How do you test the power steering vacuum line?
Discussion in '1st Gen Tundras (2000-2006)' started by Aerindel, May 27, 2024.
  1. May 27, 2024 at 2:39 PM
    Aerindel
    Aerindel [OP] New Member
    Montana
    I noticed last night at the gas station, that my truck was idling at 1100 rpm, fully warmed up, no AC.
    I also notice there is no RPM jump when I turn my steering wheel.
    Does this mean that air line I've heard about to the steering rack is leaking? what is the test and fix.
    Thanks for any help.
  2. May 28, 2024 at 12:08 AM
    You may want to test the power steering air control valve?
  3. May 28, 2024 at 12:16 AM
  4. May 28, 2024 at 2:39 PM
    Aerindel
    Montana
    Well, it does drop RPMS by about 100 when the line is pinched at full lock.
    But the end of the hose where it attaches to the manifold is heavily cracked so I am thinking there is a vacuum leak there which would have the same effect as letting a little extra air in to bump up the RPM so I'm gong to look into that.
    shifty`[QUOTED] likes this.
  5. May 29, 2024 at 6:30 PM
    Aerindel
    Montana
    The problem I am having now is that I'm having no luck finding the part for sale. Maybe I should just use generic vacuum line?
