Ignition coils which one would you pick
Discussion in '1st Gen Tundras (2000-2006)' started by USERidiculousNAME, Jun 1, 2024.
  1. Jun 1, 2024 at 9:44 AM
    USERidiculousNAME
    USERidiculousNAME [OP] ToyTurd
    Josh
    New Orleans
    250K on Early 2004 tundra DC 4.7 v8, SR5, RWD, A/T, LSD, w/ABS,TOW, OFF ROAD, ZERO RUST FRAME, BILSTIEN 5100, AAL, 17" 265/70
    Backup camera, camper shell, double din stereo, amp, sub, blind spot cameras, modest lift, newer Tacoma rims, large AT tires, interior lighting upgrades, in bed, under hood, as well as leds in cab, blue foot well strips (night driving)or bright white strips if need to see, 3 additional white leds on ceiling front L/ R and center, toggle switch's and added accessory fuse box.
    I have 2 options for ignition coils, in front of me I have denso coils with 240k or A- premium coils new densos are still working
  2. Jun 1, 2024 at 9:48 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
  3. Jun 1, 2024 at 9:50 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    If it ain't broken, don't fix it.
    jimf909, shifty` and FrenchToasty like this.
  4. Jun 1, 2024 at 9:51 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Denso 100% basically oem , our trucks don’t like aftermarket electronics. I bought autozone brand because I was in a pinch and they failed after 3k miles and I bought all Denso coils
  5. Jun 1, 2024 at 4:07 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I bought 8 Densos from Rock Auto (good for another ~20 years!). If I had to do it on the cheap I might consider MSD. Everything else seems to be too risky IMHO
  6. Jun 2, 2024 at 12:17 AM
    USERidiculousNAME
    Josh
    New Orleans
    Thanks y'all
  7. Jun 6, 2024 at 7:42 PM
    Noooooooooooo. The MSDs are known to fail and malfunction quickly. Denso is the only way here.
    87warrior, shifty` and w666[QUOTED] like this.
  8. Jun 7, 2024 at 5:04 AM
    I honestly suspect MSD is outsourcing to the same factories in mainland PRC as TRQ and the others. They switched parts manufacture to China 6-8 years ago IIRC.
    Along with that shift, I'm sure they basically gave their IP up, one of the side effects of doing business over there.
  9. Jun 7, 2024 at 1:42 PM
    USERidiculousNAME
    Josh
    New Orleans
    So a couple of the denso coils I have have cracked and fallen apart at the bottom end I'm going to try the aftermarket but only until I can get denso replacements. That's if it even sounds ok with them installed, only because they are in front of me already
  10. Jun 7, 2024 at 2:08 PM
    Nah, it's cool. I ask for advice and ignore it all the time. Big rebel in my free time.
    bmf4069 and JakeJake like this.
  11. Jun 7, 2024 at 3:49 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
  12. Jun 8, 2024 at 10:19 PM
    USERidiculousNAME
    Josh
    New Orleans
    Whoa that's crazy, are the densos actually overkill. I don't see how a replacement part can be that far off spec. Really what I'm saying is they shouldn't be allowed to sell replacement parts that are this far off spec. Good post
  13. Jun 9, 2024 at 6:06 AM
    Because consumers continue to buy it. When a company sees people are willing to buy something at the lower price, despite the shitty lower quality, they continue doing it. And when Company A sees Company B getting away with shittier quality, they shift their model to the same, and before you know it, all the companies are doing it.
    Unfortunately, this is what has happened across the board. It's why the market is flooded with suspension parts that use plastic bushings instead of metal, and fail prematurely. It's why there's so many warnings out there about using aftermarket LBJs for example.
    Look, it's your dollar and your time. If you're the kinda guy who likes to spend $20 on a part that you'll need to replace 4x over the next 15 years at an end cost of $80 total, versus spending $60 on the OEM part and changing once, then by all means, you do you.
    But you need to be aware: Parts-store parts have become a 2-5 year stop-gap measure to bandaid the problem. That's the reality of our world today, and it's why people are always hammering: GO WITH THE OEM BRAND. Doesn't mean you need to buy it from Toyota. Toyota used specialty manufacturers all the time for their parts, like Spicer for some of the drivetrain stuff, KOYO for some of the bearings, Hitachi for the V8 MAFs, and sometimes Toyota's related branding (Denso, Aisin, Advics, Sumitomo, etc.)
    Again ... you do you. I personally prefer buy-once-cry-once.
    These videos pretty much show you the cost-saving measures and quality degrade of store-brand parts these days, most of it is shit:
