Ignition coils
Discussion in '2nd Gen Tundras (2007-2013)' started by DONDOU, Apr 1, 2024.
  1. Apr 1, 2024 at 7:49 PM
    DONDOU
    DONDOU [OP] New Member
    Dallas, TX
    2012 Tundra
    Anyone here have issues with using Duralast ignition coils? I’m getting constant misfire readings and wondering if it’s because of the brand of coils I’m using. Should I not be using them in my Tundra? I have Denso plugs, but Duralast ignition coils.
  2. Apr 1, 2024 at 9:45 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    When it comes to coils I try to stick with Denso. There’s also an issue with fake name brand plugs from places like Amazon. You may want to check the gap on your plugs as well.
    DONDOU[OP] and Mdl like this.
  3. Apr 2, 2024 at 12:24 AM
    Duralast coils are not good on these trucks. Order Denso from somewhere reputable. Dealer or Rockauto would be my go to on these. Toyota’s electrical systems are pretty sensitive overall. Anything sensor or electrically activated, go with OEM Denso parts.
    DONDOU[OP], NickB_01TRD and Mdl like this.
  4. Apr 2, 2024 at 4:41 AM
    DONDOU
    Dallas, TX
    2012 Tundra
    Thank you! I’ll see if I can return the coils I have and replace with Denso. Much appreciated.
  5. Apr 2, 2024 at 4:42 AM
    DONDOU
    Dallas, TX
    2012 Tundra
    Rockauto? I’ll check it out!
  6. Apr 2, 2024 at 4:57 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Get rid of the Neverlast coils. Only Denso. RockAuto has them for 1/2 what the parts stores sell them for.
    DONDOU[OP] likes this.
  7. Apr 2, 2024 at 5:17 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    A rule of thumb is to use plugs/coils/sensors from the engine computer vendor. Bosch ECU -> Bosch spark plugs, coils, oxygen sensors, MAF, MAP, IAT, etc. Denso ECU -> all Denso.
  8. Apr 2, 2024 at 6:12 AM
    DONDOU
    Dallas, TX
    2012 Tundra
    Thanks All - I guess I learned my lesson. Hopefully, I can return the Duralast ones I got from AutoZone.
  9. Apr 2, 2024 at 7:10 AM
    FuegoMCS
    FuegoMCS New Member
    East Texas
    2011 Crewmax 2WD
    Is there a service interval for replacing the coils? My 2011 has over 185k miles, I've changed the plugs twice over the years. The coils have never been changed as I haven't had any issues.
  10. Apr 2, 2024 at 7:25 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I had 250+k miles on original coils in a 2005 vehicle. Replaced them for no good reason. Keep the coils wire harness healthy, make sure they have a good ground contact via bolt to the valve cover, and it seems they can live indefinitely.
    DONDOU[OP] and FuegoMCS[QUOTED] like this.
  11. Apr 2, 2024 at 7:48 AM
    DONDOU
    Dallas, TX
    2012 Tundra
    I ended up having to replace my alternator and was told that I received an error on the coils also. Never had an issue before, so who knows.
    FuegoMCS likes this.
  12. Apr 2, 2024 at 8:19 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    The duralast ones should be lifetime warranty. Not sure they'll give you your money back for them though unless you just bought them.
    DONDOU[QUOTED][OP] likes this.
