Inbed Storage
Discussion in '3rd Gen Tundras (2022+)' started by Sodamo, Jan 25, 2025.
  1. Jan 25, 2025 at 3:27 PM
    Sodamo
    Sodamo [OP] New Member
    David
    Big Island Hawaii
    2024 1784 Crewmax hybrid
  2. Jan 25, 2025 at 3:31 PM
    Sodamo
    David
    Big Island Hawaii
  3. Jan 25, 2025 at 3:33 PM
    Sodamo
    David
    Big Island Hawaii
    Some views inside fender well
    Note the rib
    Raven67 and The Black Mamba like this.
  4. Jan 25, 2025 at 3:35 PM
    Sodamo
    David
    Big Island Hawaii
    Where to locate was a concern. Generally this area.
    But not completely smooth surface.
    Also wanted to do a 2nd, but the AC port is on other side.
    Mr Rick, Raven67 and The Black Mamba like this.
  5. Jan 25, 2025 at 3:41 PM
    Sodamo
    David
    Big Island Hawaii
    Decided as close to rear as possible, high as possible
    My hole was too close to edge. Inserted a thin wire (#14 solid ground) to get a visual and has to adjust toward interior.
    made a template and again small holes w/wire for visual check. Did not want to make a hole in wrong place.
  6. Jan 25, 2025 at 3:51 PM
    Sodamo
    David
    Big Island Hawaii
    Used template to mark hole, cut with oscillating saw.
    Messy
    Purposely cut tight, adjusted with sander, serval trial fits along the way.
    made spacers from the cutout material to make up recessed area. Sorry forgot to get pics of that step.
  7. Jan 25, 2025 at 3:55 PM
    Sodamo
    David
    Big Island Hawaii
    Original plan was 3/8 rivnuts, but apparently got wrong size and could crush properly. Installed temporarily using #14 sheet metal screws until I get proper nuts.
    The wire on left goes to Leer top. Considered relocating but didn’t want to chance breaking the connector, so just tucked under corner after removing a bit of material.
    Overall quite pleased with installation. Still thinking if I want one on other side.
    Hope this may help someone.
    gnc1017, Rockgate, RatPanda and 6 others like this.
  8. Jan 25, 2025 at 4:17 PM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    That looks fantastic. Nice work!
    Bayou Spartan and Raven67 like this.
  9. Jan 25, 2025 at 5:19 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Great idea! & great work! Thanks for posting.
  10. Jan 25, 2025 at 5:43 PM
    Sodamo
    David
    Big Island Hawaii
    Thanks
    Lack of storage, what I miss most from my Ridgeline. This will help
    gmcguire7220 and Raven67 like this.
  11. Jan 25, 2025 at 5:44 PM
    Hella Krusty
    Hella Krusty New Member
    Great work.... but I have to admit I thought it was 12V cooler which excited me for about a minute
  12. Jan 25, 2025 at 5:53 PM
    Raven67
    Kentucky
    Found those parts much cheaper online. Just ordered 2 of them.
    FordPartsOnline.
  13. Jan 25, 2025 at 6:24 PM
    Sodamo
    David
    Big Island Hawaii
    Got mine on ebay, $60. Found 2x for $110 but was not sure about 2nd, not having proved it doable.
    Raven67 likes this.
  14. Jan 30, 2025 at 1:09 PM
    Raven67
    Kentucky
    Got my drivers side done today thanks to this thread. Should get the other one tomorrow & I'll get it installed on other side.20250130_151252.jpg 20250130_151314.jpg 20250130_152532.jpg 20250130_152525.jpg 20250130_152638.jpg
    Reubenski, gnc1017, BlackNBlu and 3 others like this.
  15. Jan 30, 2025 at 2:06 PM
    joshua32
    joshua32 New Member
    2024 Celestial Silver Platinum HV TRD OR
    Do you guys have any pictures of what it looks like (installed) from the ground up, in between the inside of the fender and bed?
  16. Jan 30, 2025 at 2:33 PM
    Sodamo
    David
    Big Island Hawaii
    Looks great
    Curious as to location on paxside.
    Good job
    Raven67 likes this.
  17. Jan 30, 2025 at 2:35 PM
    Sodamo
    David
    Big Island Hawaii
    Ok, underside pics
    Raven67 likes this.
