Horrible Handling on Washboard
Discussion in '3rd Gen Tundras (2022+)' started by Matt2015Tundra, Jan 13, 2025.
  1. Jan 13, 2025 at 5:56 AM
    Matt2015Tundra
    Matt2015Tundra [OP] New Member
    2023 1794 CrewMax
    Hey guys and gals,
    I like my Gen 3, but don't love it. Performance-wise the truck does well on pavement, tows nicely, accelerates well, and handles corning better than my previous Tundras.
    I live 7 miles from the nearest pavement, so I spend a lot of time on county roads. My biggest performance complaint is the truck is awful on washboarded dirt roads. Even at low speeds, the rear end dances around and often kicks the truck sideways to the point of being dangerous. My previous 2008 and 2015 Tundras handled the washboard much better.
    My truck is a stock 1794, non-TRD, no lift. I'm running 275/60 R20 BFG KO3 tires at around 32 psi. They are the same tires I ran on my 2015 Tundra.
    What are my options to make this truck handle the washboard better, besides sticking 600# of sand bags in the bed?
    Thanks
    camron1039 likes this.
  2. Jan 13, 2025 at 6:09 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Upgrade the rear shocks, the Bilstein 5160 remote reservoir shocks made a big difference on my '18 tundra.
  3. Jan 13, 2025 at 6:50 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Thanks, but I think your 2018 had leaf springs in the rear. Not exactly an apples to apples comparison. But I suspect upgraded shocks is the likely answer.
    Any Gen 3 owners noticed the same poor washboard handling, and have you found a solution?
  4. Jan 13, 2025 at 7:01 AM
    Nm6300'asl
    2022 DC SR5 4x4
    Yes it had leaf springs but still the same stepping out on the rear on the washboards. I just had to put a track bar relocation bracket on the 22' (due to a mild rear lift) to help correct the same issue. The stock black shocks just are not up too the task of washboard or big hits at speed.
    Txrx likes this.
  5. Jan 13, 2025 at 7:04 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Throw a couple three heavy sandbags back there.
    c&wsinbad, JJcksn12 and Hella Krusty like this.
  6. Jan 13, 2025 at 7:19 AM
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
    I found that going to 18" wheels and better tires (Continental TerrainContact A/T in 265/70-18) transformed the handling of my 1794.
    Soupbean77 likes this.
  7. Jan 13, 2025 at 7:23 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Does it get worse down the road? I.e. is managable when you start driving, but progressively gets worse?
  8. Jan 13, 2025 at 7:51 AM
    Matt2015Tundra
    2023 1794 CrewMax
    No, it's squirrelly on the washboard all the time. My restored 1981 CJ7 actually handles it better, even with it's short wheelbase.
    I do think the lack of sidewalls with the 20" wheels is part of the problem. The big diameter wheels seems like a stupid direction to go with trucks, unless they are just mall crawlers.
    CMikeB and Soupbean77 like this.
  9. Jan 13, 2025 at 7:54 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Does your truck have a rear sway bar?
  10. Jan 13, 2025 at 7:57 AM
    Matt2015Tundra
    2023 1794 CrewMax
    To be honest, I'm not sure, never looked. It's a stock 1794, non-hybrid, non-TRD, no lift.
  11. Jan 13, 2025 at 8:03 AM
    Nm6300'asl
    2022 DC SR5 4x4
    It does, the 3rd gens get them from the factory.
  12. Jan 13, 2025 at 8:04 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    @Nm6300'asl says it does. Remove it, the ride will be a bit more plushy. But switching to 18 wheels with softer tires will do much more.
    MadMaxCanon likes this.
  13. Jan 13, 2025 at 8:08 AM
    Breathing Borla
    Northern Illinois
    are those KO3 load e at at that size?
    also, I assume your older trucks had 18"s and P-rated.
    I think this is your difference right there, 20"s suck for off-roading and if you have load d or e, thats a multiplier.
    coils should be much better in this application than the leafs so I think the tires and wheel size is the place to start
    Hella Krusty and Dfrink like this.
  14. Jan 13, 2025 at 8:18 AM
    rcsbguy
    rcsbguy New Member
    Upgrade the shocks.
    Lower your tire pressure.
    Drive faster.
    Disconnect sway bars.
    Do all or do 2 of any and it’ll improve.
    Soupbean77 and Nm6300'asl like this.
  15. Jan 13, 2025 at 8:18 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    His previous trucks were without rear sway bars. They also didn't have a fully boxed frame. C-channel frame absorbs a lot of road imperfections.
    I ended up removing my TRD rear sway bar, much better log roads experience. It still didn't drive like sports car with the sway bar anyways.
    AZBoatHauler likes this.
