How to reset the Clock in the Gauge Cluster?
Discussion in '3rd Gen Tundras (2022+)' started by Spiderman1983, Mar 22, 2023.
  1. Mar 22, 2023 at 10:57 AM
    Spiderman1983
    Spiderman1983 [OP] New Member
    2022 Blue Tundra Limited TRD 4x4
    None Yet.
    Fellow 2022 Tundra Owners:
    Now that is it DST again I am going nuts trying to figure out ho to reset the clock in the instrument gauge cluster.
    The clock on the Multi-Media screen is fine.
    HELP???
    THANKS!
    Spiderman1983
  2. Mar 22, 2023 at 11:15 AM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    The multimedia display is fine because it uses your phone's date and time settings. Use the steering wheel controls to navigate to the settings on the MID (dash display). That is on my SR5 with the non-digital dash, so I don't know if it will be different for your Limited.
  3. Mar 22, 2023 at 11:35 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    The setting is in your radio/multimedia. Hit the settings (the gear symbol) then hit General, and you should see Date & Time pop up
    1lowlife likes this.
  4. Mar 22, 2023 at 11:36 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    You have a setting that turns DST on, off, or auto.
    Check that setting.
    SWB Tundra and Spiderman1983[OP] like this.
  5. Mar 22, 2023 at 11:47 AM
    nodak67
    nodak67 New Member
    JR
    or just leave it on gps setting and it will automatically change based on time zone if moving across time zones (or for those areas that dont follow DST)
    545moose and Wynnded like this.
  6. Aug 2, 2023 at 12:00 PM
    Spiderman1983
    None Yet.
    I finally had a tech @ Poway Toyota show me.
    First you need to be totally disconnected from your phone via Bluetooth & not using Apple Play.
    Then using the large screen update the time and it will send to the dash unit.
    After updated reconnect to your phone & Apple Play & all is good.
    GREATLY APPRECIATE ALL OF YOU TUNDRA FOLKS HELPING OUT
    pwpblue and (deleted member) like this.
  7. Nov 5, 2023 at 5:43 AM
    GbobbyRS
    GbobbyRS New Member
    2022 Toyota Tundra Plarinum
    Lot of complex DIY false info. Tap on the displayed time in upper right corner of the large console display. Choose: Set date & time by GPS. That is all there is to it. No tricks or complicated settings!
    Hella Krusty and pwpblue like this.
  8. Nov 5, 2023 at 7:53 AM
    xc_tc
    xc_tc New Member
    Definitely don’t need to disconnect from bluetooth or Apple Carplay/Android Auto either. If you’re in the carplay/android auto system, just tap the Toyota app on the apps screen. Then like thr post above me said, just tap the time on screen to get the time settings.
    Duckinatruck likes this.
  9. Nov 6, 2023 at 4:58 AM
    Skeeter Man
    Skeeter Man New Member
    Eric
    2022 Limited Tindra
    I have ‘22 Tundra Limited. I don’t see that I have an option for “set date & time by GPS” in my settings. My screen has correct time but not the instrument cluster. Any suggestions?
  10. Nov 6, 2023 at 7:26 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Settings > General > Date and Time > Select time zone/Daylight Savings/Set Time Automatically.
    The correct time will display on the screen and gauge cluster.
    Hella Krusty likes this.
  11. Nov 6, 2023 at 7:57 AM
    Skeeter Man
    Eric
    2022 Limited Tindra
    That’s what I’ve selected since I bought new but the cluster didn’t go back to standard time Sat night/Sunday morning. The screen did but not the instrument cluster.
  12. Nov 6, 2023 at 8:03 AM
    joescho
    joescho New Member
    Joe
    Scranton,PA
    2024 Supersonic Red Platinum
    I'm a little confused by these settings. I have the same set up as @Matt2015Tundra has (except I'm eastern TZ) and I'm confused as to why the time didn't adjust for the change to Standard time. I ended up changing my setting to turn automatically adjust off, and fix the time myself. Not worth fighting it.
  13. Nov 6, 2023 at 8:06 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Both my screen and gauge cluster changed automatically, and show the correct time with the settings I posted.
    Edit: Correction. I had to turn Daylight Savings Off to get the correct time on the screen and gauge cluster. Sorry, my bad.
    Mattedfred likes this.
  14. Nov 6, 2023 at 10:03 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    My gauge cluster time did not change. I had to go into the settings and cycle the GPS option for it to update.
  15. Nov 6, 2023 at 1:34 PM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Same in my 2024, not a huge deal but was a bit shocked the radio and cluster are independent of each other
  16. Nov 6, 2023 at 1:51 PM
    Matt2015Tundra
    2023 1794 CrewMax
    Which "settings" are you talking about? Like others have said, I don't see a GPS option on my '23 1794. I'm not running any of the connected services, though, so maybe that's the difference.
  17. Nov 6, 2023 at 4:34 PM
    Hella Krusty
    Hella Krusty New Member
    My truck changed automatically. I haven't touched my clocks since I rolled it off the lot.
    Tundrastruck91 likes this.
  18. Nov 9, 2023 at 4:46 PM
    CaptainMidnight
    CaptainMidnight New Member
    2022 Tundra SR5 5.5 ft bed
    I have a 2022 Tundra SR5 and had the dame issue with the cluster time not updating with the November time change while the big screen updated properly. The settings screen was a bit different from those described on earlier posts. I solved the issue by turning off the daylight savings selection. See photo below.
  19. Nov 10, 2023 at 5:22 AM
    Skeeter Man
    Eric
    2022 Limited Tindra
    If you no longer have the connected services subscription, CaptainMidnight post is the only way to get the cluster clock to match the screen imo.
    CaptainMidnight likes this.
  20. Nov 13, 2023 at 4:03 PM
    CaptainMidnight
    Thanks Skeeter Man. Right you are. I have chosen not to participate in subscription services. It is a shame that Toyota behaves in this manner towards customers.
  21. Nov 13, 2023 at 8:36 PM
    xc_tc
    xc_tc New Member
    I don’t have any connected services subscription and still have update time automatically. Did you opt out of all connected services?
  22. Nov 14, 2023 at 5:03 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Not correct. I've never subscribed, and my screen and gauge cluster clocks are in sync.
  23. Nov 14, 2023 at 3:21 PM
    Skeeter Man
    Eric
    2022 Limited Tindra
    You said in post #13 you turned off DST, which makes them sync. In post #16 you stated you don’t have connected services. I don’t understand where you’re going with this.
  24. Nov 15, 2023 at 6:50 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Sorry, I misread your post to say that you needed the connected service for the clocks to match. My bad.
    Skeeter Man[QUOTED] likes this.
