How Much Oil Do You Burn in Your 4.7 ?
Discussion in '1st Gen Tundras (2000-2006)' started by HBTundra, Apr 30, 2022.
  1. Apr 30, 2022 at 9:04 PM
    HBTundra
    HBTundra [OP] New Member
    2006 DC 2wd
    I'm almost to 7K since my last oil change on a 2006 4.7 DC.
    I used the factory filter, & Mobil 1 Synthetic 5/30.
    I'm pretty damn sure I got it to the right level, (flat garage, cold motor etc.) when I did it. (may have missed something)
    Heading on a road trip in the am, & I was about a 1/2+ quart low.
    My driving habits aren't 'normal' . . . lots of stop & goes, good amount of 'idling', then semi-long road-trips pulling a small boat for around 600 + or - miles.
    Just curious what others here are experiencing.
    PS . . . Motor has 66700 miles on it.
    Edit - oil on dipstick looked really clean, not that it means anything, but it's def. not sludged, black, or 'weird'. Truck runs 100%. Nothing funky.
  2. Apr 30, 2022 at 9:15 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Less than 10% loss of oil after 7K and no other symptoms. I'm surprised you noticed. I wouldn't. Maybe that's not normal but I would not know.
  3. Apr 30, 2022 at 9:20 PM
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    2021 platinum crew cab
    Had an 04, burned about a half court between oil changes. Think I read in the manual that was normal
  4. Apr 30, 2022 at 9:25 PM
    Blueranger501
    Blueranger501 New Member
    Yeah…..original owner 160k now never burns oil.
    That said my 2002 330i would do a qt between changes, no big deal keep an eye on it.
    HBTundra[OP] likes this.
  5. Apr 30, 2022 at 9:27 PM
    Mr Badwrench
    Mr Badwrench New Member
    Check your pcv valve. A half quart is not terrible though. Not even bad for 7k
    txagg, Mogo Gogo and HBTundra[OP] like this.
  6. Apr 30, 2022 at 10:13 PM
    HBTundra
    2006 DC 2wd
    Thanks guys for the feedback . . . really like this truck & can't afford a new or newer one (& honestly don't want one) . . . just wanna make sure I don't shlep-up.
    I'll look into the pcv valve.
    Thnx Again.
  7. Apr 30, 2022 at 10:23 PM
    Aerindel
    Aerindel New Member
    Montana
    320k, No enough to be worth measuring at a normal 3K oil change....and its still light honey colored at oil changes. A half quart in 7K is....insanely good. Plenty of brand new cars consider 1 quart per K normal. Relax.
  8. May 1, 2022 at 6:40 AM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    I use the same oil and filter as the OP, I change every 5K miles, usually about 18 months between changes with no noticeable oil use. I've never gone more than 5K though. But 1/2 quart in that amount of miles is fine in my book
    Double DC and FrenchToasty like this.
  9. May 1, 2022 at 7:31 AM
    Schcoman
    Schcoman From behind the Redwood Curtain
    Humboldt Co. CA
    2000 Access Cab 4.7L V8 4x4 SR5
    None
    I have a 2000, 4.7L 4X4 with over 240K miles on it. I use conventional oil and Toyota filters. Oil changes @ 3-5Kmiles. Burns absolutely NO oil. I drive mostly highway, about 35 miles a day, every day. (I like to change the PCV pretty regularly and use Lucas upper cylinder fuel treatment every other tank or so).
  10. May 1, 2022 at 10:56 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Never bothered to measure. I do know that instead of putting in the 6.5 quarts as stated in the owners manual during my 5k oil change, I use 7 instead if that matters.
  11. May 1, 2022 at 11:17 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Mine doesn't burn any that I can tell. Our 02 Corolla would burn a court every 3k but the Tundra and RAV4 do not.
  12. May 1, 2022 at 12:27 PM
    I lost over half a full quart with my recent valve cover leak and I've got less than 2k since the last oil change, if you want some reference.
  13. May 1, 2022 at 2:31 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    300k, 10k mile oil changes. I maybe burn 1/2 a quart.
    OEM Filters, Kirkland Synthetic 5w-30
    txagg likes this.
  14. May 1, 2022 at 3:05 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    All your fluid levels, including oil, looked good before leaving on that 600 mile trip, correct :)
    Being semi sarcastic....my youngest son, who was taught at young age to periodically check fluids, recently learned the hard way when not checking fluids before a trip to the coast.
