How are the 4.0 v6 engines on the 2012s?
Discussion in '2nd Gen Tundras (2007-2013)' started by NYC1stGenTun, Nov 12, 2024.
  1. Nov 12, 2024 at 5:00 PM
    NYC1stGenTun
    NYC1stGenTun [OP] New Member
    Jimmy
    2000 Tundra Black 1st Gen
    I have a 2000 Tundra with 236k and love the v8. Just had the opportunity to buy a 2012 tundra w. v6 4.0 with 100k on the clock for $4k. Any advice for these engines? They seem to be rare on the tundras so cant find much reliability reviews on these things. Are there common probs to look out for? TIA
  2. Nov 12, 2024 at 5:09 PM
    The 4.0 is a solid engine and is the same one that's in the 4Runners. However, it is too underpowered for the Tundra. I had a 2010 for just under a year and had to get rid of it and get a V-8.
  3. Nov 13, 2024 at 11:10 AM
    NYC1stGenTun
    Jimmy
    Yeah right on. As I said I have a 2000 with the 4.7 v8. I ultimately ended up buying the tundra with the 4.0 also cause for 4K at 100k it would be a good flip. Good to know its a reliable engine— maybe ill just keep her!
    Tundra234 likes this.
  4. Nov 13, 2024 at 11:52 AM
    AZBoatHauler
    So.Arizona
    The engine is underpowered but reliable. I’d be more worried about rust given the front plate.
  5. Nov 13, 2024 at 12:05 PM
    NYC1stGenTun
    Jimmy
    Frame solid, and again for 4K? No brainer for me IMG_8640.jpg IMG_8643.jpg IMG_8640.jpg IMG_8643.jpg
    Trident likes this.
  6. Nov 14, 2024 at 4:30 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    The 4.0L is one of Toyota’s most reliable engines, just a bit on the weak side (especially down low) for a larger vehicle when loaded up. If you decide to keep the truck, and want a little more out of it, swapping the rear 9.5” 3.90 diff for a 4.30 ratio will make a noticeable difference.
  7. Nov 14, 2024 at 4:32 AM
    NYC1stGenTun
    Jimmy
    Thanks for this! Helpful. Happy to hear its reliable
  8. Nov 14, 2024 at 4:34 AM
    Definitely reliable. I currently have a 2006, 2016, and 2020 4Runner all with the 4.0.
  9. Nov 14, 2024 at 4:43 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Not too bad for NY. Spray it with penetrating rust inhibitor. Also take out plugs from boxed part of the frame and slide a 360 wand with cavity wax like Noxudol 700 through it.
  10. Nov 14, 2024 at 4:43 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Gen 2 didn't have bad engines.
    NYC1stGenTun[OP] likes this.
  11. Nov 14, 2024 at 6:13 PM
    NYC1stGenTun
    Jimmy
    So just go under and spray the whole frame with the stuff? Also boxed part of the frame? Not sure what you mean but thanks
  12. Nov 14, 2024 at 6:25 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Cavity wax for enclosed space, like inside the boxed frame. C-channel frame and outside of boxed frame spray with something less sticky, or it will attract dirt, which attracts moisture, etc.
  13. Nov 14, 2024 at 6:31 PM
    NYC1stGenTun
    Jimmy
    Great got it. Thanks
  14. Nov 14, 2024 at 6:32 PM
    NYC1stGenTun
    Jimmy
    I see 3M has a good cavity wax with application straw, but whats good for directly on exterior of frame?
  15. Dec 12, 2024 at 9:24 PM
    v-eight
    v-eight New Member
    2013 Tundra Rock Warrior CrewMax
    My old truck was a 2009 Tacoma with the 4.0, just sold it a few months ago with only 90k miles. Even though it is a bit on the weaker side compared to the 5.7 (obviously), that engine was reliable as hell and I had zero issues with regular maintenance. On the other hand, I didn't even know Toyota made the older Tundras with a V6 :eek2:
