How tough is it to install steering rack bushings?
Discussion in '1st Gen Tundras (2000-2006)' started by Alltimehigh, Nov 28, 2021.
  1. Nov 28, 2021 at 8:46 PM
    Alltimehigh
    Alltimehigh [OP] New Member
    I got the Energy Suspension ones from Amazon.
  2. Nov 28, 2021 at 8:57 PM
    SouthWestGA
    SouthWestGA New Member
    It is not that difficult,but you will need an alignment afterwards
    Be sure to mark your rack on each side of the bushings BEFORE removal so you have an idea of where they go. Otherwise,your alignment tech will have to adjust stuff more and reset the rack which costs more $$$
    Also,some people report sponginess from the poly bushings and REccomend standard black or OEM bushings
    I had the poly bushings on my old 06, and didn’t like the steering. I swapped the standard rubbers back in when i needed an alignment after more work later on.
    Sunnier likes this.
  3. Nov 28, 2021 at 9:02 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I rate it as a 2 to 3 beer job.
  4. Nov 28, 2021 at 9:05 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    Depends on if the center bolt fights you it seems. Not difficult some of us have just fought it.
    des2mtn likes this.
  5. Nov 28, 2021 at 9:08 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I watched a youtube vid and got some advice from friends on here. 2005 DC. I don't know about the Gen 2, but it's a good upgrade to go to poly bushings on Gen 1. OEM bushings are fine until they are not. Mine were fine compared to some. Directions talk about a torch to melt the stock ones to get them out. I tapped them out with a bushing or socket and a dead blow hammer. Note: at least one of them only goes one way. My steering improved. I did some other stuff at the same time, but it feels new now. Total Chaos bushings.
    des2mtn, Sunnier and Darkness like this.
  6. Nov 29, 2021 at 6:44 AM
    des2mtn
    des2mtn On the scenery looking at the road
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I agree with these two, center bolt is the most annoying part of the job.
    This video does a good job of going through the process. https://www.youtube.com/watch?v=JafzubwihDM
    dinosaur likes this.
  7. Nov 29, 2021 at 9:37 AM
    Alltimehigh
    Thanks. Im going to try to do it without removing the tie rod just like in this video. Hope it goes smooth and I dont cause a power steering fluid leak like that dude did.
    Do I really need to get an alignment after?
  8. Nov 29, 2021 at 9:44 AM
    des2mtn
    SW
    Tonto cover
    I definitely didn't touch my tie rods when I did it myself, nor did I get an alignment after.
    There are some brackets for the power steering lines on the frame that you can remove to give the rack more movement. Removing those gives the rack more movement towards the rear of the vehicle.
    Toyoda Tundra and Punk1974 like this.
  9. Nov 29, 2021 at 5:08 PM
    AWilliams
    AWilliams New Member
    Did mine 6 months ago...not a tough job but can be a PITA trying to get them in and out....got the TC poly bushings and needed an alignment after. My steering wheel was 1.5" off center. Mine weren't real bad but that tells me they were getting worn out.
  10. Nov 30, 2021 at 7:25 AM
    EvilMilkshake
    EvilMilkshake New Member
    05 AC Limited 4x4
    What did you not like about the poly bushings?
  11. Nov 30, 2021 at 7:40 AM
    SouthWestGA
    For me, the feedback was different. It was more spongy than the regular black bushings.
    Everybody’s different though it’s personal preference. I probably could have grown used to it if I kept the truck
    des2mtn likes this.
  12. Nov 30, 2021 at 8:54 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    PHM said the same thing about the energy suspension bushings. Mine were so shot when I replaced them that anything would have been better. I used the energy suspension ones.
