I broke the overflow hose nipple off the radiator - how SOL?
Discussion in '2.5 Gen Tundras (2014-2021)' started by IowaGuy, Feb 13, 2022.
  1. Feb 13, 2022 at 4:30 PM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    e radiator overflow hone nipple off the radiator near the fill cap. How SOL am I?
    It is mostly for just overflow but I also understand the it sucks in extra fluid from the container as needed. The nipple broke off just short enough that I cannot get a good grip on it and the hose with a clamp or zip tie.
    Anyone have any ideas for a fix? I thought about tapping by the little weep / drain hole and putting a some connector of some sort there?
    For now I am trying to JB Weld the broken piece on there but I am not too optimistic that will be leak free. I dont think there is any real pressure on it per say and there is no pressure on the hose as it is just a slip fitting.
    The little nipple is where the arrow is in this pic and it is facing straight forward. It is just below the cap
    516NsUEzGVL._AC_.jpg Today I broke th
  2. Feb 13, 2022 at 4:42 PM
    2mchfun
    Pics would help, as would a new radiator.
  3. Feb 13, 2022 at 4:48 PM
    daveyjames207
    daveyjames207 New Member
    Dave
    2013 SR5 DC 4x4 5.7 Off Road Nautical Blue Metallic
    Retired...finally and 2mchfun like this.
  4. Feb 13, 2022 at 4:53 PM
    2mchfun
    Yep, bulkhead fitting. Perfect solution!
    daveyjames207[QUOTED] likes this.
  5. Feb 13, 2022 at 4:58 PM
    IowaGuy
    In Process
    Pic adde din original post. Nope, the solution post dis too big. The nipple on mine is 1/2 inch. I will try to get a real pic here in a few
  6. Feb 13, 2022 at 5:02 PM
    2mchfun
    I think you may want to watch video again. I looked at the part on google, seems like it would be worth a shot for $12
  7. Feb 13, 2022 at 5:12 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Cut it off flush and put a brass threaded hose barb in it's place, until you can replace the radiator
  8. Feb 13, 2022 at 5:26 PM
    IowaGuy
    In Process
    I am going to try this. Thx
    Dr Doobie[QUOTED] likes this.
  9. Feb 13, 2022 at 6:37 PM
    Dr Doobie
    Talkeetna,Alaska
    Good luck.
    Might have to enlarge the hole a little to make it work. That's what I'd try if I were in your situation.
  10. Feb 14, 2022 at 4:50 AM
    Retired...finally
    Yep. I have a Doctorate in Backyard Hacking and a Masters in Shadetree Bolt Busting and I approve of this message. I also have a BA in Procrastinatory Arts.
    landphil, Njmike13, e30cabrio and 5 others like this.
  11. Feb 14, 2022 at 7:15 AM
    IowaGuy
    In Process
    I need to be a product testor as the Samsonite Gorilla has nothing on me. I always seem to break the strange parts and pieces where it isn't just a simple bolt from the hardware store.
  12. Feb 14, 2022 at 7:57 AM
    Deacon Blues
    Deacon Blues New Member
    2018 Tundra TRD Off Road
    This is a good reminder for Valentine's Day.
    Try not to get so aggressive on those nipples.
    Dr Doobie, 2mchfun, Jaypown and 4 others like this.
  13. Feb 14, 2022 at 8:09 AM
    daveyjames207
    Dave
    Elk hunter MUST see this post. Still snappin nipples.
  14. Feb 14, 2022 at 11:08 AM
    odin1701
    odin1701 New Member
    2021 Tundra LTD TRD OR MGM
    But what if she likes it?
  15. Feb 14, 2022 at 11:16 AM
    Deacon Blues
    Then have at it!
  16. Feb 14, 2022 at 11:18 AM
    2mchfun
    Keep her around!
    Retired...finally likes this.
  17. May 5, 2023 at 6:39 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I broke mine replacing the serpentine belt, this worked.
