I could use some help sourcing a coolant leak
Discussion in '1st Gen Tundras (2000-2006)' started by Lundy, Jul 10, 2024.
  1. Jul 10, 2024 at 6:51 PM
    Lundy
    Lundy [OP] New Member
    San Diego
    2004 Dual Cab V8, Automatic, 4x4, SR5 w/tow pkg
    I just got back from a 1200 mile road trip up to Yosemite and have a coolant leak that I’m having a hard time sourcing where it’s coming from. Temps were in the 100's and I did alot of mountain pass climbs.
    I replaced both radiator hoses and three heater hoses, Denso radiator and new thermostat and pink coolant. About 2000 miles ago.
    Truck was running at normal temperature the whole time, never overheated. When I stopped to get gas, the first time about four or five hours into the trip I pop the hood just to check things out, and I noticed the coolant spatter on the hood and on the drivers side only. No visible dripping anywhere from the hoses, radiator overflow tank, etc. I did top off the coolant recovery tank two times and added about 1 to 2 cups each time.
    So now I’m back home now ,pulled all the skid plates off got a pressure tester from AutoZone and still can’t see a visible leak. I pumped it up to 15 psi three times for 30 minutes each and no drips anywhere and no pressure drop, put the cap back on and revved it up to 3000 RPM and no drips at normal operating temperature .
    The timing belt and water pump were done at 175,000 and I just hit 251,000 on the way home. My first guess is that it’s the water pump? But I’m not sure because there’s no weeping when it’s sitting and I can’t see any drips when it’s running or under pressure test, but the spatter seems to like it could’ve been coming from there the way the pattern is? When I had water pump failures on other trucks and cars, there definitely was drips under the car you could visibly see so that’s why I’m stumped right now. Not sure what to do so any input would be appreciated. I’m thinking about doing the water pump timing belt fan clutch pedestal, thermostat, serpentine… All the good stuff but don’t really want to do it if it’s just something minor.....I may wait until I hit 90 K since I’m only at 75K now . Thanks.
  2. Jul 10, 2024 at 6:53 PM
    Lundy
    San Diego
    More photos
  3. Jul 10, 2024 at 7:00 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Have you replace the radiator cap? Doesn’t look oem or Denso in the photo
    since you did the pressure test with no cap on.
    BroHon and shifty` like this.
  4. Jul 10, 2024 at 7:02 PM
    Lundy
    San Diego
    More photos, last one shows the passenger side with no coolant spatter.
  5. Jul 10, 2024 at 7:05 PM
    shifty` Kill another whale with your power
    I think Jerry nailed it. When's the last time you replaced your rad cap?
    BTW, engine bay looks awesome bro. Just gotta say that. Props where deserved.
  6. Jul 10, 2024 at 7:09 PM
    Lundy
    San Diego
    Sorry, I did replace the radiator cap when I put in the new rad. OEM and seems to be holding fine, no visible moisture or weepmg or drips........It pretty much looks brand new,but I guess it's worth a shot. Do these water pumps weep when going bad?
  7. Jul 10, 2024 at 7:14 PM
    Faulty cap? Legitimate OEM from a dealer? Still have the previous to swap in?
    Ever have someone look under the hood with it open while you push 3k RPM in park, while the engine is hot after a 10-15 minute drive?
    Clearly it's something on the driver's side, and it's high enough up that it's able to coat things below, and hit the firewall, but it's not putting anything on the passenger side of the bay. I'm thinking either cap, or a high leak where the rad is capped.
    I can't tell you how many times leaks have been found while the engine is under load and hot, which didn't otherwise appear during idle.
  8. Jul 10, 2024 at 7:15 PM
    Coupe
    Coupe New Member
    James
    Houston, Texas
    2008 Toyota X-Runner
    TRD S/C, headers, APR X1, T56 Magnum 6 spd, NST pullies, Stptech Big Brake Kit, dropped, leather
    I would look for hair line cracks in the recovery bottle.
  9. Jul 10, 2024 at 7:20 PM
    Lundy
    San Diego
    Here’s a picture of of the radiator cap… The coolant recovery tank is old, but I did pull it out and give it a once over and nothing seemed wrong with it
  10. Jul 10, 2024 at 7:25 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Doesn’t the oem cap have a D on each side for Denso?
