How long do OEM shocks last? Specifically the yellow/blue shocks that come on the TRD off-road
Discussion in 'Suspension' started by NickG, Jun 19, 2024.
  1. Jun 19, 2024 at 10:54 AM
    NickG
    NickG [OP] New Member
    Nick
    2009 Toyota Tundra Limited DC 5.7L
    I’m asking because I’m pretty darn amazed at how this truck rides with these yellow/blue original shocks at over 270k miles. There’s no way these shocks has ever been replaced considering how they look and by looking at the service history. The only time I hear something is when I go over extremely rough terrain , where it’ll at most chirp. Anything that makes the suspension really flex, I’ll hear a slight chirp noise and it’s not that typical squeaky squeak noise either. There is no noise over small or large bumps. Speed bumps=yes, off road terrain that has dips=yes
    I know at some point, I need to do a suspension overhaul. Replace the shocks, coil springs, control arms, and some of the steering components. I’m sure most of you have upgraded shocks, probably the more superior Bilstein shocks.
  2. Jun 19, 2024 at 11:14 AM
    Guaranteed that they are worn if the have 270K on them.
    NickG[OP] likes this.
  3. Jun 19, 2024 at 11:49 AM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    My shocks did the same chirp that you are describing. I pulled them off at 143K and was pretty shocked that my ride actually got a little harsher, at low speeds, with the shocks that I chose. When the Blue and Yellow offroad shocks wear out they seem to give a softer ride on the street which is both good and bad in certain situations. I started doing some light offroading with the Blue and Yellows and off any drops/ quick dips I would blow straight through the shock and bounce off the bump stop which drove me to new suspension. The upgraded Bilsteins will likely stiffen up any low-speed driving that you do but at about 45-50mph and above they should smooth back out and you won't notice a harsh ride.
  4. Jun 19, 2024 at 12:56 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    OEM Bilstein or Hitachi shocks "generally" last about 60k before they start to lose their ability to compress and rebound properly.
  5. Jun 19, 2024 at 12:58 PM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Lifespan of most shock oil will be about 50k miles
  6. Jun 19, 2024 at 1:00 PM
    NickG
    Nick
    Well, I must say that the ones on my truck are way overdue. They haven’t leaked as far as I seen and ride quality is ok except for when I’m driving on certain parts of the highway.
