Ignition Coil Boot broken inside cylinder
Discussion in '1st Gen Tundras (2000-2006)' started by Mctodd, Aug 19, 2018.
  1. Aug 19, 2018 at 4:16 PM
    Mctodd
    Mctodd [OP] New Member
    Todd
    Nor Cal
    2003 SR5 4wd TRD
    F. Fabtech Dirt Logic 2.5, Icon 1.5 Add a Leaf pack, BFG KO2s 285/75/17, 1.25 Spydertrax, SPC UCAs.
    Any suggestions on removing the rubber ignition coil boot stuck down in the cylinder around the spark plug?
    I went in to replace my spark plugs and half the rubber on one of my ignition coils broke off inside the cylinder around the spark plug. I've tried using long pliers, a screw driver, and making a shim out of a coat hanger to get down in the there to try and hook onto the rubber to pull it out but no luck.
  2. Aug 19, 2018 at 4:20 PM
    Professional Hand Model
    Hand Protectors
    Two long screw drivers down at same time and wedge up slowly.
    Mctodd[OP] and Black Wolf like this.
  3. Aug 19, 2018 at 5:06 PM
    Casper421
    In the woods
    06 DC
  4. Aug 19, 2018 at 8:28 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Can you put a pretty long screw into it and use that to yank it out with needle nose? I'm actually picturing cutting the business end of a corkscrew and using that with needle nose.
    Mctodd[OP] likes this.
  5. Aug 20, 2018 at 8:18 AM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    I had the same thing happen on my 03. I had to get in there with a long-handled exacto knife and cut a slit down the side of the boot. Then I was able to grab it and pull it out with a long-handled pair of forceps.
  6. Aug 22, 2018 at 8:08 AM
    Mctodd
    Todd
    Nor Cal
    2003 SR5 4wd TRD
    Thanks for the input. I finally got it out with a combination of long needle nose pliers, long screws, screw driver and a shop vac. It was so stuck and brittle that it broke into pieces whenever i got any grip on it so i essentially broke it up and removed the pieces by hand and with a shop vac.
    A royal pain in the ass for sure!
    2010SR5NIC, Darkness and 15whtrd like this.