  18. Jan 30, 2025 at 2:58 PM
    Raven67
    Kentucky
    This is such a good idea & an easy install. I used a DeWalt cutting tool to make the hole, it worked great. Then I used a small sander to clean up the cut & make a few slight adjustments for a tight fit.
  19. Jan 30, 2025 at 10:18 PM
    joshua32
    joshua32 New Member
    This is great! Thanks for the pics...adding it to the list!
  20. Jan 31, 2025 at 5:37 AM
    mach1man001
    mach1man001 New Member
    Rob
    2024 Limited Crewmax
    Any idea if there is enough room to fit a 2nd gen Tacoma pocket? They are longer but not as tall
  21. Jan 31, 2025 at 5:37 AM
    DRP
    DRP Old Member
    Dave
    Looks like a great spot for those pesky tie down straps and bungees that always seem to be laying in the bed. Looks like local Ford dealer has them for $40. Not that I can't figure it out for myself, was it a wood cutting blade you used in the cutting tool? Thanks. And thanks to @Sodamo for starting the thread.
  22. Jan 31, 2025 at 6:28 AM
    Raven67
    Kentucky
    I just used an all purpose blade, it's composite material, pretty much like plastic. Tough, but it cuts nicely, just take your time. Hardest part was getting measurements for exactly where the hole to cut is going to be. When I get out to shop today, I'll post my measurements.
    I ordered the boxes online, got them below $40 ea. But then you'll have shipping.
    DRP[QUOTED] and Mr Rick like this.
  23. Jan 31, 2025 at 7:52 AM
    DRP
    DRP Old Member
    Dave
    Thanks for the update. Measurements would be awesome for a little peace of mind. I don't do many mods but this one is definitely going to happen.
    Raven67[QUOTED] likes this.
  24. Jan 31, 2025 at 8:11 AM
    Raven67
    Kentucky
    Ok, here's the tools I used, and some measurements.
    Measurement A is from bottom of rail to top of hole. It's 1 3/8"
    Measurement B is 2 3/8"
    Hole that you cut is 7" wide and 8" tall.
    Please double & triple check for yourself before cutting. My truck has no factory bed lights, plugs, etc. So it's all open on both sides. Look up in rear quarters & make sure there's nothing back there before you start. I marked for the cut & used level to draw lines level & straight, then cut. Then used a small angle sander (not shown) to touch up hole & fine tune it for a tight fit. Good luck. 20250131_110219.jpg 20250131_110322.jpg
    Mr Rick and 22whatwedo like this.
  25. Jan 31, 2025 at 9:21 AM
    DRP
    DRP Old Member
    Dave
    Most excellent. Thanks again. Next time I'm in Kentucky I'll buy you a beer or three.:cheers:
    Mr Rick and Raven67[QUOTED] like this.
  26. Jan 31, 2025 at 9:32 AM
    Raven67
    Kentucky
    Let me know!! I'm ready!
    DRP[QUOTED] likes this.
  27. Jan 31, 2025 at 9:35 AM
    Sodamo
    David
    Big Island Hawaii
    No idea. That was my major concern as well. Just never confident in my measuring. I drilled a 1/8 hole and then guaged the depth with a piece of copper wire, figuring worst case I could fill in the small hole. I was less concerned as to length as it looked like if mounted lower it would still be OK.
    mach1man001[QUOTED] likes this.
  28. Jan 31, 2025 at 9:44 AM
    Sodamo
    David
    Big Island Hawaii
    Thanks for the additional info Raven, very helpful. Agree with your measurements. I felt a bit more confident using a template, not that I have EVER marked on wrong side of a measure before. I used a metal blade, because it was what was in the tool. This can be messy, lots of dust from cutting and sanding. I used 80 grit to sand as I was on the tight side. Cut strips from the cutout to make spacers for that moulded recess.
    a good project
    DRP likes this.
  29. Jan 31, 2025 at 9:46 AM
    Sodamo
    David
    Big Island Hawaii
    Can’t help but thinking Toyota is missing an opportunity here. Factory mould in the cutout & cover. Sell us the cubby box for $150, $250 installed, even $500 option.
  30. Jan 31, 2025 at 9:53 AM
    Sodamo
    David
    Big Island Hawaii
    what about me ☹️
