How to tell if it’s an acoustic windshield?
Discussion in '3rd Gen Tundras (2022+)' started by Talltugger, May 10, 2023.
  1. May 10, 2023 at 12:58 PM
    Talltugger
    Talltugger [OP] New Member
    Captain
    E WA or Pacific Ocean.
    23’ Platinum-MGM-6.5’
    I bought the truck (23 platinum) with a crack in the windshield. The dealer is replacing it tomorrow and I want to make sure it is replaced with the same glass. Is there a way to tell if the windshield is acoustic? While it’s there she’s getting Icon on the corners and some 35s! Should be a good day! Thanks in advance for the help.
    ryanwgregg likes this.
  2. May 10, 2023 at 1:04 PM
  3. May 10, 2023 at 2:26 PM
    Talltugger
    Captain
    I tried the parts search you linked above. It didn’t come up with anything. Wondering if there was some indication on the glass itself.
  4. May 10, 2023 at 2:40 PM
    Talltugger
    Captain
    Ok. If there’s nothing obvious to it, I’ll just make sure whatever numbers I can find, match up with the new one. Thanks.
  5. May 10, 2023 at 3:48 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
  6. May 10, 2023 at 6:45 PM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    I’m surprised Vitro is making the Toyota windshield. Typically Toyota uses AGC. But with tundra built in Texas and vitro being US based I shouldn’t be too surprised. The acoustics come from the PVB layer that the two pieces of glass laminate against. Usually windshield will state acoustic on the decal. I’m not seeing that but it doesn’t necessarily mean it’s not acoustic.
    @Talltugger make sure your windshield says Vitro on it. That’s the best way to ensure it’s truly factory.
    Talltugger[OP] likes this.
  7. May 10, 2023 at 7:09 PM
    Talltugger
    Captain
    Thanks guys. I appreciate the feedback. I “trust” the dealer, they have been great so far, but as always Trust but verify.
    pwpblue and Lake.Life24 like this.
  8. May 10, 2023 at 7:13 PM
    Lake.Life24
    Shawn
    Upstate, NY
    what's going on with your front door glass?
  9. May 10, 2023 at 7:14 PM
    Lake.Life24
    Shawn
    Upstate, NY
    Anytime! And if you have further questions let me know. The business I work for sells glass for car windows so I am more than happy to answer questions.
  10. May 10, 2023 at 7:17 PM
    biebs96
    PA
    So… what is an acoustic windshield? o_O
    1lowlife and Randy Morton like this.
  11. May 10, 2023 at 7:18 PM
    Lake.Life24
    Shawn
    Upstate, NY
    I would be curious the cost of that. Are the rear doors laminated? Laminating the side windows is a big trend. The noise reduction is like 10x better than a normal single ply window
  12. May 10, 2023 at 7:20 PM
    Lake.Life24
    Shawn
    Upstate, NY
    Who makes the front door window?
  13. May 10, 2023 at 7:22 PM
    Lake.Life24
    Shawn
    Upstate, NY
    ahh okay got it. Yes typically lamination triples the cost of a normal window so companies make sure the driver and passenger get that comfort
    mayan and ryanwgregg like this.
  14. May 10, 2023 at 7:27 PM
    Lake.Life24
    Shawn
    Upstate, NY
    Dang...Toyota probably buys those windows for $50 more than a regular window
  15. May 11, 2023 at 5:21 AM
    Lake.Life24
    Shawn
    Upstate, NY
    Does it mention that the Regular, Non Acoustic glass is still laminated? If it isn't laminate then Toyota is literally stealing from people
  16. May 11, 2023 at 6:30 AM
    Talltugger
    Captain
    Now I’m really going to have to trust them.
    Thanks!
  17. May 11, 2023 at 3:21 PM
    LouALouA
    LouALouA New Member
    Lou
    Central Florida
    2023 1794 Blueprint 4x4
    The glass is probably the cheapest part of the procedure. All the nanny's (ADAS) on the glass will need to be moved and aligned.
  18. May 11, 2023 at 6:52 PM
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    2023 Celestial Tundra CM TRD OR
    All windshields are laminated for the last 30 years or so. It's a safety requirement via the feds. Otherwise hitting a bird on the highway could give you a lap full of glass.
