 2021 at 2:47 PM
    Thanks. So it looks like the only gap is at each end of the bar? I don't see any at the top or bottom. I just can't see getting the NSV if I can't even turn it on manually without going to high beams first.
    AZ Red Nek[QUOTED] likes this.
  18. Aug 6, 2021 at 4:12 PM
    AZ Red Nek
    Chuck
    You're welcome Sir. I agree with your comment on the switch. With the Switch Pros controller and switch you can double tap the switch and the lights will strobe. I didn't care about the strobe function at first but got to thinking, if there was a emergency situation help could find you quicker. I put my parka back on and took a couple more photos. The gap on each side is part of the lightbar where it attaches to the mount. I had to use a flashlight inorder to get it to show up in the photo.20210806_155525.jpg 20210806_155556.jpg
  19. Aug 6, 2021 at 4:18 PM
    Nice...I like it!! NSV can bite it...lol.
  20. Aug 6, 2021 at 4:24 PM
    I think it would look sweet on mine....
  21. Aug 6, 2021 at 4:39 PM
    AZ Red Nek
    Chuck
    Absolutely, and fantastic looking truck. You do have to do some cutting on the hood but you will never notice it once the lightbar and surround is back on. You will also need to drill some access holes on the under side of the hood. After I made the cuts I shot it with primer and then some color match to prevent rust.20210311_224054.jpg
  22. Aug 6, 2021 at 4:52 PM
    Thanks. I did see a video on the tabs that need to be cut out. It didn't look too bad. The holes are to reach in to grab the wiring?
  23. Aug 6, 2021 at 7:09 PM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    They say to cut those "so you can get the bolts in from the back side easier". It's because they replace the plastic clips that hold the bulge on with bolts and nut clips.
    I left the plastic clips in, and have had no problems in 3+ years. They did come loose once going across south dakota at 80MPH in 50+ MPH winds. Only time I've had a problem... I replaced the stock plastic clips with new ones after that and they've held ever since.
    mav7021234 and bulldog93 like this.
  24. Aug 6, 2021 at 7:27 PM
    I was referring to the supports on the hood itself but it's all good. :thumbsup:
  25. Aug 6, 2021 at 7:33 PM
    ChrisTRDPro
    MT
    I thought you were asking what the round holes are for :thumbsup: maybe someone else will find the info useful
  26. Aug 6, 2021 at 8:50 PM
    AZ Red Nek
    Chuck
    No, they're for reattaching the plastic surround. They include some screws and nut plates. If I had smaller hands it would have been great. But it turned into a pain in the rear. There is a channel between the outer and inner hood panel that I fished the wiring through. It comes out by the drivers side hood hinge for a clean install.
  27. Aug 6, 2021 at 9:31 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    SDHQ brackets look solid, but that is definitely a lot more trimming than I did with my Nilight light bar.
    All I did was cut the 3 brackets behind the bulge and drilled 2 holes for the light bar bracket.
  28. Aug 21, 2021 at 8:02 PM
  29. Aug 21, 2021 at 8:08 PM
    memario1214
    Colton
    Missoula, MT
    I actually had a local customer buy my 40” bar off of me so I had to order another couple. Install is not complete as a result!
    Were you able to source a bar yourself?
  30. Aug 21, 2021 at 8:15 PM
    Yes I did actually. Got the harness today, and ordered the SDHQ brackets. I wouldn't advise someone cutting me off in the dark with one of these lol.
    20Tundra_sauce21 likes this.
