Icon progressive AAL
Discussion in 'Suspension' started by Macreggg, Jul 12, 2019.
  1. Jul 12, 2019 at 12:03 AM
    Macreggg
    Macreggg [OP] TRD No
    Mel
    Los Angeles, CA
    2019 Tundra CM Super White
    wheels/tires suspension protection
    Hello everyone,
    The internet is lacking with pictures of people’s icon AAL.
    Can someone please post pictures of yours? I have a feeling mine is installed incorrectly but just want to make sure.
    I do not have the overload in.
    It’s also ridiculously squeaky no matter what I do. It is also not aligned straight any more.
    It does however perform very well off road.
    I’ll post better pictures tomorrow.
    But as you can see I only have 4 leafs installed...
  2. Jul 12, 2019 at 12:06 AM
    Macreggg
    Mel
    Los Angeles, CA
    I have a bro lean with only 2 inches of thread showing in the front.
  3. Jul 12, 2019 at 12:11 AM
    Macreggg
    Mel
    Los Angeles, CA
    577538EF-B763-4BDA-8C19-D7484F9CAFFC.jpg 39B7C978-0AB1-46C7-AF62-01E815C78EB1.jpg
    Reelman likes this.
  4. Jul 12, 2019 at 5:08 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    600lb or 700lb springs on those?
  5. Jul 12, 2019 at 6:03 AM
    Macreggg
    Mel
    Los Angeles, CA
    Should be 700. But my issue is the leaf pack not the front springs.
  6. Jul 12, 2019 at 6:09 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Yes but the 700lb spring should only be at 1” of thread. That’s why your front is that high.
    Challenger1 likes this.
  7. Jul 12, 2019 at 7:04 AM
    Macreggg
    Mel
    Los Angeles, CA
    Do you have input on the rear leaf pack?
  8. Jul 12, 2019 at 7:18 AM
    Stainlesst
    Stainlesst everybody loves an Inky. Inky Inky. go Inky go!
    going to the big D and don't mean Denver...
    09 trd crewmax, 13 TWReX stage III
    In the "Zone"...
    do you have any shackles installed or are they stock? could try some longer ones.
  9. Jul 12, 2019 at 7:34 AM
    TheBeast The Beach
  10. Jul 12, 2019 at 7:37 AM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    How thick is the overload leaf that you removed? I don’t remember, it’s been a long time since I threw mine in the trash. Your going to loose minimum that much in height. From the looks of the pics the leafs are installed correctly. My old Icon AAL would make noise in the area shown below from metal to metal contact. Also make sure all of the isolator pads are installed between the leafs.
  11. Jul 12, 2019 at 1:13 PM
    Macreggg
    Mel
    Los Angeles, CA
    Stock shackles. Was thinking of doing that just wanted to see what everyone else’s Icon AALs look like and their input.
  12. Jul 12, 2019 at 1:15 PM
    Macreggg
    Mel
    Los Angeles, CA
    The only proof on this is a install guide for the first gen and in those pictures I count 6 leafs. I have 4...
    Here’s the link
    https://www.iconvehicledynamics.com/wp-content/uploads/2016/07/I51100_REVA.pdf
  13. Jul 12, 2019 at 1:22 PM
    Porschetech29
    Francis
    That picture you posted is of the RXT pack, completely different than what you have installed. With the expansion pack you only reuse the main and overload. In your situation just the main.
    Macreggg[OP] and zcarpenter92 like this.
  14. Jul 12, 2019 at 1:35 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    ^^the rxt is completely different with 3 height options.
  15. Jul 12, 2019 at 1:41 PM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    The expansion pack should have the factory overload in there. That is what maintains the factory payload and towing capacity. The Icon expansion pack replaces everything between the overload leaf and the main leaf. If you have removed the overload, you will net 1" of lift and are more likely to sag the pack out due to the pressure right in the center.
  16. Jul 12, 2019 at 1:48 PM
    throughitalldude
    throughitalldude New Member
    Jeff
    Southern California
    2017 Platinum
    3/1 Lift |TSS 20" Wheels | 35 Cooper AT3 XLT | Flowmaster 40 Series Exhaust
    I would put your overload back on it would most likely level you to a point of being slightly high in the front. It will look much better IMO. Had this setup on my Tacoma and most likely will head the same route with my tundra.
    Macreggg[OP] likes this.
  17. Jul 12, 2019 at 5:58 PM
    Macreggg
    Mel
    Los Angeles, CA
    This was all the info on any icon leafs. Lol.
    You guys def answered my questions. Will add the overload. Any issues if I did that with a 1.5 to 2 inch shackle?
  18. Jul 12, 2019 at 7:24 PM
    olsin6
    olsin6 New Member Vendor
    Joey
    Mesa, AZ
    2010 White DCSB Tundra
    35" Toyo MT w/ 17" Method Standards Body Mount Chop SDHQ Sliders
    They have install instructions posted on their website and they usually come in the box with the expansion pack.
    The shackle was lift it an additional 1.5-2.0 over what you have, so it would give you a huge rack. Plus the shocks you have on there will be riding at full extension with the shackle which would be a horrible ride.
