Hood bulge.
Discussion in '2.5 Gen Tundras (2014-2021)' started by kevine0001, Feb 6, 2022.
  1. Feb 6, 2022 at 8:45 AM
    kevine0001
    kevine0001 [OP] New Member
    Kevin
    In the process of painting the chrome grill surround and hood piece on my truck
    So that chrome hood piece with the thin black honeycomb screen looks like it would let wind thru. However, the hood is solid behind it. It does not let wind in. Or water and dirt I suppose.
    Wondering if anyone has drill a few small holes for additional cooling
    Like three small holes. Maybe 1/2" holes??
  2. Feb 6, 2022 at 8:51 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    If you were to take apart your hood bulge assembly, behind it would just be your hollow hood. It won't have any affect on additional cooling through the hood bulge... that's why its useless.
    1lowlife likes this.
  3. Feb 6, 2022 at 8:55 AM
    kevine0001
    Kevin
    I’m talking about drilling holes into the metal between the bulge and motor
  4. Feb 6, 2022 at 8:55 AM
    kevine0001
    Kevin
    This part…
  5. Feb 6, 2022 at 8:57 AM
    kevine0001
    Kevin
    This may be easier to see. Or are these spots cutting into something important??
  6. Feb 6, 2022 at 9:13 AM
    You won't gain anything at all by doing that.
  7. Feb 6, 2022 at 9:16 AM
    kevine0001
    Kevin
    just texted my cousin who was a Toyota tech at a dealer. I could sense he wanted to slap me. I won’t be making any more mods….
    1UP, MedCityMoto, Paul B and 3 others like this.
  8. Feb 6, 2022 at 9:30 AM
    Lol. There's alot of mods that can be done, but that wouldn't do anything at all. I have three 3.5 inch holes in mine that are for a light bar install and they don't do anything.
    Okierunner likes this.
  9. Feb 6, 2022 at 9:43 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    You're seeking a solution to a problem that doesn't exist.
    If it ain't broke, don't fix it..:thumbsup:
    There is no reason to do that.
    You may end up with a whistling noise, or worse...
    Besides that, if you start running airflow thru the hood bulge, you're gonna end up with this...
    Not my pics but I did have this problem.
    [​IMG] [​IMG]
    My 2014 hood bulge kept popping out like that.
    Come to find out the black plastic 'vent' was broken and forced air into the bulge.
    The top would 'pop out' like in the pics.
    It kept happening despite replacing the clips, even replacing the 'vent' that another forum member gave me.
    The repeated 'popping out' finally broke the bolt/nut mount on one end in the bulge.
    I tried glue, epoxy, you name it, it would never hold.
    I ended up buying another hood bulge...
  10. Feb 6, 2022 at 9:50 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    How did that happen?
  11. Feb 6, 2022 at 9:50 AM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
  12. Feb 6, 2022 at 9:51 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Best thing you can do... is add a hood bulge light there! :thumbsup:
  13. Feb 6, 2022 at 9:56 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I edited my post to explain what happened..:D
  14. Feb 6, 2022 at 10:00 AM
    That's a pain in the rear!
    pvn.beluga[QUOTED] likes this.
  15. Feb 6, 2022 at 10:13 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  16. Feb 6, 2022 at 10:27 AM
    BayRunner
    2017 Tundra Platinum
    what vent are you referring to? My bulge was popped out like that last week and I thought someone pried it out.
  17. Feb 6, 2022 at 10:36 AM
    MoToad
    MoToad New Member
    Toad
    BC Kanuckistan
    2009 Tundra DLX
    That almost looks like heat expansion and deformation.
  18. Feb 6, 2022 at 10:46 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    The fake vent black plastic insert in the hood bulge.
    It was cracked and broke inside and was allowing air into the bulge with nowhere to go.
    So it was forcing the top of the bulge to pop out like in the pics.
    The first time it happened I thought someone tried to steal it.
    Although you have to remove 3 bolts on the underside of the bulge to get it off.
    I would pop it back in and it would stay for a few days, then on the highway to go to work it would pop out again.
    I replaced the black clips (and the broken fake vent thanks to another forum member) and it stayed for about 3 months, yet eventually started popping out again.
    I pulled the bulge off again, and then I noticed on one end the speed nut mount for the mounting bolt was broken in the bulge.
    You can try replacing the clips.
    I think these are the correct ones..
    Rocker Molding Clip - Toyota (75867-AA010)
    Hood & Components for 2014 Toyota Tundra | Sparks Parts
    75867-AA010 - Rocker Molding Clip - 2002-2021 Toyota | Sparks Parts
    You can find aftermarket on Amazon, but that is what I tried and they didn't stay in after a few months.
    Amazon.com: XYZ Fasteners Rocker Panel & Scuff Plate Retainer Fasteners Clip, Compatible with Toyota 75867-AA010 (25) : Automotive
    There are several different clips like this.
    Make sure what you get looks like the black one with a single collar or whatever you call it.
    The white and green (door panel/interior trim clips) have a double collar that makes the hood bulge stick out too far giving you a gap between the bulge and the hood.....
    n591b0e9_5e4493e320f0ff6a6080054a5465768bbfa7555d.jpg lcykwgmh_9cf629192d4a8f009843d2c31225e8e5fa693901.jpg
    AggiePhil, panicman and pvn.beluga like this.
  19. Feb 6, 2022 at 1:51 PM
    BayRunner
    Thanks for the info, it is very useful. Do you remember how many of the following clips the bulge uses? Just want to make sure I order the correct amount.
  20. Feb 6, 2022 at 1:53 PM
    BayRunner
    Also, what is the process to rmove the bulge?
  21. Feb 6, 2022 at 1:56 PM
    5 on the top, 3 on the bottom.
  22. Feb 6, 2022 at 1:57 PM
    There are 3 bolts and 3 clips on the bottom, and the rest is the 5 upper clips.
  23. Feb 6, 2022 at 2:16 PM
    BayRunner
    Ok, I see the 3 bolts on the underside, but how do I access the clips? Does removing the 3 bolts allow the bulge to pop out. Don’t mean to be dense but don’t want to try anything and potentially break something until I understand the procedure.
  24. Feb 6, 2022 at 2:18 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  25. Feb 6, 2022 at 2:38 PM
    After you remove the bolts you gently pull it off...the clips will pop out.
  26. Feb 6, 2022 at 2:39 PM
    This will show you.
    https://youtu.be/xO96NngJq7w
  27. Feb 6, 2022 at 2:52 PM
    BayRunner
    Tundra234[QUOTED] likes this.
  28. Feb 6, 2022 at 2:54 PM
    No problem.
  29. Feb 6, 2022 at 3:02 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Hahaha if anything the flow into the hood crevices would create weird sounds or vibration or something like that.
    I could swear that bulge has air route down to the top of your radiator no?
  30. Feb 6, 2022 at 3:08 PM
    It does not. The screen is attached to a scoop which has no openings in it. It's basically a bowl that is screwd into the back of the bulge.
