Inner CV boot whacked out
Discussion in 'General Tundra Discussion' started by TG705, Apr 10, 2020.
  1. Apr 10, 2020 at 3:36 PM
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    Is there any way to fix this without unclamping the boot? I’ll pull the axle if I need to. Any help is appreciated!
    dcsleeper408 likes this.
  2. Apr 10, 2020 at 3:38 PM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    Lift kit strain. A lot of angle there.
  3. Apr 10, 2020 at 3:49 PM
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    There’s hardly any angle at all. Coils are set to about 2.5” with a diff drop
  4. Apr 10, 2020 at 3:51 PM
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
  5. Apr 10, 2020 at 3:51 PM
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    Did the joint pop out and rotate?
  6. Apr 10, 2020 at 3:53 PM
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    Nope, I 4 wheeled pretty hard over last weekend and it never skipped a beat. No weird noises or anything. Works perfectly fine.
  7. Apr 10, 2020 at 3:55 PM
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    Looking at the line on the boot, looks like the boot rotated.
    dcsleeper408, YardBird and vhstejskal like this.
  8. Apr 10, 2020 at 3:56 PM
    vhstejskal
    Vic
    TG705[OP] likes this.
  9. Apr 10, 2020 at 4:00 PM
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
  10. Apr 10, 2020 at 4:02 PM
    Vizsla
    Vizsla ☠️☠️☠️
    I have the same axles, you can take the little clamp off and burp it. Need to use these clamps, not regular ones. Mark the axle at end of boot for reference.
  11. Apr 10, 2020 at 4:22 PM
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    right on thanks!! are those hose clamps strong enough to get a good seal and to where the boot won't side up and down the shaft?
  12. Apr 10, 2020 at 4:54 PM
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
    Could this have something to do with the issue you posted with your diff mount? What was the issue there?
    Tundyfundy likes this.
  13. Apr 10, 2020 at 6:31 PM
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    I don't think it's related, the outer clamp somehow spun a little bit on the inner CV joint causing the boot to twist. As far as the diff, I couldn't tell you lol, it looked like the bushing was blown out so I took off the diff drop spacers to inspect it, the bushings looked fine so I kept the diff drop off and tightened them back up and now they're fine.
    2Tall[QUOTED] likes this.
  14. Apr 10, 2020 at 6:34 PM
    Vizsla
    Vizsla ☠️☠️☠️
    Yes, bunch of us use them, pretty common. They have a soft edge on them so they don’t tear into the boot. A27481EE-1BAA-411B-AB23-133F8880DF04.jpg
    joonbug, vhstejskal and TG705[OP] like this.
  15. Apr 10, 2020 at 6:49 PM
    TheBeast The Beach
    LT ftw !
    Vizsla[QUOTED] and TG705[OP] like this.
  16. Apr 10, 2020 at 6:50 PM
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    Awesome! you have a link to where you bought those specific clamps?
  17. Apr 10, 2020 at 7:16 PM
    Vizsla
    Vizsla ☠️☠️☠️
  18. Apr 10, 2020 at 7:23 PM
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
  19. Apr 11, 2020 at 11:48 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Looks like the boot vacuumed
    You might be able to get away with placing a straw or similar to release the air suctioned inside. Whenever I rebuild axles I do this, mount the axles give it a good cycle to release as much out as possible. I try to stick with oem/band clamps, just need to since em down real good with the right tools. Hose clamps Work well. Just don’t bite them down too hard or they will cut the boot.
  20. Apr 11, 2020 at 3:59 PM
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    right on man thank you! I ordered the hose clamps that @Vizsla posted yesterday and run that until I can get it reclamped.
    dcsleeper408[QUOTED] likes this.
  21. Apr 11, 2020 at 4:12 PM
    Yoda1
    Yoda1 New Member
    2016 MGM Tundra Crewmax
    I tried the hose clamps on the large end of the inner boot on the passenger side and they actually hit the bump stop mount. Not sure why as the driver side seems to have more clearance. Hope they work for you.
