How to get factory XSP-X sticker off side panel
Discussion in 'General Tundra Discussion' started by Woodguy65, May 13, 2018.
  1. May 13, 2018 at 1:46 PM
    Woodguy65
    Woodguy65 [OP] New Member
    So it's 90 degrees today, I've got braided fishing line and Goo Gone, got wild hair and decided to debadge my black truck.
    It was going great until I got to the Butt Ugly XSP-X sticker. I figured the heat and some goo-gone would take off but Iveas wrong.
    So any tricks to get the stickers off? Maybe 3M ERASER TOOL?
    Thanks.
  2. May 13, 2018 at 2:45 PM
    15whtrd
    15whtrd Mr. Blonde
    Besides picking at it like you have. It sounds like it’s hot enough so the heat gun wouldn’t do much I bet. 3M eraser sounds like a good idea. Have you tried laying a googone soaked rag on it to hopefully soften it up?
  3. May 13, 2018 at 2:55 PM
    Woodguy65
    Have not tried the rag but have repeatedly sprayed it - to no avail. LOL
  4. May 13, 2018 at 3:01 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    3M Eraser Wheel should work. I removed my pin stripes with it. Once off I removed remaining remnants with finger nail polish remover. You will have to eventually give it a good buff and wax.
    15whtrd likes this.
  5. May 13, 2018 at 3:16 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    I used a hair dryer to heat just ahead of where you are peeling. My tss decals came right off.
    geno0506 likes this.
  6. May 13, 2018 at 3:18 PM
    15whtrd
    15whtrd Mr. Blonde
    That’s a good idea. But I bet his is more baked on because it’s black.
  7. May 13, 2018 at 3:56 PM
    Woodguy65
    I think I will get one of those 3 M eraser tools - are there different kinds of the 3 M eraser?. In other words do some take off stickers and decals - vs another type that takes off pin stripes and whatever. I assume its one tool that does it all.
  8. May 13, 2018 at 4:12 PM
    rons23
    Ron
    Kill Devil Hills
    Yes. Check out ebay, they are cheaper than buying straight from 3M . That's where I got mine and free shipping.
  9. May 13, 2018 at 4:19 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
  10. May 13, 2018 at 8:05 PM
    DecalsByDesign
    DecalsByDesign Vinyl Connoisseur
    Eagle, CO
    2019 Quicksand Limited Double Cab
    Toytec Performance Aluma 2.5 Kit Nitto G2 295/70-18 Method MR306 18x9 +18 Kenwood DDX6906s Carven TR Muffler w/ Y-Pipe
    If you’re not careful with a 3m eraser you can go right through your paint!! Be careful if you go that route. I’ve heard of lots of people struggling to get these and TRD stickers off. I personally just give it a good amount of heat with a heat gun and it comes off in one piece. How much do you heat it up?
    Soupbean77 likes this.
  11. May 13, 2018 at 8:31 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I used this on the thick gummy gray badge glue, should shred that sticker right off. Heat the sticker with a hair dryer or heat gun first. I didn’t know those wheels can damage paint, I attached it to a cordless drill and went gangbusters, paint unaffected.
    https://www.amazon.com/dp/B00VFACQRE/ref=cm_sw_r_cp_api_i_Dgq-AbERWRA58
    rons23 likes this.
  12. May 13, 2018 at 8:35 PM
    ZPMAN
    Minnesota
    I use this, it will soften it up plus remove excess sticker residue.
    DecalsByDesign likes this.
  13. May 14, 2018 at 5:02 AM
    Woodguy65
    I didn't use a heat gun, just left it outside in sun for about 5 hours in 90 plus degree heat. It was almost too hot to touch.
  14. May 14, 2018 at 7:02 AM
    DecalsByDesign
    Eagle, CO
    When I remove wraps for a company I work with, I have to heat it up with a blow torch and make it too hot to touch to get any of it off. I do not recommend using a blow torch on your truck but I do think if you gave it a little more heat it should come off no problem. Too hot to touch is good.
  15. May 14, 2018 at 7:06 AM
    DecalsByDesign
    Eagle, CO
    Yea they can be hooked up to corded drills and grinders as far as I know. I've seen paint damage from them but who knows how hard they were getting after it. It is definitely a good tool. I prefer my hands but takes much more patience and is way less fun lol.
    ^^ Way better alternative to goo gone, I don't think goo gone works at all personally. Smells nice.
  16. May 14, 2018 at 7:17 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I use a heat gun in a waving motion but use my hand in work glove as a gauge. If I can feel it, I stop, don’t want the paint to blister.
  17. Oct 22, 2023 at 10:59 PM
    DavidColemanFL
    DavidColemanFL New Member
    David
    2016 Tundra 4x4 crew max
    I bought that vinyl decal removal tool off Amazon. Holy crap. It's awesome. Took my 10 minutes and done to remove both xspx decals. Thanks for the tip!
