Horn/ Clockspring
Discussion in '2nd Gen Tundras (2007-2013)' started by 82angelfan, Nov 11, 2022.
  1. Nov 11, 2022 at 4:07 PM
    82angelfan
    82angelfan [OP] New Member
    2012 Tundra 5.7 4WD
    Horn stopped working for several years. I have read that this is more than likely the clock spring. More and more I am hearing a noise when turning the wheel.
    I have also read somewhere that it could be a wire harness rubbing in steering column. Before I purchase and replace a 200 part, what are my chances that it could be the wire harness?
    Thanks
  2. Nov 11, 2022 at 6:01 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    The clock spring is a $20 part. If you want OEM then give $200. But I fixed it with the cheapest ebay clock spring. It was <20.
    So replace it. In fact use the search and see how many clockspring threads are on here.
    BTW my problem was no horn and no curise. Swapping the CS fixed my issue.
    Here is the ebay seller's name.
    snivilous and D4x4TRD like this.
  3. Nov 12, 2022 at 6:28 AM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    2012 Sr5 DC TRD 4x4 Blaaaaaack baby 4.6liter
    Blacked out front grill badge Bigger tires 305/60r18 Tonneau cover
    Sounds like your clock spring needs replacement. Get the cheaper one and follow a YouTube video for instructions. It worked for me. Same symptoms.
  4. Nov 12, 2022 at 6:55 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    The clock spring is very easy to access and test if that's the issue too. It's like two screws and the steering wheel nut, then use a puller or yank the wheel or tap the back with a hammer and it'll pop off.
    baraynavab and D4x4TRD like this.
  5. Nov 12, 2022 at 9:53 AM
    82angelfan
    thanks all. When I looked at clock springs on the net, Amazon, Rockauto, Toyota the cheap ones don't appear to support airbag. This why I looked at the 200 dollar one. the difference seemed to be one wire jack verse 2 wire jacks, I will check again.
  6. Nov 12, 2022 at 11:08 AM
    baraynavab
    Atlanta
    So @82angelfan Just thinking this out here.. If our clocksprings did not have airbag cable.. then I am sure we would get an airbag light on our car.. I am just speculating. But since airbag is a safety system of the truck I would think there would be airbag system check and anytime the system sees a disconnect in the airbag system it would bring the airbag light on.. so do you research and see what you find out.. I would like to know myself..
    D4x4TRD likes this.
  7. Nov 12, 2022 at 12:23 PM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    I got my clockspring through a link on one of the threads on replacing clockspring. It might have been through a video in the thread. My memory isn’t too great these days.my truck had air bag too. Search for the thread on clockspring replacement. Hope that helps. Good luck.
  8. Nov 14, 2022 at 8:49 PM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    baraynavab likes this.
  9. Dec 18, 2024 at 12:18 PM
    EJ_Pants
    EJ_Pants New Member
    Eric
    2011 Toyota Tundra
    3" ELKA C/O Icon Stage III Leafs BFG KO2s 35x12.5r18 Fuel Vapor 18" +20mm Line-X'd Magnum Front Bumper Warn 12-S Platinum Kenwood DMX1057XR Viper Remote Start OPT 7 Tailgate LED Bar Morimoto Headlights Rigid Fog Lights x4 AMP Power Steps Nitro 5.29 Front and Rear Gear Set Eaton Electric Front and Rear Lockers
    How is everyone's cheap CS holding up? I got a cheap eBay one and first time I turned on the truck, horn worked again, but I got an airbag light. I put the old one back in and the airbag light cleared. Seems like it was the cheap CS
  10. Dec 18, 2024 at 3:46 PM
    Thumper_6119
    2 years in with mine, and everything is still working like it should. No warning lights. I didn't get mine off of ebay, I got it off of PartsGeek.
  11. Dec 18, 2024 at 4:16 PM
    snivilous
    SW UT
    Right at 4 years the eBay one broke and replaced with another eBay unit, never had an issue with it not working out of the box.
  12. Dec 18, 2024 at 6:17 PM
    EJ_Pants
    EJ_Pants New Member
    Eric
    2011 Toyota Tundra
    Well they refunded mine today after I put my original one back in and it cleared the airbag light. I said I'd be fine to get a replacement, but they just sent me my whopping $14.00 even back.
    I'd be fine if it lasted 4 years lol, it wasn't too hard. Just nervous holding the "Front Towards Enemy" side of the airbag while removing and installing it. But right out of the box is kinda annoying. I'll have installed three clocksprings in one month
  13. Dec 19, 2024 at 6:14 AM
    baraynavab
    Atlanta
    Hey my CS is holding up just fine.. it working fine.. and its been around 2 years since I put it in...
  14. Dec 19, 2024 at 6:58 AM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    I can’t remember if it was 3 or 4 years ago I changed my clockspring with eBay model. Still holding up good. I think it’s closer to 4 years now. Hope it keeps going longer.
  15. Dec 19, 2024 at 9:49 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Ebay clockspring here too. Not nearly as long as others, just over a year, but it fixed my cruise control issue and has been flawless.
  16. Dec 19, 2024 at 11:44 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    my airbag light is on and my CC doesn't work. clock spring has been on my list for a while, probably gonna go with OEM.
  17. Dec 27, 2024 at 4:46 PM
    Stevebaseball
    Stevebaseball New Member
    Arizona
    2008 Tundra crewmax
    3” lift- 35 x 12.50 on 18” custom rims
    I did my clock spring last year- first one was junk.. paid $55 for second one and works great (my issue was horn stopped working) ..
    Remember to disconnect the battery- when changing click spring
