How to replace a broken electrical ( taillight ) connector
Discussion in '1st Gen Tundras (2000-2006)' started by Serge928, Apr 23, 2023.
  1. Apr 23, 2023 at 8:12 AM
    Serge928
    Serge928 [OP] New Member
    Serge
    2005 Grey Double Access 4wd SR5 4.7L
    Hi,
    Yesterday replacing my taillight bulbs I noticed the connectors were very brittle. I tried replacing bulb very gingerly but the connector still broke and now doesn’t hold the bulb.
    I already searched the forum for instructions to either change the connector (preferred) or harness but didn’t have any luck. What is the best way to replace connectors? Once I remove would I need to solder the new connector?
    Thank you
  2. Apr 23, 2023 at 3:35 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Serge928[OP] likes this.
  3. Apr 23, 2023 at 9:15 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    tvpierce, Festerw and Serge928[OP] like this.
  4. Apr 24, 2023 at 7:44 AM
    If I remember right based on mine, the tail light (driver's side at least) originates at a combination connector at the bottom corner of the bed, then routes its last 12-18" up into the housing area. I'm sure you can hit the electrical section of the Toyota Parts website and find a replacement sub-harness. I doubt it's more than $50-60 and should tie you over for another 15-20 years...
  5. Apr 24, 2023 at 7:53 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
    It is separate, but mine at least are all manual splices. I am digging into that right now on the driver side to rewire my camper shell/cap/topper.
