idler pulley bearing
Discussion in '1st Gen Tundras (2000-2006)' started by fishordie, Nov 3, 2024.
  1. Nov 3, 2024 at 7:30 PM
    fishordie
    fishordie [OP] New Member
    Earl
    East Texas Piney Woods
    2002 SR5 AC 2WD 210K Grocery Getter
    Middle of Timing Belt - Possibly Cam seals
    I searched through the posts and was able to find the bearing product ID for the tensioner bearing but couldn't find any info the idler bearing. I took it to the two local bearing shops and neither have it. They both said its an odd size. I pushed out the bearing out a few weeks (to take to the bearing shops) and I've lost it. If anyone has an info on this bearing I would really appreciate it.
  2. Nov 3, 2024 at 7:39 PM
    You just want the OEM part number to replace it? Or specific bearing info?
  3. Nov 3, 2024 at 7:44 PM
    fishordie
    Earl
    Hey Shifty...I was hoping to find the bearing to keep it O-OEM..ha..but if I dont find it I may get the whole OEM Pulley.
  4. Nov 3, 2024 at 9:08 PM
    bing5
    bing5 New Member
    New Mexico
    2004 Double Cab. 260k+
    fishordie[OP] and ToyotaDude like this.
  5. Nov 3, 2024 at 9:31 PM
    Dustbox
    Dustbox New Member
    Southern Utah
    2000 Black AC 4.7l V8 4x4 SR5
    285/75/r16 tires on stock suspension Tubed Bumpers
    I just replaced my whole serpentine belt, tensioner and idler pulley for $106 from rock auto, the gates one. Can’t remember their exact prices on idler pulleys, if I remember correctly there was a dayco one for sale at $20. Idk if that’s a good one or not tho.
    In what condition is your serpentine belt?
    fishordie[OP] likes this.
  6. Nov 4, 2024 at 5:57 AM
    For 2002 SR5 AC V8 2WD, the passenger side I'm seeing (A) is 13505-0F010. Driver side (B) is 13503-0F010. Both appear to be the most recent design. Remember, discounts won't apply until you first select a dealer, then any add'l discounts show at Checkout.
    It's worth mentioning, you can get these parts significantly cheaper through Amayama in Japan, roughly $50 for the pair, huge savings. You'll pay around $33 in shipping and wait 10-20 days for arrival from Japan, this is for driver side, and for passenger side at Amayama.
    They're saying Koyo bearing PU306630ARR9D is (B) below and Koyo LAT1030-1 for (A), Koyo may be the actual OEM supplier as it is with other bearings on our trucks.
  7. Nov 4, 2024 at 6:19 AM
    fishordie
    Earl
    hmmm..Amazon is saying it doesn't fit my 02...that NSK does look like a good AM option. I hadn't seen that in all my research. Probably because Amazon says it doesn't fit. That's surprising if that's true.
  8. Nov 4, 2024 at 6:39 AM
    fishordie
    Earl
    that sounds like a great deal compared to a pulley thats almost 100.
    Got a brand new green HD belt chompin at the bit to put on and fire up...
  9. Nov 4, 2024 at 6:42 AM
    fishordie
    Earl
    This is gold!! Never knew about Amayama. I learn something every time you drop some info. Tracking down the 13503-0f010 you included now.
  10. Nov 4, 2024 at 6:44 AM
    Links on my 2nd line point to exact parts in Amayama to add to cart.
  11. Nov 4, 2024 at 6:51 AM
    fishordie
    Earl
    Gunna try them out..im in no hurry...
