IGN fuse/ Alpha Rex/ Aux Beam
Discussion in '2.5 Gen Tundras (2014-2021)' started by Part_time, Nov 15, 2021.
  1. Nov 15, 2021 at 5:26 PM
    Part_time
    Part_time [OP] Not a new member
    Oregon
    2017 MICA BRONZE SR5
    I installed Alpha Rex headlights. Part of install is to run a wire with a fuse from the headlights to the ING fuse. This runs the DRL lights. So now I would like to install Aux Beam switch panel. It has the same wire with fuse to be put in same location,
    Question:
    Is there another spot that I can put the Aux beam fuse 10 amp that turns on like the ignition?
    Or
    Should I could I tap into the wire and fuse that I have installed for the Alpha Rex headlights?
  2. Nov 15, 2021 at 5:41 PM
    I'm not sure about a second location without looking for a blank spot in the fuse panel but I would not tap the fuse/wire that you have installed for the headlights.
    Part_time[QUOTED][OP] likes this.
  3. Nov 15, 2021 at 5:45 PM
    Part_time
    Oregon
    I didn't think that would work, I could just start plugging in 10 amps that are empty.
  4. Nov 15, 2021 at 5:59 PM
    Yeah I'm not too familiar with the "adding a circuit" but I was just thinking that putting the Auxbeam on the headlight circuit would be too much for it.
  5. Nov 15, 2021 at 6:15 PM
    Part_time
    Oregon
    If I do find another 10 amp the only thing I can think I may loose is I would have to turn it on after starting the truck. Instead it auto automatically turning on with the ignition.
  6. Nov 15, 2021 at 7:00 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    INJ fuse is 10amp, I know yotaleds uses it for the add a fuse on their raptor lights.
    So more than likely will work for what you want too.
  7. Nov 15, 2021 at 7:21 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    I’d second this. Fuel injectors only turn on when ignition is on…
  8. Nov 16, 2021 at 1:01 AM
    Part_time
    Oregon
    Thanks will give it a try.
  9. Nov 26, 2021 at 5:07 AM
    Akaklutz
    Akaklutz New Member
    Alan
    2021 Tundra
    New stock
    Keep us updated. Ive been considering these headlights....
