How to know if it's the belt tensioner/idler pulley vs. water pump
Discussion in '2nd Gen Tundras (2007-2013)' started by PresidentsDad, Jan 31, 2023.
  1. Jan 31, 2023 at 10:30 AM
    PresidentsDad
    PresidentsDad [OP] New Member
    Marcus
    2010 Silver Sky Metallic Double Cab SR5 4x4 5.7L
    New accelerator pedal
    Hey folks. My truck is a chirpin'. Is there a way to tell if it's belt tensioner/idler pulley or the water pump? Truck has 182k on it, no idea if any of these parts are original (I doubt they are). Appreciate the help.
  2. Jan 31, 2023 at 10:56 AM
    Chuy!
    Chuy! New Member
    Lakeside, CA
    2007 Tacoma 4X4
    You can take the belt off and spin each pulley/bearing. They should spin smoothly and without any play. Although I believe it’s normal for a PS pump pulley to have a little fore/aft play.
    Alternatively, try the acoustic method.
    https://youtu.be/fHtLH_m9gN4
  3. Jan 31, 2023 at 11:01 AM
    Ricos
    Ricos New Member
    Ricardo
    2010 Tundra SR5 White Widow
    Never stopping ...
    Spray silicon spray while it’s running on the belt, fast and easy way to find out it’s the belt.
    Mine sometimes does make the chirp while it is pooring rain and stormy winds, everything is new on mine, just a quick way to check if it’s the belt, the chirp will come back quick but will disappear when you spray on it
    Chuy! likes this.
  4. Jan 31, 2023 at 11:09 AM
    Chuy!
    Chuy! New Member
    Lakeside, CA
    2007 Tacoma 4X4
    Good point, forgot to cover that it could be the belt. With that many miles, and not knowing what’s been replaced, I would replace the belt and pulley bearings.
    chugs and Ricos like this.
  5. Jan 31, 2023 at 11:17 AM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    I would definitely pull the belt off, inspect it, and turn each pulley by hand.
  6. Jan 31, 2023 at 11:18 AM
    PresidentsDad
    Marcus
    Thanks y'all, I'll try that acoustic method. Ahead of that though, what does a failing water pump sound like? (It's not leaking).
  7. Jan 31, 2023 at 3:53 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    A rumble or grinding sound. The sound of shot bearings or the impeller rubbing the housing. That’s would I would listen for.
    If the water pump is on the way out the door the truck may show signs of overheating after running for a while.
    My truck started squeaking and chirping pretty bad. A new Toyota belt fixed this. Definitely spin all the pulleys by hand and make sure they feel smooth.
  8. Feb 1, 2023 at 11:06 AM
    Chuy!
    Chuy! New Member
    Lakeside, CA
    2007 Tacoma 4X4
    A failing water pump can sound like any other bearing going bad, but keep in mind if a fan clutch is connected to it, it also has a bearing although it is not serviceable.
  9. Feb 28, 2023 at 12:04 PM
    Slim Gym
    Slim Gym New Member
    2013 Tundra DC 4X4
  10. Feb 28, 2023 at 1:07 PM
    Rocko9999
    Rocko9999 New Member
    $6 mechanics stethoscope from harbor freight.
  11. Feb 28, 2023 at 3:40 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I can probably tell you about the water pump, since mine just went. It'll start leaking before it makes any type of noise. At 182k its probably all original tbh, I've posted a video on a bearing sound on here somewhere, and the water pump had just started leaking... I'm at 270k and I just replaced the original tensioner, idle bearing, water pump and radiator. I would look at your water pump and check if it's leaking down on the skid plate or look at the engine block right by the oil filter housing, depending on if its leaking and how long it will be noticeable, if it's a small stream, it's probably something else. Check for condensation in the belt, if you suspect the belt, I would go with a gator back belt, its pricey, but evacuates condensation more efficiently.
  12. Jun 11, 2023 at 11:17 AM
    Slim Gym
    Slim Gym New Member
    2013 Tundra DC 4X4
  13. Jun 12, 2023 at 1:58 PM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    I would NOT recommend spraying the belt with silicone. The intent is to not slip. It's not a wet clutch on bike!
    I use dish soap and water. Initially it will make it squeak worse as its acting like a lubricant and then clears up.
    They do make belt dressing product to minimize slip and reduce noise if you isolate it to the belt and nothing needs replaced.
  14. Nov 2, 2023 at 12:36 PM
    Slim Gym
    Slim Gym New Member
    2013 Tundra DC 4X4
