How to program a new key fob for my 2004 Sequoia SR5
Discussion in 'Sequoia 1st Gen (2001-2007)' started by OG2004, Aug 25, 2023.
  1. Aug 25, 2023 at 4:07 PM
    OG2004
    OG2004 [OP] New Member
    2004 Sequoia SR5
    I’m the original owner of a 2004 Sequoia SR5. Both of my key fobs don’t work anymore. I’ve tried Autozone, 3rd party vendor and even my local Toyota dealership but none of the could get my vehicle into program mode. I was told by my local West Coast Dealership that since I purchased the Sequoia in Georgia that they can’t help me and recommended I contact the Dealership in Georgia. I called them and was told that model key fob is no longer available. They suggested I try finding it on eBay or other online site. The model number is 00016-0c060-01. They also provided me a copy of the Keyless Entry System manual. We still couldn’t get my vehicle into programming mode. Has anyone had a similar problem, if so did you find a solution. I’d appreciate any help. Mahalo!
  2. Jan 18, 2024 at 12:55 PM
    judsonw
    judsonw New Member
    If you haven't found a solution, I have used these steps several times to reprogram new fobs:
    1. Start with key out of ignition, driver’s door is open all others closed and driver’s door is unlocked.
    2. Insert key into the ignition (Do NOT Turn) and Pull key out.
    3. Perform these steps within 40 seconds.
    A. Using the power lock switch on the driver’s door, perform 5 lock/unlock cycles starting with lock. Use an even
    pace and try to go about one cycle per second. (1 Cycle = 1 lock and 1 unlock).
    B. Close, then open driver’s door.
    4. Perform these steps within 40 seconds.
    B. Insert the key in the ignition cylinder.
    C. Turn the ignition to ON (Do NOT Start) then back to OFF once to program remote while retaining the original
    remote codes. Twice to erase all original codes and add new remote. Three times to check how many remotes are
    programmed or five times to erase all original codes.
    D. Remove the key from the ignition.
    5. Within 3 seconds the power door locks should cycle automatically indicating successful entry into programming
    mode. Return to step 1 if the locks do not cycle at this point.
    6. Perform these steps within 40 seconds.
    A. Press the lock and unlock buttons on the remote simultaneously for 1 second.
    B. Immediately after letting go of the lock and unlock buttons, press the lock button itself and hold for 2
    seconds. Within 3 seconds, the door locks should cycle once indicating successful programming. If the door locks do not cycle,
    or cycle twice. Repeat steps A and B in step 6 as your remote has not been accepted.
    C. Repeat steps A and B in step 6 for each new remote.
    7. Close driver’s door.
    Good luck!
  3. Apr 18, 2024 at 9:35 AM
    NateB04
    NateB04 New Member
    Nathan
    04 Sequoia 2wd
    Electric radio fan After market radio and speakers.
    I have the same issue and tried that but to no secess. Any help would be great
