Hyper Flashing Led Turn Signals. Yet Again
Discussion in '1st Gen Tundras (2000-2006)' started by tda003, Jun 6, 2023.
  1. Jun 6, 2023 at 11:04 AM
    tda003
    tda003 [OP] New Member
    Tom
    St. Simons Island, GA 31522
    2005 Tundra Access Cab, SR-5. 2-wheel drive. V-8.
    None (so far)
    I'm sure this has been updated since the 2020 thread, but my more leaks like a sieve and my computer skills ended a while back. Is there a simple change for the stock turn signal relay that will cure the hyper flashing with LED bulb switch, at least temporarily until I can add resisters to the factory unit. Original owner of a 2005 Tundra Access Cab. Senior Coffee at McDonalds isn't helping my memory.
  2. Jun 6, 2023 at 11:05 AM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    I’m running the diode dynamics smart tap relay with mine and have no issues. Have you swapped the flasher relay or you still on the stock Toyota under the dash
  3. Jun 6, 2023 at 11:26 AM
    tda003
    Tom
    None (so far)
    Still stock under dash. Do I search "Diode Dynamics Smart Tap Relay" to get this wonderful thing?
  4. Jun 6, 2023 at 11:53 AM
    tda003
    Tom
    None (so far)
    Don't know what Daytime running lights (DTRL) means. My headlights come on when the truck starts. If this is DTRL, Diode Dynamics says this isn't compatible. Thoughts?
  5. Jun 6, 2023 at 12:15 PM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
  6. Jun 6, 2023 at 1:43 PM
    tda003
    Tom
    None (so far)
    Just ordered it. Many thanks.
    2006Tundra likes this.
  7. Jun 6, 2023 at 1:59 PM
    2006Tundra
    Lou
    Long Beach, CA
    Do you know where the relay is?
  8. Jun 6, 2023 at 2:21 PM
    tda003
    Tom
    None (so far)
    As I understand it, under the driver side on the right just below the dash.
  9. Jun 6, 2023 at 2:25 PM
    tda003
    Tom
    None (so far)
    Reviving a 55-year-old skill, I may solder resisters in the stock unit as a backup.
  10. Jun 6, 2023 at 2:28 PM
    2006Tundra
    Lou
    Long Beach, CA
    Oh, I'm sure it'll be a piece of cake for you. It'll be a really easy wait to fix the hyper flash. No need to solder anything.
  11. Jun 6, 2023 at 2:41 PM
    tda003
    Tom
    None (so far)
    FWIW, I bought this new in May of 2005. SR5 Access cab165k miles, no wrecks. Only routine maintenance: oil, tires, brakes, timing belt (water pump same time), etc.
  12. Jun 6, 2023 at 5:26 PM
    Cummins3500
    Logan
    I’m little late getting back in here but it looks like @2006Tundra got ya fixed up.
    my 06 is equipped with daytime running lights as well. Mine are unplugged to run leds. The plug is beside your battery, big grey one
    1lowlife likes this.
  13. Jun 6, 2023 at 5:42 PM
  14. Jun 6, 2023 at 7:29 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
  15. Jun 6, 2023 at 7:32 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Same experience here with that same unit.
    NickB_01TRD[QUOTED] likes this.
  16. Jun 7, 2023 at 9:05 AM
    tda003
    Tom
    None (so far)
    I am amazed at all the replies to this thread. Thanks so very much. I have purchased the inexpensive adjustable unit. I may figure out how to disconnect the DTRL switch by the battery and get the Diode Dynamics Smart Tap Relay and or solder the resisters (which I have) to convert the stock unit. I, being past the McDonalds Senior Coffee age, remember how to use hand signals, but maybe not at night...
  17. Jun 7, 2023 at 10:39 AM
    2006Tundra
    Lou
    Long Beach, CA
    So far it still works for me. I've had it installed since 2018. Cheap enough to replace if/when it fails.
  18. Jun 7, 2023 at 11:47 AM
    tda003
    Tom
    None (so far)
    I'll install it as soon as it arrives. Any issues with fit?
  19. Jun 7, 2023 at 1:47 PM
    2006Tundra
    Lou
    Long Beach, CA
    Nope, pops right in. There's a speed adjuster that you tune for your liking.
  20. Jun 10, 2023 at 6:03 AM
    tda003
    Tom
    None (so far)
    Thanks for your help. The flasher arrived yesterday. I'll post w/ comments after I get it installed.
  21. May 7, 2024 at 4:07 PM
    BT2004DC
    BT2004DC New Member
    Jake
    2004 Toyota Tundra Double Cab
    Hello I know this thread is from last year but here we are. 2004 toyota tundra double cab, LED front turn signal replacement (bulbs only). I have purchased the cheap Amazon 8 pin flasher to fix the hyper flash that was listed above. LED bulbs i am using are sylvania 3157a. Issue is when replacing the bulbs i have no running lights when the headlights are turned on, but the turn signal will work and so will the hazards. Next I flipped the bulbs in the socket and the running lights work with headlights on but no turn signal or hazards. Any thoughts on this? (Headlights are LED replacement bulbs with resistors)
  22. May 7, 2024 at 4:12 PM
    I'm assuming it's the shitware scAmazon flasher. You get what you pay for. I've had zero issues with my Diode Dynamics unit. Buy once, Cry once, buy American. https://www.diodedynamics.com/smarttap-led-flasher-for-2000-2006-toyota-tundra-non-dtrl.html
    Be careful, there's no shortage of scammers selling fraudulent inventory on scAmazon and fleaBay for this specific item. I've caught and reported several already.
    BT2004DC[QUOTED] and w666 like this.
  23. May 7, 2024 at 4:40 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Not sure what the difference is between A and NA?
    But I do know that 3517 and 3157CK have different lead placements.
    Sounds like that may be the issue..:confused:
    BT2004DC[QUOTED] likes this.
  24. May 7, 2024 at 4:54 PM
    BT2004DC
    BT2004DC New Member
    Jake
    thank you all for the replies, been outside in the lovely wyoming wind fiddling with this. Turns out i over looked the daytime running lights, all of the lights function as they should once the grey plug by the battery is unplugged, as stated by cummins3500. Running lights work with and without headlights on and turn signals function as they should.
    Cummins3500 and shifty` like this.
