How to Install | Replace Toyota Tundra Fog Lights Bulbs?
Discussion in '2nd Gen Tundras (2007-2013)' started by Alla_Lighting_Auto_LED, Jul 3, 2020.
  1. Jul 3, 2020 at 11:09 AM
    Alla_Lighting_Auto_LED [OP] Alla Lighting Automotive LED Bulbs
    14722 Yorba Ct Chino, CA91710
    2017 Toyota Tundra
    Upgrading Stock Halogen Fog Lights to LED Fog Lights in Toyota Tundra
    If you have been curious to see what it takes to upgrade your outdated halogen fog lights to after market LED fog lights in your Tundra... then we say LOOK NO FURTHER! In a few easy steps you are guaranteed to see a difference after placing ALLA Lighting LED fog light bulbs in your vehicle.
    LET'S GET STARTED...
    STEP 1: Gain access to your fog light housing by pulling back on vehicle fender line
    STEP 2: Twist stock bulb counter clockwise and remove from fog light housing
    STEP 3: Push down on clip to remove stock bulb
    *stock halogen bulb + LED bulb tabs alignment*
    STEP 4: Connect LED fog light bulb into vehicle's wiring harness
    STEP 5: Insert LED bulb in fog light housing and twist clockwise to lock into place
    INSTANT RESULTS!!
  2. Jul 3, 2020 at 12:55 PM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    Since you're asking -- assume your audience are morons when making a walk-through and start right from the start sadly. Introduce what you will be using and if any tools may be required. Show the loosening of the bolts in the fender and even explain the benefit of turning the tire to the correct direction.
    The more broken down the better for people to follow step by step and if your viewer feels more comfortable it may increase the likelihood that they made a purchase or attempt the mod itself.
    Not sure if that's why you're asking but this is just my .02