  16. Jan 13, 2025 at 8:25 AM
    Breathing Borla
    Northern Illinois
    lower the tire pressure under the 32 he has? sidewalls will melt on those larger BFGs
  17. Jan 13, 2025 at 8:27 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Yes, I believe the KO3's are E-rated. The thing is, I ran the same tire on my 2015 Tundra without problems. It did have 18" wheels, however. I was
    hoping to avoid the expense of new wheels and tires.
    I always thought the sway bar was to minimize body lean in corners. How does it affect straight away driving on washboard?
  18. Jan 13, 2025 at 8:43 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    It reduces function of shock absorber. When one wheel goes up, it twists the sway bar, which pushes the other side up as well. The kinetic energy transfer to the frame happens on both sides, not just one. To you it feels like you hit the obstacle with both wheels.
  19. Jan 13, 2025 at 8:53 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Thanks, that makes sense. I'd hate to make highway handling worse by removing the sway bar, though.
    It really seems like the engineers missed the mark on the standard suspension of the Gen 3, at least for anything but pavement. I do like the way it handles on pavement.
    I might try upgrading the shocks, first. Not a fan of the remote reservoir shocks, however. I've had bad experiences with those in the past. What would be a good upgrade in a standard shock?
  20. Jan 13, 2025 at 9:03 AM
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    My first reaction to reading this post was the 20’s. Why Toyota, why!?
  21. Jan 13, 2025 at 9:10 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I had Bilstein 4600 stock on my gen2.5 TRD Offroad, they were good. "Upgraded" to 5100, they were much stiffer. One leaked 3 years later, both were replaced with ARB Old Man Emu, like them lot more.
    Wife's TRD PRO Sequoia came with FOX 2.5 shocks, they are good on any pavement we tried it. Multistage compression seems to be the key.
    But really you need 18" wheels and softer tires. Shock absorbers won't solve your washboard problem.
    CMikeB and Breathing Borla like this.
  22. Jan 13, 2025 at 9:11 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    1794 is for beauty, not for function.
  23. Jan 13, 2025 at 9:12 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    I find putting it in 4hi on washboards makes a world of difference.
    22whatwedo and Nm6300'asl like this.
  24. Jan 13, 2025 at 9:12 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    BAK Revolver X4S, APS I-Boards, RC bed mat, AirLift
    Especially for an "Off Road" optioned model.
    I've noticed similar twitchiness / monkey-motion from the rear axle under similar circumstances. Can't wait to ditch the 20's.
    MaineTundy[QUOTED] likes this.
  25. Jan 13, 2025 at 9:19 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Agreed. I think it was to appeal to the mall crawler crowd.
    Had I known my truck was going to handle so poorly off-road, I would have held out for a TRD Pro. But, after reading this review, I'm not so sure it handles off-road any better.
  26. Jan 13, 2025 at 10:10 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Thanks. I put OME leaf springs and shocks on my '81 CJ7 when I restored it, and I love them. The leaf springs arrived before the shocks, so I installed them, and drove the Jeep for a week with no shocks. I honestly couldn't tell much difference in the ride after installing the new shocks. So, you may be right, shocks probably aren't going solve my Tundra's washboard problem.
    Well damn, I might have to bite the bullet and buy new wheels and tires when my current tires are worn out. 20K on the current set. Hope to get at least 20K more.
    Thanks for all the responses, gentlemen.
  27. Jan 13, 2025 at 10:13 AM
    rcsbguy
    rcsbguy New Member
    I just saw he has E rated tires on 20” wheels. Possibly the worst combo to exist for dirt roads haha.
  28. Jan 13, 2025 at 10:18 AM
    LowcountryDave
    LowcountryDave New Member
    ‘23 Limited TRD
    I had 20’s on mine up until a couple months ago and replaced them with 17’s but still have the stock TRD OR suspension. Just that change made the 20-30 miles worth of state/county/hunting roads I travel on much more tolerable.
  29. Jan 13, 2025 at 10:22 AM
    Matt2015Tundra
    2023 1794 CrewMax
    This is interesting to me. I ran the same KO3 tires on my 2015 Tundra with 18" wheels, and it handled dirt roads fine. A 20" wheel, with the same sized tire, means 1" less sidewall.
    Does that 1" of sidewall rubber really make that big of a difference?
    Sleeper16plat likes this.
  30. Jan 13, 2025 at 10:28 AM
    Txrx
    Txrx New Member
    Patrick
    Bellingham WA
    2023 Silver tundra Limited TRD OR, Crew max, 5.5ft
    MX4 Tonno, Go Rhino E-boards, Method 705, BFG AT 285/75/17, Rigid amber fog lights
    That stock suspension isnt up to the task. I replaced my stock TRD shocks and springs with Dobinsion IMS and it took away a lot of the small bump jolts. Once you can keep your tread in contact with the ground you wont feel so squirmy on the washboard at speed.