  19. May 11, 2023 at 7:26 PM
    BaldMenace
    BaldMenace New Member
    2022 Tundra SR5 Double cab
    I think a laminated windshield is required by law. The type of laminate may be different for the acoustic version
  20. May 11, 2023 at 10:33 PM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    Is that a typo, or are you finding that the acoustic front windows are cheaper than their non-acoustic counterparts?
  21. May 12, 2023 at 5:55 AM
    Lake.Life24
    Shawn
    Upstate, NY
    Sorry I should have clarified I was referring to the side windows being laminated in for the non acoustic version. But yes you both are correct, windshields are required by law to be laminated
  22. May 13, 2023 at 9:15 AM
    Bourbonator
    North ID
    '23 LE CM 6.5
    That seems backwards.
  23. May 13, 2023 at 9:37 AM
    Breathing Borla
    Northern Illinois
    dB meter before and after please if anyone changes the side windows
    if it’s a huge difference, I may be in
  24. May 18, 2023 at 1:54 PM
    mkii_turbo
    mkii_turbo New Member
    2023 Tundra Limited TRD Off-Road
    As 'luck' would have it someone smashed my passenger side front glass to help themselves to a well used jacket and a 7 year old diaper bag last night! Looks like everyone lost in this transaction.
    I have a 2023 Limited, just ordered up the Capstone acoustic glass as per the part #'s above (68101-0C050). MSRP in Canada is approximately $330, and the regular glass is a little more as expected.
    Should be installing this weekend, I'll post my results. From what I can tell all the tracks, seals, window regulator are identical between the trim levels.
    I'm going to bring my digital capliers to measure the thickness of my drivers side window glass and compare with the acoustic glass to make sure there isn't a huge difference.
    I'll keep you posted.
  25. May 18, 2023 at 4:28 PM
    Lake.Life24
    Shawn
    Upstate, NY
    I’m genuinely curious how the edge profile of the laminated window looks.
    TrimTab and ryanwgregg like this.
  26. May 19, 2023 at 10:51 AM
    TrimTab
    TrimTab Old man with a beard
    Trim
    This glass thread is interesting, so let’s make sure I understand. If the glass says Vitro on it that means it is factory and acoustic ? or is that just factory window how do you tell if the front vitro window or side windows has the sound deadening …….. i guess im confused
  27. May 20, 2023 at 2:21 AM
    Jimba
    Jimba New Member
    I have TRD pro, when they were trying to sell me warranty, they told me I have acoustic windshield, and the cost to replace is 1100$
  28. May 20, 2023 at 8:46 AM
    mkii_turbo
    So the sideglass glass changeout was a success on my Limited, replaced my broken standard passenger window with the laminated glass from the higher trim (68101-0C050).
    Took me around 90 minutes, biggest issue was trying to clean up all the broken glass from the felts, tracks and bits stuck in my rust proofing at the bottom of the door cavity. Actual installation of the new glass only took a few minutes.
    Thickness of the factory single panel glass on the drivers side is approximately 0.1995" and the replacement laminated window is 0.205" so only 5 thou difference, no issues. Tinting/glass colour appears to be the same from what I can tell.
    Auto up/down works as expected. However someting weird did happen, for a short period my drivers side switch for passenger side would not work nor would auto up/down, local passenger door switch worked fine manually. I was trying to be careful with keeping the battery disconnected when unplugging modules in the door however perhaps I got out of order, after the last battery reconnect and reassembly all is working well. I´ll scan for BCM codes later, maybe disconnected a CANBUS module with battery still applied.
    I´ll see if it makes any difference to sound level, my previous truck (2017 Titan) had laminated side glass but was by no means a quiet vehicle.
    Here is a profile shot the edge of the window for Lake.life, looks very similiar to the laminated side glass in my wifes Acura MDX and my previous Titan.
  29. May 21, 2023 at 6:35 PM
    Lake.Life24
    Shawn
    Upstate, NY
    Appreciate the photo! This is exactly what I was looking for!
  30. May 21, 2023 at 6:39 PM
    Lake.Life24
    Shawn
    Upstate, NY
    Typically manufacturers will put on the window that its acoustic but not always. So it is very difficult to know for sure, because the sound deadening is 1 of four layers in the windshield. You will unfortunately just have to take the dealers word for it. But always try to get replacement windows made by the company that does the factory. That is the best way to know you are getting the correct windshield. In this case it's Vitro for the windshield and AGC for the side windows
    Wynnded likes this.
