Installed CALI RAISED sliders
Discussion in '2.5 Gen Tundras (2014-2021)' started by LunaPro, Jan 13, 2021.
  1. Jan 13, 2021 at 6:18 AM
    LunaPro
    LunaPro [OP] New Member
    Dreux
    2021 Crewmax Pro
    Just beginning
    New here and just looking at all of your rigs. I just installed the Cali-Raised Sliders. I did order the the two inch wider step, not sure on that decision yet. I do use it as a step and thought the additional width may offer more protection. But initial impression is that it bumps into my calves at the oddest place.
    Checkout them out. Great company to deal with, order delivered ahead of schedule by a few days and everything bundled up and safely delivered with no scratches or dings.
  2. Jan 13, 2021 at 7:47 AM
    Mediumrarepls
    Mediumrarepls New Member
    2019 Tundra SR5 TRD Offroad Crewmax Quicksand 4x4 5.7
    Looks good... how long did the install take?
  3. Jan 13, 2021 at 7:49 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Nice!
    I have their narrower “trail” version without the top plate and love them.
    ToyoMafia likes this.
  4. Jan 13, 2021 at 7:58 AM
    LunaPro
    Dreux
    2021 Crewmax Pro
    Just beginning
    Install took a little longer than I anticipated due to working around gas tank. It took about 2.5 hours. There was not real rush and it was pretty cold. Could be done in two easy.
    Mediumrarepls likes this.
  5. Jan 13, 2021 at 10:04 AM
    clarkritchie
    clarkritchie New Member
    Nice. Did you pop all these nubs off the frame? Or maybe drill them out? I thought they might pry off with Vice Grips but they sure don't seem to give up easily. Asking for a friend.
  6. Jan 13, 2021 at 10:08 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Don't want to do that. Tundras have a C channel frame. These nuts and bolts hold two C channels together (think of it as a C within a C) along with some spot welds.
  7. Jan 13, 2021 at 10:08 AM
    clarkritchie
    Well good thing I asked! Thank you. I assumed (incorrectly) that these would come off to allow the slider to press up flat against the frame.
  8. Jan 13, 2021 at 10:10 AM
    LunaPro
    Dreux
    2021 Crewmax Pro
    Just beginning
    Those rivots are accomodated for in the fabrication of the rails. The "nubs" are simply straddled. Actually not an issue at all. The only hurdle is the gas tank. And even that for those more mechanically inclined could be a non issue.
  9. Jan 13, 2021 at 10:11 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Wait until some fool parks really close to you and swings their door open :rofl:
    Darkness, Luckydog, ToyoMafia and 2 others like this.
  10. Jan 13, 2021 at 10:11 AM
    Squatting Pigeon
    Holden
    North Texas
    I just so happened to have this pic on my phone of mine:
    HD59019, Darkness, NoRcptn and 2 others like this.
  11. Jan 13, 2021 at 10:12 AM
    LunaPro
    Dreux
    2021 Crewmax Pro
    Just beginning
    I am down with the virus right now ..... but I will crawl under the rig and get some more photos. I wish I would have tracked entire process for you guys. Couldnt be more simple straight forward design.
  12. Jan 13, 2021 at 10:24 AM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
  13. Jan 13, 2021 at 10:34 AM
    LunaPro
    Dreux
    2021 Crewmax Pro
    Just beginning
    Looks sweet without the caps. I was undecided but thought it may protect rocker panels a little more and provide good footing. Have any of you guys had to hijack your rigs using the sliders? do you think they are capable?
  14. Jan 13, 2021 at 10:39 AM
    Pitbull410
    Pitbull410 New Member
    2020 TRDPro CM MGM, 2018 LC200 MGM
    I need these. Gonna have to wait for next black friday sale now:(
  15. Jan 13, 2021 at 10:40 AM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    I think you have to buy the weld on version, not the bolt on version to use with a lift.
  16. Jan 13, 2021 at 10:46 AM
    TheBeast The Beach
    for the wkor sliders, you can hi lift no problem. I have drilled 5 extra holes on each side for the sliders to be mounted on the frame. it's not going anywhere.
  17. Jan 13, 2021 at 10:48 AM
    Squatting Pigeon
    Holden
    North Texas
    I haven't tried, but I'm sure you can use a Hi-Lift on these no problem.
  18. Jan 13, 2021 at 11:00 AM
    LunaPro
    Dreux
    2021 Crewmax Pro
    Just beginning
    i had some serious reservations about welding the sliders on. seemed like a job for extreme qualifications and the chance of accelerating the rusting of my frame.
    Pitbull410 likes this.
  19. Jan 13, 2021 at 11:20 AM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    Those look good! I am undecided on the steps or not, these pics help.
    I'm def going with caliraised since I can pick them up will call and save the $200 shipping everyone else wants for sliders
    Squatting Pigeon likes this.
  20. Jan 13, 2021 at 11:54 AM
    Bootleg
    Bootleg New Member
    Brandon
    2020 MGM TRD Pro
    This is not true. Many brands of sliders are able to be used as a lift point without welding them to the frame, C4 Fabrication, SDHQ, WKOR to name a few. Many have a drill and no drill option. If you choose not to drill You probably shouldn't use them as a lift point. The Shrockworks sliders I had on my 4Runner we bolt on with mounting points drilled into the frame in two places and I used them as lifting and recover points without issue. I would caution you to follow the recommendation of the manufacturer.
    OP, thanks for sharing. I've been torn between these, CBI, and C4 Fab sliders.
  21. Jan 13, 2021 at 12:32 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
  22. Jan 13, 2021 at 4:12 PM
    clarkritchie
    And here are the RCIs, I just put the driver's side on today. Man alive I cannot get the last bolt into the frame by the gas tank, I might need to grease one of my kid's hands and have her reach up in there. :)
    SLA10 likes this.
  23. Jan 17, 2021 at 6:24 PM
    VietGuy
    VietGuy New Member
    Houston
    2019 Tundra CrewMax Cement
    Sliders look great! Do you have any pictures of the side view of the truck? does the sliders sit flush with the frame?
  24. Jan 21, 2021 at 6:01 AM
    LunaPro
    Dreux
    2021 Crewmax Pro
    Just beginning
    VietGuy likes this.
  25. Jan 21, 2021 at 6:01 AM
    LunaPro
    Dreux
    2021 Crewmax Pro
    Just beginning
  26. Jan 21, 2021 at 6:02 AM
    LunaPro
    Dreux
    2021 Crewmax Pro
    Just beginning
    I hope this helps. Sorry it took so long.
    Darkness likes this.
  27. Jan 22, 2021 at 11:43 PM
    VietGuy
    VietGuy New Member
    Houston
    It looks awesome! Thanks for the photos!
  28. Mar 18, 2021 at 7:04 PM
    Pitbull410
    Anyone else have these? How are they holding up long term?
  29. Mar 20, 2021 at 6:54 AM
    LunaPro
    Dreux
    2021 Crewmax Pro
    Just beginning
    Sorry to say mine are rusting already! Not too happy about it. I installed them on the 21st of December. Ive contacted them and havent gotten any resolution from Cali Raised. We shall see. I am not the type to bash them or pound them online, but I will let you guys know how this is handled.
  30. Jul 1, 2021 at 1:15 PM
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    Soon to be 4WC Raven host. Mods to come.
    @Pitbull410 What sort of % discount do they offer during Black Friday?