  11. Jul 10, 2024 at 7:26 PM
    Lundy
    San Diego
    So I guess I’ll get a new radiator cap, clean it all up and drive it up to temp and have my son rev it while I’m checking it out. It has me stumped.:monocle:
  12. Jul 10, 2024 at 7:29 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
  13. Jul 10, 2024 at 7:30 PM
    Lundy
    San Diego
    AISIN THT015 (Standard Replacement) 180°F Info
    OE Temp
    AISIN Warranty Information
    12 months/12,000 miles
    [​IMG]This is the one I bought from Rockaoto, I think it's out of stock mow as I just checked now.....
  14. Jul 10, 2024 at 7:32 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Looks like the center part of your cap has come apart at some point and now is in the radiator.
    shifty` and jerryallday like this.
  15. Jul 10, 2024 at 7:33 PM
    Lundy
    San Diego
    I bought the rad. cap from Rockauto also, maybe it wasn't OEM? It only has 2000 miles on it but I will get a new one from the dealer
  16. Jul 10, 2024 at 7:39 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Order a Denso cap from rockauto. Looks like the middle of your cap is missing inside the radiator
    Lundy[OP] and shifty` like this.
  17. Jul 10, 2024 at 7:44 PM
    That's the t-stat, not the cap.
  18. Jul 10, 2024 at 7:55 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    ^ this.
    The missing part is what opens as the radiator cools to let air escape and suck fluid back in.
    Your spray is from the overflow bubbling/over filling while driving.
  19. Jul 10, 2024 at 8:11 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Actually I don’t see a Denso part on rockauto anymore and I can’t find the part number on Denso website but here is the oem part number. I thought I bout a Denso one but I got oem.
    Toyota part number 16401-20353
  20. Jul 11, 2024 at 4:13 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Are you sure you got it from Rock Auto? (Re-check your order.)
    That ND logo on the left is the old Denso logo. The company was originally called Nippon Denso. According to Google, they changed the name in 1996.
    Is it possible that's the old cap? If not, it could be counterfeit -- not likely if you got it from RA, but if it came for ScAmazon or some other source...?
    Agreed.
    Should look something like this:
  21. Jul 11, 2024 at 4:38 AM
    tvpierce
    Maine
    For what it's worth, this is what the cap looks like on my 2000 AC.
    Note the Nippon Denso logo.
    I presume it's the original, but I don't know as I bought the truck used.
    Lundy[OP] and jerryallday like this.
  22. Jul 11, 2024 at 10:32 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    Also, there are 3 little coolant hoses behind the timing belt. I change them every time I do a timing belt.
  23. Jul 11, 2024 at 3:16 PM
    Lundy
    San Diego
    Picked up the cap, does sayND on it , but it’s the higher pressure one. it does have the extra tab on it. I guess that fell off on the other one . We’llsee how it goes.
  24. Jul 11, 2024 at 3:17 PM
    Lundy
    San Diego
    Back side
  25. Jul 11, 2024 at 4:17 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    When I lived in Japan it was Nippon Denso so I think ND is correct but so it D
  26. Jul 12, 2024 at 6:42 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Disregard this, was making sure you were aware it is higher pressure but I see it in your post now. Not sure that it will cause any issue or not, never tried one.
  27. Jul 12, 2024 at 3:47 PM
    tvpierce
    Maine
    Did you get that cap at the dealer? I've never seen a Toyota part packaged that way.
  28. Jul 12, 2024 at 4:38 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I think because it's a TRD branded part it got special packaging. It has the normal label on the plastic bag.
  29. Jul 12, 2024 at 4:39 PM
    Lundy
    San Diego
    YES, Toyota Parts Online.com and the picked up at my local dealer. Maybe because it's TRD model in packaged that way? I live in San Diego and there is a huge Toyota parts distribution warehouse in Riverside CA about 1.5 hours away. Can order in the afternoon and receive at local dealer at 2-3 o'clock next day.
  30. Jul 12, 2024 at 4:47 PM
    Lundy
    San Diego
    Cleaned up all the sprayed coolant and installed the new cap ast night. Drove to work at five in the morning no spillage but driving home this afternoon 23 miles in about 80° weather. I did get some. I think my next step is to replace the coolant recovery tank. I called the dealer because I couldn’t find the part number active and it is discontinued 16470–0F010. Rock auto has a Dorman one available. I may pick that up. Thanks for all the input. Any other suggestions?
