Hybrid Malfunction Failure
Discussion in '3rd Gen Tundras (2022+)' started by Hella Krusty, Apr 3, 2023.
  1. Apr 3, 2023 at 9:40 PM
    Hella Krusty
    Hella Krusty [OP] New Member
    Driving down the road today,....actually coasting, the truck shutters and shakes and i get this warning ........Hybrid Malfunction Failure ....power reduced, call dealer
    Pulled over cycled the power, same warning and so I drove past the dealer to make an appointment.
    They took the truck right in, 2 hours later they called to come retrieve it. Has a Hybrid Converter Failure.....new one gets installed in 2 weeks, truck is fine to drive.
    So I drive home from the dealer and it is running 100% normal.
    WTF.
  2. Apr 3, 2023 at 9:48 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    The joys of new models.
  3. Apr 3, 2023 at 9:54 PM
    axtawesomizer
    axtawesomizer ABG
    Alec
    Pullman, WA
    2001 Sequoia SR5 4x4
    Yup, first models of a new power train, coupled with the fact like 90% failures are going to occur in the first 10% of life - for any manufactured device, not just cars. Glad it's all covered though!
  4. Apr 3, 2023 at 10:06 PM
    Hella Krusty
    I was more shocked the parts are on the way LOL. I said to my wife this thing might be parked for a while
  5. Apr 5, 2023 at 6:50 AM
    bballjames
    bballjames New Member
    Inland PNW
    22 Tundra Platinum 4x4 Hybrid Crew Max 6.5ft bed
    Pretty disconcerting… was it a software bug then? Maybe a bad ECU or whatever the computer is that manages the hybrid system? I’ll be curious to hear what the fix is…
  6. Apr 5, 2023 at 10:45 AM
    Hella Krusty
    It has to be software as the truck is running 110% normal right now, so it isnt mechanical. They have some part ordered that will get installed the 20th.
    Gonna get that fake engine noise deleted the same time
  7. Jul 19, 2023 at 9:52 PM
    Vanster
    Vanster New Member
    2023 Tundra Platium iforce max
    Just got 2023 Tundra platium iforce max at 400 miles and the hybrid system malfunction message is on ‍♂️
  8. Jan 14, 2024 at 4:38 PM
    Bearsy
    Bearsy New Member
    2024 Toyota Tundra platinum hybrid
    Just put 1000 kms on 2024 Toyota hybrid platinum and my hybrid malfunction is on with other warnings like brake, check engine light, collision warning errors. Truck wouldn’t start for the longest time but then finally fired up but engine was pulsating and running rough. I’m 200kms away from dealership and wondering if it’s safe to drive or will the darn thing blow up with all those hybrid batteries? It’s -20 Celsius right now. Any advice would be helpful
  9. Jan 14, 2024 at 4:59 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Honestly. This doesn’t sound good. It seems similar to others that had bearing failure. The engine would shut off. Then wouldn’t start. After cooling off and the expanded metal parts contracted, the motor finally fired up but was running g horribly and making noise. I wouldn’t drive it as it could become a total motor failure, if it isn’t already. Hopefully it’s not the issue though
  10. Jan 14, 2024 at 5:02 PM
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    Call your dealership in the morning and tell them what's happening. They may pay to have it loaded and towed back to them to check out. I don't think I'd risk driving it there if the engine runs rough.
    EDIT: Free towing within 300 km. At least in Canada.
    https://www.toyota.ca/toyota/en/owners/warranty-and-coverage/new-vehicle
    Mattedfred likes this.
  11. Jan 14, 2024 at 6:05 PM
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    2022 Tundra Limted TRD
    This. A good dealer will come and fetch it. If they can't for whatever inexcusable reason, try getting it into some kind of nearby heated garage to thaw it out. The 40 degree swing from -20C to +20C might get it running well enough (or clear the issue) to take to the dealer, but if it's still running poorly, don't chance it.
    You will, however, have to name your truck snowflake from this point on.
  12. Jan 15, 2024 at 7:03 AM
    Bearsy
    Bearsy New Member
    lol thanks for the advice. I do have a heated garage so will try thaw it out and hopefully “snowflake” can make it to the garage safely
  13. Jan 15, 2024 at 8:13 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Can't be bearings. It's a '24.
    dbittle likes this.
  14. Jan 15, 2024 at 8:24 AM
    Bearsy
    Bearsy New Member
    Yeah I wasn’t thinking it’s bearings being a new 2024. But wondering if the malfunction will go out on its own or will have to be reset on a diagnostic computer regardless
  15. Jan 15, 2024 at 8:33 AM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    I bet it was the Ocilatingdoofilator...
    All kidding aside let us know what the problem was.
  16. Jan 15, 2024 at 8:35 AM
    Hella Krusty
    Some board in the Hybrid system is all they said. Worked fine since repair.
    In saying that I have an appointment tomorrow and am buying the extended warranty on this thing. I have had a hybrid failure and corroded wiring in 1 year.
    Blufin[QUOTED] likes this.
  17. Mar 14, 2024 at 12:10 PM
    sanchito6
    sanchito6 New Member
    Oscar
    2022 Tundra 1794 Max Long bed
    My Tundra got the hybrid malfunction light today. I drove to the dealer and they performed a software update per tsb all is good now.
    Tundrastruck91 likes this.
  18. Mar 14, 2024 at 4:50 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Heck of a first post. Welcome to Tundras.com ! How many miles and what was weather like out when it lit up ??
  19. Mar 14, 2024 at 6:52 PM
    sanchito6
    Oscar
    My truck has 38k miles and the weather was about 60 degrees out. Never had any check engine lights or hybrid malfunctions before. Truck was built on 1/22 one of the first 1200 hybrid trucks built.
  20. Mar 15, 2024 at 2:29 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    This came up on my 23. 12500km (about 8k miles). Hybrid inverter failure. In the shop and it’ll be 3 weeks before I get it back. Mine had some charging issues before though.