  15. May 2, 2022 at 5:10 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I don't have an oil catch can on my Tundra, but when I had one on another vehicle, the fluid that accumulated was a mix of oil, water, and presumably combustion gases. It was horrible looking stuff... and nothing I would dump back into my crank case.:eek2:
    5N0W808, Darkness and Jack McCarthy like this.
  16. May 2, 2022 at 5:45 AM
    tundrainsc
    tundrainsc Happy Tundra 1st Gen
    06 Limited 4.7 2WD
    My 06 4.7 with 167 k drops approximately 1/2 to 1 qt between changes at 18 months and 5k miles. I believe most maybe all that drop is due to valve cover leak. Last oil change i used valvoline high mileage oil. My plan is to go through another oil change to give the valve cover gaskets a chance to expand with the high mileage oil.
  17. May 2, 2022 at 8:05 AM
    DJS Tundra
    DJS Tundra Lots to learn
    South Alabama
    2002 White Lmt 4x4
    Tundra rain why not change the valve cover gasket’s? It’s super easy on these even if your just a little bit of a diy’er.
    Mogo Gogo and bmf4069 like this.
  18. May 2, 2022 at 10:47 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I 2nd that. Easy job and cheap parts.
    Mogo Gogo likes this.
  19. May 3, 2022 at 9:06 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I’ve never had to add a drop in 250k miles. Walmart synthetic and fram filter at 3-5K intervals
    txagg likes this.
  20. May 3, 2022 at 9:07 AM
    Practically no oil loss between annual 7k mile oil changes. Think my rear main seal might be a little leaky. Doesn't leave a drop on the floor so it doesn't count.
  21. May 3, 2022 at 7:59 PM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    Our trucks are notoriously easy on oil. I would just check it every 3k or so, to be sure its not getting worse. PCV is a great idea, just swap it out as cheap as they are. I've done about 3k on mine with no loss of oil showing, that's with leaking valve cover gaskets I just changed. Now that I think about it, pretty sure mine is making oil
    5N0W808, alb1k, bmf4069 and 3 others like this.
  22. May 4, 2022 at 2:22 PM
    Aerindel
    Aerindel New Member
    Montana
    That reminds me yeah....I also have leaking valve covers, but I don't lose enough even with a known leak to be able to measure the loss between 3K oil changes.
    If only my wife's subaru was that like that. Zero external oil leaks, but uses a quart every 300 miles.
    Darkness, 5N0W808 and HBTundra[OP] like this.
  23. May 4, 2022 at 2:35 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    That's a lot. You may wanna get that checked. :D
    Aerindel[QUOTED] likes this.
  24. May 4, 2022 at 8:44 PM
    Aerindel
    Aerindel New Member
    Montana
    Yeah, I checked it. Yup....thats how much it uses...Don't know what to do about it but buy another engine. I'll get around to it one of these days. As it is, oil is really cheap compared to engines so I'm in no hurry. Runs great otherwise.
    Darkness likes this.
  25. May 4, 2022 at 8:57 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Wait, really? That wasn't a typo?
    FirstGenVol, Mogo Gogo and Darkness like this.
  26. May 4, 2022 at 11:58 PM
    Aerindel
    Aerindel New Member
    Montana
    Sometimes more like 250.
    Yes really. Its not something I'm super happy about, but like I said, with the choice being $3 of oil once a week vs buying a new engine and installing it I can live with the extra cost of buying a quart of oil with every tank of gas for now.
    I don't actually know what is wrong with it, presumably ring issues or valve seals but either way a major repair to fix something that worst case costs about $150 extra a year to deal with.
    Kinda puts oil consumption in perspective when you look at it like that. There is almost no oil leak or consumption that is actually worth fixing when you price it out.
    Mogo Gogo and bmf4069[QUOTED] like this.
  27. May 5, 2022 at 12:45 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Hopefully your state doesn't care about smog checks, that can't be good for your cats.
  28. May 5, 2022 at 1:09 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    My oil level drops about an 1/8 inch on the dipstick when I do my changes at 4k miles. Valvoline white bottle and walmart toyota filter.
    Mr Badwrench, Mogo Gogo and BubbaW like this.
  29. May 5, 2022 at 1:58 PM
    Aerindel
    Aerindel New Member
    Montana
    The cats where toast 10 years ago, before I even bought the car and long before it started using oil. Yeah, my state doesn't care.
    Darkness[QUOTED] likes this.
  30. May 5, 2022 at 2:31 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    that don't count ;)
    Jack McCarthy and Aerindel like this.
