How to trace interior leak?
Discussion in '2nd Gen Tundras (2007-2013)' started by Nemesis, Feb 25, 2023.
  1. Feb 25, 2023 at 6:42 PM
    Nemesis
    Nemesis [OP] New Member
    The past two days we've had some heavy rain in California. After a rain break in the afternoon, instead of checking for leaks inside the house, I decided to check for leaks inside my truck. LOL
    Well, just my luck because the interior carpet lining on the rear left floor was wet. But I can't seem to trace where the leak is coming from. None of the interior door panels are wet or have signs of water leak stains. Windows were closed. Truck have not been driven in a month. I could only think of two possible things but I'm not all that confident they're the culprits. Any help/insight would be greatly appreciated. Thanks in advance.
    Leak: carpet - 1-inch soaked and only in this area
    Possible cause(s):
    1)Window seal?
    2)Roof Molding?
  2. Feb 25, 2023 at 7:02 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    The easiest way to track it down is with the trusty garden hose. Get inside and have someone blast all the areas that you posted that look questionable. Good luck.
  3. Feb 25, 2023 at 7:08 PM
    Nemesis
    True but those two possible areas I mentioned makes no sense why water would travel to that particular only and nowhere else if in fact one of them was the cause. Either way, I'll have to tear it down and see where the leak is coming from. This is why I refused to take over friend's plumbing business. No matter how much money it generates: hate dealing with water whether directly or indirectly.
  4. Feb 25, 2023 at 7:21 PM
    TILLY
    Massachusetts
    I get your points and they're all valid, but its the only way to truly track down a water leak. That's how we did it at the dealership I worked at, and pretty sure how they still do it there today. :notsure:
    Nemesis[QUOTED][OP] likes this.
  5. Feb 25, 2023 at 7:22 PM
    Nemesis
    Appreciate your input, brutha!
    TILLY likes this.
  6. Feb 25, 2023 at 7:25 PM
    TILLY
    Massachusetts
    Anytime, water leaks suck! :thumbsup:
  7. Feb 28, 2023 at 8:59 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Do you have a moonroof/sunroof?? I'd check for their drain tube that I believe leads towards the rear of the cab
  8. Feb 28, 2023 at 9:22 PM
    Nemesis
    No, I don't.
    It's raining right now and I sat in the rear for a good 30 minutes, with the channel panel off and I didn't see any water leaks or rather pudding forming. I'm really leaning toward the cause being the roof molding. But I'll have to test it when it's not raining. LOL
  9. Feb 28, 2023 at 9:28 PM
    okietundra18
    okietundra18 New Member
    Green Country
    2018 Ltd OR
    I vote; window seal leak and clogged/restricted drain at the bottom of the door.
  10. Feb 28, 2023 at 9:46 PM
    Nemesis
    Is there a drain plug at the bottom of the door?
  11. Feb 28, 2023 at 9:54 PM
    okietundra18
    Green Country
    2018 Ltd OR
    Not a plug, but usually hole(s) that allow water that enters through the exterior glass seals to exit the door cavity before it enters the cabin space. No idea where these are located on the Tundra, other than the bottom of the door.
  12. Mar 2, 2023 at 3:14 PM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    Based on the fact that it's set for a month, I'd have to say this isn't it but I'll throw it out there. When the AC evap drain plugs up, the system can overflow into the cab.
    On the Lexus IS350 forum I'm on, it manages to flood the back seat through the HVAC vent to the rear passenger area. I wonder if the Tundra is capable of that too?
    That's said, I'd be looking at the back window!
  13. Mar 2, 2023 at 3:20 PM
    KeepOnTruckin
    Randy
    Usually 3 to 4 of them, open the door and look up. Sometimes they have a flapper in them that can get debris in it and plug it up.... The intent being high water on the outside doesn't rush in.
  14. Mar 2, 2023 at 5:07 PM
    Rockwell
    Rockwell New Member
    New Jersey
    2021 Tundra Crew Max SR5
    Is it even remotely possible that no matter how sure you are the rear door was closed fully, that in fact it wasn't?
    Just a thought, If you can't reproduce the leak with a garden hose.
  15. Mar 2, 2023 at 5:13 PM
    Rockwell
    Rockwell New Member
    New Jersey
    cargo light/brake light on back of cab leaking? Where truck was parked, did it have a slight lean to the left and perhaps water came from the back of cab light fixture and found its way to left side, rear floor area?
  16. Mar 2, 2023 at 11:44 PM
    Nemesis
    It makes sense that it would be the exterior glass seal but the drain holes exit below and before the cabin. So, I'm not convinced it's the gap in the window seals. But then again, it does make sense since that's the only area that's wet. We'll see when I eventually test it with the garden hose. Eventually! LOL
    Yeah, I'm not buying that. LOL
    100% positive. Checked both nights right before it started pouring.
    No sight lean whatsoever. It was parked in my front driveway-pretty much flat. No leak behind cargo light/brake light.
    Still haven't had the chance to work on the Tundra. Busy fixing Honda Accord and remodeling house. Sheesh!
