How lock doors with engine running
Discussion in '3rd Gen Tundras (2022+)' started by Tb2, Aug 17, 2023.
  1. Aug 17, 2023 at 9:58 AM
    Tb2
    Tb2 [OP] New Member
    James
    Is it possible to leave truck running and lock doors . It’s real hot and I leave a dog in truck sometimes and don’t want to leave truck unlocked .
  2. Aug 17, 2023 at 10:19 AM
    genchi genbutsu
    genchi genbutsu New Member
    '22 218 Tundra TRD Sport
    Have to pull the key out and manually lock/unlock the door
  3. Aug 17, 2023 at 10:28 AM
    Tb2
    Tb2 [OP] New Member
    James
    Ok thank you never thought of that
  4. Aug 17, 2023 at 10:30 AM
    Twin2turbo
    Twin2turbo New Member
    Pacific NW
    2023 Hybrid MGM Platinum
    This works. Just remove the key from the fob and manually lock/unlock.
  5. Aug 17, 2023 at 10:34 AM
    EmergencyMaximum
    EmergencyMaximum New Member
    I do it all the time when warming up vehicle. The depressing part is you have to utilize two keys all the time and that's twice the risk of losing a set.
    Kap1 likes this.
  6. Aug 17, 2023 at 10:48 AM
    Twin2turbo
    Pacific NW
    I don't understand why you need to utilize 2 keys. I only use 1 key. After manually locking the door, I walk away with the key and fob in my pocket. The truck will run for an hour without the fob.
  7. Aug 17, 2023 at 10:54 AM
    EmergencyMaximum
    I have 2010 work package, new generation gang wouldn't understand.
  8. Aug 17, 2023 at 6:39 PM
    mcnabb100
    mcnabb100 New Member
    I wonder if hitting the door lock button on the door would work after you’ve already opened the door? I’d go try it real quick but I’m at work.
    chaztizer likes this.
  9. Aug 17, 2023 at 7:34 PM
    EmergencyMaximum
    If engine is running it will automatically unlock right away, unless doors are all closed.
  10. Sep 29, 2023 at 11:53 AM
    Madlion
    Madlion New Member
    Stuff like this make me miss my 2017 ram limited
  11. Sep 29, 2023 at 12:59 PM
    Sixty9Four20
    Sixty9Four20 TRD is not a trim
    2023 TuRD Pro
    I didn’t spend the money to just swap out stuff.
    stuff like this makes me miss comprehension.
  12. Sep 29, 2023 at 3:15 PM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    On our old Honda, we would pull the door handle (inside the vehicle) to open while simultaneously hitting the lock button and it would lock the door.
  13. Sep 29, 2023 at 4:41 PM
    Sixty9Four20
    2023 TuRD Pro
    No.
    Once you start the truck normally using the fob, you are not able to use the app for safety reasons.
  14. Sep 29, 2023 at 4:43 PM
    overl4nd
    overl4nd New Member
    Shut down the truck after turning on AC , walk out, start with remote start on app?
  15. Sep 29, 2023 at 5:51 PM
    KiloOps
    KiloOps New Member
    Dustin
    2023 Army Green Tundra Limited TRD Off Road
    Purchased the truck on Jun 10, 2023, modifications will be made!
    It is incredibly stupid that you can't leave the truck running and lock it with the key fob as you walk away. I did that all the time with my F-350. What exactly is the logic behind making it difficult to lock the truck while running when the key is not inside?
    Vicious and Madlion like this.
